Hamburger Hypersonic July 19, 2009 Share July 19, 2009 (edited) mi fren thinkin of gettin tis 2005 2nd hand car. so basically he is paying paper value + 5k for body. so u tink its a gd idea?? Tried out e car but e gear change is v diff from Jap/Kor car n quite jerky. Hope bros here n mivera owner can shed some lights on tis autotrans.... cheers Edited July 19, 2009 by Hamburger ↡ Advertisement Link to post Share on other sites More sharing options...
Watwheels Supersonic July 19, 2009 Share July 19, 2009 Might as well get a used Zafira 1.8L. It has a proper automatic gearbox. The one in Meriva you have to lift up your foot from the throttle during upshift. The MPV is also based on the Opel Corsa. Link to post Share on other sites More sharing options...
Hamburger Hypersonic July 19, 2009 Author Share July 19, 2009 gd pt there,bro. will check it out......... Link to post Share on other sites More sharing options...
Tohto Hypersonic July 19, 2009 Share July 19, 2009 Drove the 1.4L manual version in Germany (rental car) for a few days. It is actually a very nice car. Very big rear leg space, boot is also very big even though this is quite a small car. Traveling at 160km/h on Autobann is still very stable even it is sitting quite high... Link to post Share on other sites More sharing options...
Hamburger Hypersonic July 19, 2009 Author Share July 19, 2009 its e transmission i m worry abt....really need some getting use to. Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear July 19, 2009 Share July 19, 2009 mi fren thinkin of gettin tis 2005 2nd hand car. so basically he is paying paper value + 5k for body. so u tink its a gd idea?? Tried out e car but e gear change is v diff from Jap/Kor car n quite jerky. Hope bros here n mivera owner can shed some lights on tis autotrans.... cheers Mom used to drive the corsa with that same g/box. the shifts are only jerky if you drive aggresively as it will make aggresive gear changes. If you take it easy, the shifts are really smooth. Link to post Share on other sites More sharing options...
Hamburger Hypersonic July 19, 2009 Author Share July 19, 2009 oic.....mayb i was too heavy footed . tat again, cant fault e car as e build is sturdy in & out. . will go try it out again Link to post Share on other sites More sharing options...
Picanto 3rd Gear July 20, 2009 Share July 20, 2009 mi fren thinkin of gettin tis 2005 2nd hand car. so basically he is paying paper value + 5k for body. so u tink its a gd idea?? Tried out e car but e gear change is v diff from Jap/Kor car n quite jerky. Hope bros here n mivera owner can shed some lights on tis autotrans.... cheers so, how much will he be paying in total? and which dealer he buy from? Link to post Share on other sites More sharing options...
Silver_blade Turbocharged July 20, 2009 Share July 20, 2009 (edited) I have a meriva. It is a good car and pretty reliable. The gear change is only jerky if you drive aggressively otherwise it is pretty smooth. Aggressive driving need to lift of the gas a little when changing the gear. Just treat it as a manual, instead of an auto trans and you will find the gear change to be 'normal'. It is just about getting used to it and accept that it is essentially a manual car. Shouldn't be a problem lah....my mum (given it to her) 'mastered' the technique in less than 2 days. i think the price you friend was quoted is attractive. I was quoted $7K for the body (mine is a '04 model) when I checked mid last year when i was considering to trade it in instead of keeping it. Edited July 20, 2009 by Silver_blade Link to post Share on other sites More sharing options...
Tonicwater Neutral Newbie July 20, 2009 Share July 20, 2009 (edited) Might as well get a used Zafira 1.8L. It has a proper automatic gearbox. The one in Meriva you have to lift up your foot from the throttle during upshift. The MPV is also based on the Opel Corsa. Not all Zafiras have actual automatic gearboxes. Only Zafira A 1.8 and Zafira B 2.2. The current Zafira B 1.8s are all MTA. The Meriva 1.6 uses the same MTA gearbox as well. And yes, MTA isn't your normal auto gear box so the TS need to get used to it. Or better, try it to make sure can live with it before getting. Edited July 20, 2009 by Tonicwater Link to post Share on other sites More sharing options...
Hamburger Hypersonic July 20, 2009 Author Share July 20, 2009 dealer in ubi......31k for july/05 car Link to post Share on other sites More sharing options...
Hamburger Hypersonic July 20, 2009 Author Share July 20, 2009 agree wif u bro, did e test drive again n was surprise its shift shock is ok thou not as smooth as asian make. all it takes is a light tap on e gas n let it chge smoothly(10% of full throttle). btw, where to check e ATF level, cant seem to locate e ATF dipstick, if there is 1...... Link to post Share on other sites More sharing options...
Notsogoodman 4th Gear July 20, 2009 Share July 20, 2009 Are you guys saying that OPEL is using an automated manual gearbox similar to Alfa's Selespeed? Link to post Share on other sites More sharing options...
Picanto 3rd Gear July 21, 2009 Share July 21, 2009 Are you guys saying that OPEL is using an automated manual gearbox similar to Alfa's Selespeed? alfa gearbox is of the higher end type. i doubt the opel gearbox can be compared to the alfa one. its like apple and oranges. Link to post Share on other sites More sharing options...
Furrynadz 5th Gear July 21, 2009 Share July 21, 2009 alfa gearbox is of the higher end type. i doubt the opel gearbox can be compared to the alfa one. its like apple and oranges. dont embarass yourself if you dont know what you are saying its like saying a european hooker is more high end than a china one Link to post Share on other sites More sharing options...
Hamburger Hypersonic July 21, 2009 Author Share July 21, 2009 meriva call it easytronic...which i guess is MTA??? So its still uses torque converter?? Link to post Share on other sites More sharing options...
Parkwalker Clutched July 21, 2009 Share July 21, 2009 Ever wondered why the owner wants to get rid of the car at such a low price? I suspect its maintenance cost... Used to own a corsa and the maintenance "killed" me. Simple servicing will cost you at least $500 - $1000, especially older cars. You can try to service outside but parts are hard to find. I used to hunt for parts in the whole of singapore, only to pay extremely high prices for original parts from GM because no where else sells the stuff. Mechanics can help you maintain the care but once parts spoils (which is fairly common for opel), that is it! In the end, you will save on the car but spend a hell lot more for parts and servicing... In fact, I got a pleasant shock when I realised how cheap servicing could be for japanese cars, even from agents! Maybe I am conti-accustomed then :) Buyers therefore beware... PS: BTW, easytronic always got problem. Heard of one person drive halfway, transmission stalled with "F" written on the shift indicator. The car had to be towed back for electronic refresh. The transmission hung, I think... While we could laugh at it, its not funny for the driver at that situation. Link to post Share on other sites More sharing options...
Kangadrool Supersonic July 21, 2009 Share July 21, 2009 (edited) Ever wondered why the owner wants to get rid of the car at such a low price? Seen a 2-year old Vectra 1.8MTA selling at just 48K few weeks back by direct owner and very tempted. But, it was snapped up within a few days. :) Heard too many stories of MTA/Easytronic/Selespeed/DSG screwing up. In a nutshell, either stick to shift stick (full manual) or traditional torque converter autobox. Edited July 21, 2009 by Kangadrool ↡ Advertisement Link to post Share on other sites More sharing options...
Opel Questions
Opel Questions
Car Wrap or respraying of the car?
What is OPC?
What is OPC?
Comparing Opel Astra 1.6 Twinport and Ford Focus 1.6 H/B
2017 Opel Crossland X
Opel Pledges To Make Sporty Cars Again By Bringing Back The GSe
