Babyt 4th Gear October 6, 2009 Share October 6, 2009 I just sent my qashqai for servicing and the side slip tested 0.6mm. what does it mean? searched the web for info but all lengthy and very chim. ↡ Advertisement Link to post Share on other sites More sharing options...
Hermitage 1st Gear October 6, 2009 Share October 6, 2009 Hmmm...yeah. I've had this test too and have NO idea what it means. Think it has something to do with wheel alignment? Link to post Share on other sites More sharing options...
Babyt 4th Gear October 6, 2009 Author Share October 6, 2009 (edited) i think so but if the measurement gets bigger n bigger what will happen?? for example, mine is 0.6mm...wat if it becomes 5cm? how to rectify? Edited October 6, 2009 by Babyt Link to post Share on other sites More sharing options...
Yeobh 4th Gear October 6, 2009 Share October 6, 2009 Click here for more info http://www.mycarforum.com/index.php?showto...side+slip\ Link to post Share on other sites More sharing options...
Cavver 4th Gear October 6, 2009 Share October 6, 2009 side slip = slip angle , mean on your car's handleing In x-axis , zero = your car go straight when steering is striaght, (-ve) = to the left when your steering is straight and (+ve)positive to right when steering is straight. possible your tires or your steering problems will result positive or negative figure. Link to post Share on other sites More sharing options...
Yeobh 4th Gear October 6, 2009 Share October 6, 2009 Which measurement or reading are you referring to - wheel toe angle reading ( in mm) or side slip reading ( -+5m/km) Link to post Share on other sites More sharing options...
CarsNStars Neutral Newbie October 6, 2009 Share October 6, 2009 (edited) A sideslip test is actually just another test for any potential wheel-alignment problems. +0.6mm is very very minor, and not an issue at all. Essentially, a sideslip result of +0.6mm means your vehicle will travel 0.6mm to the right over a distance (I believe it's 1m in your case) even if the wheels are maintained directly straight. So, with a sideslip result of +0.6mm, over a distance of 1km, your car will "slip" rightwards 600mm, or 60cm, or 0.6m. This is still well within rated specs of +5m/km. P.S It's quite common, you should not have to worry too much about it. :) Edited October 6, 2009 by CarsNStars 1 Link to post Share on other sites More sharing options...
Yeobh 4th Gear October 6, 2009 Share October 6, 2009 If the reading is side slip then it should read +0.6mm/M. The car will pull to the right by 600mm after travelling the distance of 1km. Link to post Share on other sites More sharing options...
Thargor 1st Gear October 6, 2009 Share October 6, 2009 Good to have it corrected....I had some issues with wheel alignment few months back and sent car back to AD for correction....doesn't cost much...definitely below 100 bucks...not bad for safely and reassurance of mind. Link to post Share on other sites More sharing options...
Yeobh 4th Gear October 6, 2009 Share October 6, 2009 The passing mark for side slip test should not be more than +- 5m/km Link to post Share on other sites More sharing options...
Mockngbrd Supersonic October 6, 2009 Share October 6, 2009 i only know of nip slip Link to post Share on other sites More sharing options...
Zniper 2nd Gear October 6, 2009 Share October 6, 2009 bro, where u do this side slip test?? might need to go one for my ride... :( Link to post Share on other sites More sharing options...
Yeobh 4th Gear October 6, 2009 Share October 6, 2009 Most of the Shell autoserve stations should have such service. Link to post Share on other sites More sharing options...
Beehive3783 Twincharged March 26, 2011 Share March 26, 2011 Sorry to bump this old thread, but does anyone know if there is any workshop in the North West area that does side slip testing and can also do the necessary adjustments to correct any excessive side slip? Link to post Share on other sites More sharing options...
Yeobh 4th Gear March 26, 2011 Share March 26, 2011 Check with Weltune Auto Svs Mr Phua Tel : 6755-4046 9755-4064 Link to post Share on other sites More sharing options...
Pisces69 6th Gear March 26, 2011 Share March 26, 2011 I just sent my qashqai for servicing and the side slip tested 0.6mm. what does it mean? searched the web for info but all lengthy and very chim. Is that a "PASS" with Viacom? If can pass, no need to adjust lah. BTW "side-slip" is the distance yr car will drift to the side off the center line on a given distance forward. If its very bad, u can even feel the steering pull to one side sometimes. Link to post Share on other sites More sharing options...
Pisces69 6th Gear March 26, 2011 Share March 26, 2011 Hmmm...yeah. I've had this test too and have NO idea what it means. Think it has something to do with wheel alignment? Er....Hermi, U so lau-chiau also dunno what is side-slip? U must b joking. Link to post Share on other sites More sharing options...
Pisces69 6th Gear March 26, 2011 Share March 26, 2011 bro, where u do this side slip test?? might need to go one for my ride... :( Search Kennys Alignment service in here. He at AMK autopoint. He specializes doing it. Price abt $50 fr a normal Jap car fr the 4 wheel computerised alignment. But many tire shops hv this service. Its better to go for the 4 wheel computerised alignment test as it addresses all the 3 parameters of your cars tracking. Any irregularities wil show up. U go for the basic mechanical side-slip check where the car is driven over 2 plates on the floor only check side drift of front wheels but its a cheaper option. Abt $25 I think. ↡ Advertisement Link to post Share on other sites More sharing options...
Right side speakers no sound
Need Advice On Honda Fit 2008 (GE) Side Mirror Repair
Herbal tonic wine (any side effects?)
Side mirror back cover replacement. where and how much?
Anti-slip treatment
Anti-slip treatment
Rain Shield for Side Mirror and Side Windows
SUV side step
SUV side step
Aircon not blowing cold air on driver side
