When to replace brakes rotors ?
Jimcheam
Hi Bros,
Do you know whether the brake rotor sizes for Vios and Altis are the same?
I got one for my 2006 FL Altis (stock 14inch 4x100 pcd wheel version). The mech says it is correct. The packaging says Vios on the box and when installed, it appears to be very "spacious" to the rims. Thanks.
Hi Bros,
Not only PCD and diameter. You need to make sure the center ring diameter and the offset of the rotor matches. If not, no go. Even if rotor can fit in, it will rub the ball joint, or your caliper may not fit.
for me, if the rotors have been worn to the stage where the outer edges of the discs protrudes more than the surface, when you run your finger from the edge towards the center.
Reason is:
- the pad will not have an optimal braking performance, as it contacts firstly and mostly on the edge rather than the surface of the disc
- the pad will also wear out pre-maturely, and unevenly.
- lastly, noisy.. 'eeeeeeeeee.. eeeek' due to contact with the outer edge of the rotor
I went back to WS and compared with my old discs that they still have around. I didn't have a ruler to measure but visually the difference in diameter is maybe 5mm. [hur] The mechanic said no problem. So far, the brakes are performing better, probably because they are new and the brake pads are supposed to be better than stock.
anyone can recommend where to get rotors cheap...can pm thanks
can get at taobao really cheap
example for my front rotor, a pair cost only about $50
http://item.taobao.com/item.htm?id=7176506917
of course there are more expensive ones to chose from, it all depend on user
just need to know how to search for it
Edited by Stanchiam
