Randolf Clutched March 29, 2010 Share March 29, 2010 Hi all, I have been very blur lately. i keep forgetting that i had start the engine and i would ignite it again. what are the damaging effects to the car over the long term? thank you ↡ Advertisement Link to post Share on other sites More sharing options...
Limbat 1st Gear March 29, 2010 Share March 29, 2010 Hi all, I have been very blur lately. i keep forgetting that i had start the engine and i would ignite it again. what are the damaging effects to the car over the long term? thank you Most likely your starter pinion will go 1st if worse the flywheel will wear out ....... Link to post Share on other sites More sharing options...
Bicolor 5th Gear March 29, 2010 Share March 29, 2010 Engine too quiet is it? My friend in HK did it with his Camry many times when he first got it. That was a year ago and apparently nothing wrong with his car. Not sure exactly how Camry compares to others in terms of quietness and sound insulation, but his previous car was a 16 year old Corolla with a very rough engine so it's understandable Link to post Share on other sites More sharing options...
Randolf Clutched March 29, 2010 Author Share March 29, 2010 haha, if its quiet still understandable. but the door and window was opened when i start the engine. this morning lagi worse, after i re-ignite the car kinda switch off and i have to restart it again. scare me sia. if i spoil the car, my dad cfm chop me sia. haha Link to post Share on other sites More sharing options...
Randolf Clutched March 29, 2010 Author Share March 29, 2010 is it expensive if the flywheel wears off, sounds like a major repair. Link to post Share on other sites More sharing options...
Heartbreakkidz Clutched March 29, 2010 Share March 29, 2010 I always did that with my honda fit,engine too quiet liao, heart pain when heard it scream in pain,haha. This one still okie,the one i fear is while moving,i accidentally shift the gear to reverse,then hongan liao surely the gearbox byebye ,luckily i never do that YET I noe there is a stopper that prevent u to shift the gear to R but sometimes haf the urge to shift the gear downwards to L in order to haf more power as gear one but only scare is shift upwards to R,haha Link to post Share on other sites More sharing options...
Randolf Clutched March 29, 2010 Author Share March 29, 2010 hey i used to shift to L often when i am on a slope, until my fren told me that its not wise to do so as it will damage the gear box and stuffs. Yea, seriously heartache when it scream in pain. Link to post Share on other sites More sharing options...
Jayl33 Neutral Newbie March 29, 2010 Share March 29, 2010 It's just a habbit that everyone has. There's 2 way to prevent this to happen by either; 1) turn your car key back anti clockwise and start a again or 2) step on the fuel and feel the engine. I usually check using no.2 correct me if i'm wrong. Link to post Share on other sites More sharing options...
Randolf Clutched March 29, 2010 Author Share March 29, 2010 no 2 sounds good thanks will do that from now on Link to post Share on other sites More sharing options...
Jamesc Hypersonic March 29, 2010 Share March 29, 2010 No real damage. car manufacturers can fix a device to stop restarts but to save money they dun! Link to post Share on other sites More sharing options...
Cavver 4th Gear March 29, 2010 Share March 29, 2010 no 2 sounds good thanks will do that from now on Just remember to step on crutch (Manual) or engage to P or handbrake (Auto) just in case move forward and run some1 down... Best way is have a clear mind before driving and dun blur !!! Link to post Share on other sites More sharing options...
Hotamp 3rd Gear March 29, 2010 Share March 29, 2010 It's just a habbit that everyone has. There's 2 way to prevent this to happen by either; 1) turn your car key back anti clockwise and start a again or 2) step on the fuel and feel the engine. I usually check using no.2 correct me if i'm wrong. actually just take a look onto the odometer will know if the engine is on or off....needle above zero, engine will be running. Link to post Share on other sites More sharing options...
Hammerhammer 1st Gear March 29, 2010 Share March 29, 2010 I always did that with my honda fit,engine too quiet liao, heart pain when heard it scream in pain,haha. This one still okie,the one i fear is while moving,i accidentally shift the gear to reverse,then hongan liao surely the gearbox byebye ,luckily i never do that YET I noe there is a stopper that prevent u to shift the gear to R but sometimes haf the urge to shift the gear downwards to L in order to haf more power as gear one but only scare is shift upwards to R,haha Ya I also kanna when I first got my FIT cos previously driving a noisy EG so suddenly feel very quiet. First few days when I stop at junction I thought car engine dies like my old EG have to look at the RPM meter to assure the engine is running Link to post Share on other sites More sharing options...
Manu27 Neutral Newbie March 30, 2010 Share March 30, 2010 no idea Link to post Share on other sites More sharing options...
Happily1986 5th Gear March 30, 2010 Share March 30, 2010 actually just take a look onto the odometer will know if the engine is on or off....needle above zero, engine will be running. yalor, isn't this method fastest and easiest? Link to post Share on other sites More sharing options...
Showtime Neutral Newbie March 30, 2010 Share March 30, 2010 best way i feel, is to prep everything eg, seat belt on, put your iphone in cradle, etc, before starting engine. once engine is on, drive off immediately. Link to post Share on other sites More sharing options...
Leepee 1st Gear March 30, 2010 Share March 30, 2010 His is simply a case of not my car so not really my problem. Last time I also lut my fathers car. Making fast u-turns without due care to the tyres or couplings. Rev the engine when it's cold. Turn the air con full cold when park in dark parks. Also hit many kerbs during parking. Trust me TS, whenit comes to your car. All this thigh will not happen as you will be very caring towards your car! Link to post Share on other sites More sharing options...
Relagsingh 4th Gear March 30, 2010 Share March 30, 2010 is it expensive if the flywheel wears off, sounds like a major repair. yes. can be quite major. depends how bad the flywheel is worn off. a flywheel almost acts like a balancer too as it is one one end of crankshaft. the crankshaft moves the con rods and pistons. it may seem minor but an engine moves at extremely high rpms. an unbalanced engine can cause severe damage. ↡ Advertisement Link to post Share on other sites More sharing options...
COE Bidding – Jun 2026
How to get car financing loan?
What could have causes this car to skid so badly?
