yokechye 4th Gear January 9, 2017 Share January 9, 2017 Hmm... ok, i'll try to check the spec of the car cam, to ascertain whether it will cut off a few min after the engine is cut off. But if the power supply is not cut off, how will the car cam be able to know when to start any 'countdown' after the engine is cut off? I've not installed the cam yet, for fear that it will drain the batt dry after engine cut off... Will try to find out from the company that brought this in first... tks. OK tks. Yup, had heard from others that conti cars look to have the power continue running after engine cut. Will need to think of a way out... Not all I supposed. My new conti ride does shut power off to the 12v after engine cutoff ↡ Advertisement Link to post Share on other sites More sharing options...
Atrecord Supersonic January 9, 2017 Share January 9, 2017 Not all I supposed. My new conti ride does shut power off to the 12v after engine cutoff hmm... really? Wah, then different brands do different things, no standard leh... btw, what car are you driving now? Wonder whether got any switch to put at the aux power jack, so that can easily switch it off, or if mechanic can adjust to cut power when engine cut... Link to post Share on other sites More sharing options...
Magfocus 5th Gear January 9, 2017 Share January 9, 2017 hmm... really? Wah, then different brands do different things, no standard leh... btw, what car are you driving now? Wonder whether got any switch to put at the aux power jack, so that can easily switch it off, or if mechanic can adjust to cut power when engine cut... I use an aftermarket adapter for the 12v socket, with individual switches, so I can control what needs to be off when the car is off. 1 Link to post Share on other sites More sharing options...
Atrecord Supersonic January 9, 2017 Share January 9, 2017 I use an aftermarket adapter for the 12v socket, with individual switches, so I can control what needs to be off when the car is off. Oh, good. Tks. Was thinking of checking to see whether got or not. Where did you get it and how much did it cost? Link to post Share on other sites More sharing options...
Magfocus 5th Gear January 9, 2017 Share January 9, 2017 Oh, good. Tks. Was thinking of checking to see whether got or not. Where did you get it and how much did it cost? It was from aliexpress - pretty cheap, perhaps around $10 or under. Link to post Share on other sites More sharing options...
Atrecord Supersonic January 9, 2017 Share January 9, 2017 It was from aliexpress - pretty cheap, perhaps around $10 or under. ok tks. China one huh? I hope China stuff are now much safer... I had one china car charger some years back, which when i used to charge my samsung note 3, it gives out some smell, and the charger was really hot! I straightaway took it out and threw it away... Link to post Share on other sites More sharing options...
yokechye 4th Gear January 9, 2017 Share January 9, 2017 hmm... really? Wah, then different brands do different things, no standard leh... btw, what car are you driving now? Wonder whether got any switch to put at the aux power jack, so that can easily switch it off, or if mechanic can adjust to cut power when engine cut... Driving a VW Touran now. Last time I no need to on my engine I can use the 12v to vacuum and use for the car wash spray on my focus. Now I have to at least on the electronic system, dunno what it's called when you half on without switching o the engine, to use the 12v 1 Link to post Share on other sites More sharing options...
Magfocus 5th Gear January 9, 2017 Share January 9, 2017 ok tks. China one huh? I hope China stuff are now much safer... I had one china car charger some years back, which when i used to charge my samsung note 3, it gives out some smell, and the charger was really hot! I straightaway took it out and threw it away... So far so good, *touchwood* havent had any trouble. Had no choice also, needed to avoid draining the battery without having to plug out and in to the socket constantly. Link to post Share on other sites More sharing options...
Atrecord Supersonic January 9, 2017 Share January 9, 2017 Driving a VW Touran now. Last time I no need to on my engine I can use the 12v to vacuum and use for the car wash spray on my focus. Now I have to at least on the electronic system, dunno what it's called when you half on without switching o the engine, to use the 12v ok. I think it is something like Acc mode is it? So far so good, *touchwood* havent had any trouble. Had no choice also, needed to avoid draining the battery without having to plug out and in to the socket constantly. Yup, i'm feeling the same way too. Will go and look around challenger and car accessories shops to see whether got decent ones that aren't too expensive. Do you remember which one you bought? Link to post Share on other sites More sharing options...
Magfocus 5th Gear January 9, 2017 Share January 9, 2017 Do you remember which one you bought? It fits into the cupholder, with 2 12v sockets, a voltmeter display and 2 buttons to turn each one individually on or off. Link to post Share on other sites More sharing options...
Atrecord Supersonic January 9, 2017 Share January 9, 2017 It fits into the cupholder, with 2 12v sockets, a voltmeter display and 2 buttons to turn each one individually on or off. ok tks. Will try to find... Link to post Share on other sites More sharing options...
Boringchap Turbocharged March 8, 2017 Share March 8, 2017 Understanding customer experience. Ford GT supercar. Can't afford this car. Link to post Share on other sites More sharing options...
amirsamadzadeh Neutral Newbie August 11, 2018 Share August 11, 2018 I recently bought a honda s2000 car and I'm very pleased with it. I also have an exhibition that sells many Honda car models. You can log in to view our blog: خرید سربازی Link to post Share on other sites More sharing options...
DACH Supersonic August 11, 2018 Share August 11, 2018 I recently bought a honda s2000 car and I'm very pleased with it. I also have an exhibition that sells many Honda car models. You can log in to view our blog: Ø®Ø±ÛØ¯ Ø³Ø±Ø¨Ø§Ø²Û Hello, this is Ford forum. Link to post Share on other sites More sharing options...
Lchong 4th Gear August 11, 2018 Share August 11, 2018 Shouldn't this be under USA instead of conti? Link to post Share on other sites More sharing options...
DACH Supersonic October 4, 2018 Share October 4, 2018 Because Ford remove sedans from its lineup? https://www.detroitnews.com/story/business/autos/2018/10/02/us-auto-sales-september-2018/1495761002/ Link to post Share on other sites More sharing options...
Balaballs 1st Gear December 10, 2019 Share December 10, 2019 Hello All, Is there any Ford spare parts stockist or agent in Singapore? I have bought a Ford Galaxy Giah ecoboost 2010 model and trying to find some spare parts for this particular model. Please let me know if you know any. Thank you Link to post Share on other sites More sharing options...
BanCoe Hypersonic December 11, 2019 Share December 11, 2019 8 hours ago, Balaballs said: Hello All, Is there any Ford spare parts stockist or agent in Singapore? I have bought a Ford Galaxy Giah ecoboost 2010 model and trying to find some spare parts for this particular model. Please let me know if you know any. Thank you I remember there was one near in Desker Road(Hoover Auto I believe it was).... pls just google them ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Ford invents retractable exhausts
2022 Tesla Cybertruck and the Ford Executive Challenge
Let's talk about American pickup trucks.
Comparing Opel Astra 1.6 Twinport and Ford Focus 1.6 H/B
Ford Doing BTO, KYM?
Europe's Seven Big Car Brands In Free Fall Over Last 20 Years, Except One
In need of vehicle history software
2018 / 2019 Ford Focus
