Dafansu Turbocharged December 10, 2020 Share December 10, 2020 16 hours ago, inlinesix said: No. I remove the sensors before head off to tyre shop why remove sensor when head off to tyre shop? thought they will swap the thing for u ↡ Advertisement Link to post Share on other sites More sharing options...
mersaylee Hypersonic December 10, 2020 Share December 10, 2020 1 hour ago, Dafansu said: why remove sensor when head off to tyre shop? thought they will swap the thing for u Maybe to change tyre...might as well diy than risk being damage by poor handling... Link to post Share on other sites More sharing options...
mersaylee Hypersonic December 10, 2020 Share December 10, 2020 No need double sided tape...just tuck it snugly into the gap like a wedge. Link to post Share on other sites More sharing options...
inlinesix Hypersonic December 10, 2020 Share December 10, 2020 3 hours ago, Dafansu said: why remove sensor when head off to tyre shop? thought they will swap the thing for u I don't want them to mess it up. Link to post Share on other sites More sharing options...
Mkl22 Supersonic December 10, 2020 Share December 10, 2020 38 minutes ago, inlinesix said: I don't want them to mess it up. i usually leave it to them. they have installed more internal and external sensors than me. if they can also screw up such a simple task , then it is a shop that needs to be avoided. Link to post Share on other sites More sharing options...
Mkl22 Supersonic December 10, 2020 Share December 10, 2020 1 hour ago, mersaylee said: No need double sided tape...just tuck it snugly into the gap like a wedge. how come yours all kosong?😁 1 Link to post Share on other sites More sharing options...
mersaylee Hypersonic December 10, 2020 Share December 10, 2020 1 hour ago, Mkl22 said: how come yours all kosong?😁 Totally flat😁 Link to post Share on other sites More sharing options...
Discoburg Supersonic December 10, 2020 Share December 10, 2020 2 Link to post Share on other sites More sharing options...
Dafansu Turbocharged December 10, 2020 Share December 10, 2020 2 hours ago, Mkl22 said: i usually leave it to them. they have installed more internal and external sensors than me. if they can also screw up such a simple task , then it is a shop that needs to be avoided. Just did rotation at Kim Hoe, they change swap my external sensors for me also. Just a simple task as mentioned 2 Link to post Share on other sites More sharing options...
mersaylee Hypersonic December 10, 2020 Share December 10, 2020 (edited) I jinx it when I talked about "totally flat"...my front right is now deflated. Suspect it is either I over tighten or under tighten the sensor to the valve 😢 Edited December 10, 2020 by mersaylee 1 2 Link to post Share on other sites More sharing options...
Volvobrick Supersonic December 10, 2020 Share December 10, 2020 (edited) 11 minutes ago, mersaylee said: I jinx it when I talked about "totally flat"...my front right is now deflated. Suspect it is either I over tighten or under tighten the sensor to the valve 😢 Next time when replacing tyres just install an internal set at the same time. No over/under problems. Edited December 10, 2020 by Volvobrick 2 Link to post Share on other sites More sharing options...
mersaylee Hypersonic December 10, 2020 Share December 10, 2020 25 minutes ago, Volvobrick said: Next time when replacing tyres just install an internal set at the same time. No over/under problems. But need to go tyre shop to get them off then again for the next ride. JMH😅 1 Link to post Share on other sites More sharing options...
Volvobrick Supersonic December 10, 2020 Share December 10, 2020 14 minutes ago, mersaylee said: But need to go tyre shop to get them off then again for the next ride. JMH😅 Only 30 odd dollars for the whole set, labour cost will be at least 2, 3 times that! Just sell the car along with the TPMS. 1 1 Link to post Share on other sites More sharing options...
mersaylee Hypersonic December 10, 2020 Share December 10, 2020 1 hour ago, Volvobrick said: Only 30 odd dollars for the whole set, labour cost will be at least 2, 3 times that! Just sell the car along with the TPMS. Supposed to be my long term hold "investment" to maximise roi Now it's 三却一 😁 2 3 Link to post Share on other sites More sharing options...
Mkl22 Supersonic December 10, 2020 Share December 10, 2020 1 hour ago, mersaylee said: Supposed to be my long term hold "investment" to maximise roi Now it's 三却一 😁 Try removing batt to reboot it 1 Link to post Share on other sites More sharing options...
mersaylee Hypersonic December 10, 2020 Share December 10, 2020 13 minutes ago, Mkl22 said: Try removing batt to reboot it It's air leak caused by the sensor. Cost me $80 for tyre recovery service. I'm so gonna buy one of these on Saturday 😁 2 1 Link to post Share on other sites More sharing options...
Dafansu Turbocharged December 11, 2020 Share December 11, 2020 18 hours ago, Volvobrick said: Next time when replacing tyres just install an internal set at the same time. No over/under problems. external is better in my opnion, easier to just order online and change yourself if faulty. So far I've changed 3 set. 1 Link to post Share on other sites More sharing options...
Mkl22 Supersonic December 11, 2020 Share December 11, 2020 3 minutes ago, Dafansu said: external is better in my opnion, easier to just order online and change yourself if faulty. So far I've changed 3 set. Steelmate external has not failed me yet after 4years. ↡ Advertisement 2 1 Link to post Share on other sites More sharing options...
