Sci10213 3rd Gear March 21, 2010 Share March 21, 2010 Hi I'm a bit confused on this area... If there is a label on the tyre that says max pressure is 350, so my setting on the air pump is not more than this. But the label found on the car (driver side) states a different measurement like 2.1 or 4.2kgf something? This means what? ↡ Advertisement Link to post Share on other sites More sharing options...
Celicagt42010 Neutral Newbie March 21, 2010 Share March 21, 2010 You pump at the pressure on the label. Not the max pressure of the tyre. Just use an online conversion tool to convert between the units. Link to post Share on other sites More sharing options...
Tinydog Clutched March 21, 2010 Share March 21, 2010 Hi I'm a bit confused on this area... If there is a label on the tyre that says max pressure is 350, so my setting on the air pump is not more than this. But the label found on the car (driver side) states a different measurement like 2.1 or 4.2kgf something? This means what? pump more than 350 and your tyres go POP! Link to post Share on other sites More sharing options...
Pisces69 6th Gear March 21, 2010 Share March 21, 2010 Hi I'm a bit confused on this area... If there is a label on the tyre that says max pressure is 350, so my setting on the air pump is not more than this. But the label found on the car (driver side) states a different measurement like 2.1 or 4.2kgf something? This means what? ================== Most tires have a recommended pressure of about 210kpa. Do not pump too much more than this & never pump the Max pressure(350kpa) as stated on the tire. U wil prob kill yourself if u pump the max pressure. Link to post Share on other sites More sharing options...
Spying Clutched March 21, 2010 Share March 21, 2010 2.1 bar --> 210kpa --> 30psi approx. I usually pump according to the label by the door. That should be a rough guideline, i would imagine slightly less than recommended would mean more grip but faster wear while slightly more would mean less grip but less wear. Not too extreme though and definitely not max that the tire can withstand or risk going POP. Link to post Share on other sites More sharing options...
Nf0rc3r 1st Gear March 21, 2010 Share March 21, 2010 (edited) My states 1 passenger > Front 230 Rear 210 5 Pessengers + Luggage in Boot > Front 240 Rear 250 I pump all 250s. abit higher is quite ok. helps the fuel consumption too. Not too high until u lose grip though.. Edited March 21, 2010 by Nf0rc3r Link to post Share on other sites More sharing options...
Redplanet Clutched March 21, 2010 Share March 21, 2010 Mine @39 psi, about 270kpag. My personal preference though.....just avoid pumping to max pressure as stated on tyre wall. Link to post Share on other sites More sharing options...
Ladykillerz 4th Gear March 21, 2010 Share March 21, 2010 Hi I'm a bit confused on this area... If there is a label on the tyre that says max pressure is 350, so my setting on the air pump is not more than this. But the label found on the car (driver side) states a different measurement like 2.1 or 4.2kgf something? This means what? If your 2.1 is 2.1 bar, then should be equal to 30.45 psi and 210 kpa. Usually what people do is to add abit more air. I would recommend you to pump, 220kpa = 32 psi = 2.2 bar check your tyre pressure and best to do it at least once per month. ultimately, you have to decide yourself what pressure to use and how frequent you pump.~ BAR-to-PSI-to-KPa Converter Link to post Share on other sites More sharing options...
Hiphiphoray 6th Gear March 22, 2010 Share March 22, 2010 My 225 x 50 x 17" tyre also says 350 max. I always check and maintain 250 for my tyres. Is this ok ? Cos i notice everytime it goes under 230 pressure, can feel the tyres dragging on the road. Link to post Share on other sites More sharing options...
Puteh83 1st Gear March 22, 2010 Share March 22, 2010 i have the same problem...i pump it every fortnight... but feels the pressure drops 1 week later... tyres are quite new somemore... Link to post Share on other sites More sharing options...
Robo 2nd Gear March 22, 2010 Share March 22, 2010 i pump around 235-240 front n rear Link to post Share on other sites More sharing options...
Jordanplus 1st Gear March 22, 2010 Share March 22, 2010 it depens on your tyre size. bigger tyre pump higher psi. e.g 225/40/17 is different 225/50/17. am i right? i pump 230-240kpa for my 195/55/15. Link to post Share on other sites More sharing options...
Berncsp76 6th Gear March 22, 2010 Share March 22, 2010 (edited) yep...my pica 165/60/R14 i also pump 235-240... good to pump every week or fortnightly so as to optimise the tyres and improve FC..can add a little more if the distance from your home to the nearest petrol station is far coz the tyres will be heated up (air inside heats up too) so need to pump slightly higher pressure. Btw sometimes a bit confusing for different petrol stations too. I like to use those needle types that SPC provides rather than the See Hum wan which uses the electronic wan, coz the former gives me a more accurate reading. Edited March 22, 2010 by Berncsp76 Link to post Share on other sites More sharing options...
Lengendcf 1st Gear March 22, 2010 Share March 22, 2010 Hi I'm a bit confused on this area... If there is a label on the tyre that says max pressure is 350, so my setting on the air pump is not more than this. But the label found on the car (driver side) states a different measurement like 2.1 or 4.2kgf something? This means what? 350?? Pumping for car tyre or motorbike tyre? For car normally is 210psi to 250psi, that's why normally pump 230psi. Link to post Share on other sites More sharing options...
Melvinyuen 2nd Gear March 22, 2010 Share March 22, 2010 oh i pump 265 for both my set of tyres front and back i am running on 15" only wor hehe Link to post Share on other sites More sharing options...
Robo 2nd Gear March 22, 2010 Share March 22, 2010 oh i pump 265 for both my set of tyres front and back i am running on 15" only wor hehe wont it be a little too bouncy? Link to post Share on other sites More sharing options...
Redplanet Clutched March 22, 2010 Share March 22, 2010 350?? Pumping for car tyre or motorbike tyre? For car normally is 210psi to 250psi, that's why normally pump 230psi. Not psi, u mean kpag. Link to post Share on other sites More sharing options...
Lengendcf 1st Gear March 22, 2010 Share March 22, 2010 Not psi, u mean kpag. Haha, I think you are right. ↡ Advertisement Link to post Share on other sites More sharing options...
Valve stem washer?
Valve stem washer?
Portable Tyre Pump
Portable Tyre Pump
Pump Petrol In JB - Worth it
Do I need to change tire ?
Tire patching types and prices
Spare tire. do u remove or leave in boot?
How often do you pump air for tyres?
