Karoon Turbocharged December 7, 2009 Share December 7, 2009 i made this observation when i filled up my car tank with just about 4-5 litres of petrol at a petrol station... (long story... but basically just filled up enough to avoid empty tank so i can get to my preferred petrol provider) the first time i did it, i realised there was no impact whatsoever on my gauge, distance travelled, distance to empty indicator etc... i thought amount put in was too insignificant. second time, again same thing. but it got me thinking... 5L is a significant amount. is it possible that the first few litres is just vapour, no liquid, or a mix of both.... so you get much less than what you think? ↡ Advertisement Link to post Share on other sites More sharing options...
Haziqko Clutched December 7, 2009 Share December 7, 2009 i've tried filling up 10ltrs & only got me a few bars up, quite insignificant actually. i think its got to do with the shape of the tank + vapor + others. the bigger your tank at the bottom the less your meter go up. Link to post Share on other sites More sharing options...
Agentwilson 1st Gear December 7, 2009 Share December 7, 2009 yup, i agree. level sensors dun work so well at very low levels maybe? might be calibration error Link to post Share on other sites More sharing options...
Mingsect 5th Gear December 7, 2009 Share December 7, 2009 i made this observation when i filled up my car tank with just about 4-5 litres of petrol at a petrol station... (long story... but basically just filled up enough to avoid empty tank so i can get to my preferred petrol provider) the first time i did it, i realised there was no impact whatsoever on my gauge, distance travelled, distance to empty indicator etc... i thought amount put in was too insignificant. second time, again same thing. but it got me thinking... 5L is a significant amount. is it possible that the first few litres is just vapour, no liquid, or a mix of both.... so you get much less than what you think? naye, if you fill up to a empty fuel container b4. you will be able to see how many litres u pay is how many liter you pump... damn accurate.. most prob , like most gauge it will need longer time to register the change. read that most fuel gauge have this device to retard the sensor , so that when the vehicle is up or down the slope, the up and down fuel gauge won't scare/panic the driver. Link to post Share on other sites More sharing options...
Zyrofillica 1st Gear December 7, 2009 Share December 7, 2009 my car whenever the tank is almost empty (light have not light up), when i drive the 99 bends stretch, every corner the light will light up and then off when the car is straight. think my vehicle petrol sensor is damn bloody accurate Link to post Share on other sites More sharing options...
Adrianli Hypersonic December 8, 2009 Share December 8, 2009 What kind of level sensor is installed in the car's petrol tank??? Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear December 8, 2009 Share December 8, 2009 What kind of level sensor is installed in the car's petrol tank??? Usually a floater on a pivot linked to a variable resistance circuit. Link to post Share on other sites More sharing options...
Kb27 Supersonic December 8, 2009 Share December 8, 2009 It depends on your fuel sensor. Mine is a float with variable resistance. At both ends of the float, the reading is not linear. At the low end, it appears whatever you pump will not move the gauge much. Same thing at the top end, it appears that whatever you use the gauge does not move much. Link to post Share on other sites More sharing options...
Haziqko Clutched December 8, 2009 Share December 8, 2009 I think the concept is almost simliar to your toilet bowl tank. only the other way round. so if you can shake your toilet bowl tank when its filling up it will stop pumping in water intermitantly. thats why 1 forumer say his signal on-off when the car rolled. ↡ Advertisement Link to post Share on other sites More sharing options...
Singapore and Australia tank collided in Shoalwater Bay
Encounters with tyre shop
Do officials still check the 3/4 tank rule at causeway?
