Kelvingoh45 Clutched May 25, 2010 Share May 25, 2010 Aircon at home fail so went down to Courts,the salesman there tell me that if my existing piping is conceal behine warobe or floor ceilling,they will not be able to change.The price of the system 4 aircon will still be the same even without piping changed. Will the performance of the new aircon be affected if piping are not change? What are the recomended brands for aircon. Mitsubishi,Carrier,Toshiba? ↡ Advertisement Link to post Share on other sites More sharing options...
Sjww57 Neutral Newbie May 25, 2010 Share May 25, 2010 Currently my system 3 also spoilt after 10 years. Upgrade to Mitsubishi System 4. I bypass all the major store and go direct to a aircon installation shop. Major store offer the BTU is lesser. I manage to get a 34000 BTU for HDB flat. Individual is 10,000 btu and the hall is 24000btu. All wiring and piping change new. If u are from 3 to 4, the bigger unit piping is different size. If I just change my compressor but keep the blower, they say No gurantee. Link to post Share on other sites More sharing options...
Little_prince Supersonic May 25, 2010 Share May 25, 2010 have to change... otherwise lots of problem down the line... leakage... insulation will deteriorate over time... etc... no point just change compressor without changing pipe Link to post Share on other sites More sharing options...
Fireball0088 5th Gear May 25, 2010 Share May 25, 2010 Aircon at home fail so went down to Courts,the salesman there tell me that if my existing piping is conceal behine warobe or floor ceilling,they will not be able to change.The price of the system 4 aircon will still be the same even without piping changed. Will the performance of the new aircon be affected if piping are not change? What are the recomended brands for aircon. Mitsubishi,Carrier,Toshiba? not sure how old is your aircon, but now they are using a slightly bigger piping (in diameter i meant).... better to change everything. why not go Safe superstore to ask for quotation Link to post Share on other sites More sharing options...
Freestylers09 5th Gear May 25, 2010 Share May 25, 2010 have to change..different systems got size difference in short, in "feng" of piping they use in market they call.. 3 feng or 5 feng etc etc kind Link to post Share on other sites More sharing options...
Zyrofillica 1st Gear May 25, 2010 Share May 25, 2010 my piping keep clogging up resulting in water leaking from the unit itself. any DIY solutions to recommend instead of paying the aircon man to come and clear the pipes? Link to post Share on other sites More sharing options...
Freestylers09 5th Gear May 25, 2010 Share May 25, 2010 use water vacuum cleaner to suck the water outlet pipe.. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic May 25, 2010 Share May 25, 2010 my piping keep clogging up resulting in water leaking from the unit itself. any DIY solutions to recommend instead of paying the aircon man to come and clear the pipes? I kenna the same problem recently. Unless you have the wet vacuum cleaner then you can DIY. Just suck the dirt out from the water outlet pipe. It's clogging the pipe. Else better to call the aircon guy. I call this guy who did my aircon for $30. Took out the whole unit to clean and also use the vacuum cleaner to suck from the outlet pipe. Link to post Share on other sites More sharing options...
Soya Supersonic May 25, 2010 Share May 25, 2010 how old is the extg piping? if changing from non-invertor to invertor a/c oso hv to change pipe. Link to post Share on other sites More sharing options...
Shanhz 3rd Gear May 25, 2010 Share May 25, 2010 air con prices gain city very competitive.. GSS coming, wait awhile Link to post Share on other sites More sharing options...
Best_ctzn Clutched May 25, 2010 Share May 25, 2010 my piping keep clogging up resulting in water leaking from the unit itself. any DIY solutions to recommend instead of paying the aircon man to come and clear the pipes? A ugly DIY method is to do a bypass from the fancoil output directly and pipe the tube to a pail on the floor. But must remember to empty the pail every morning. Link to post Share on other sites More sharing options...
Kelvingoh45 Clutched May 25, 2010 Author Share May 25, 2010 Currently my system 3 also spoilt after 10 years. Upgrade to Mitsubishi System 4. I bypass all the major store and go direct to a aircon installation shop. Major store offer the BTU is lesser. I manage to get a 34000 BTU for HDB flat. Individual is 10,000 btu and the hall is 24000btu. All wiring and piping change new. If u are from 3 to 4, the bigger unit piping is different size. If I just change my compressor but keep the blower, they say No gurantee. sorry ar......not 9000BTU X 3 15000Btu X 1 Link to post Share on other sites More sharing options...
Kelvingoh45 Clutched May 25, 2010 Author Share May 25, 2010 how old is the extg piping? if changing from non-invertor to invertor a/c oso hv to change pipe. i am currently using non invertor so i think must change Link to post Share on other sites More sharing options...
Kelvingoh45 Clutched May 25, 2010 Author Share May 25, 2010 Currently my system 3 also spoilt after 10 years. Upgrade to Mitsubishi System 4. I bypass all the major store and go direct to a aircon installation shop. Major store offer the BTU is lesser. I manage to get a 34000 BTU for HDB flat. Individual is 10,000 btu and the hall is 24000btu. All wiring and piping change new. If u are from 3 to 4, the bigger unit piping is different size. If I just change my compressor but keep the blower, they say No gurantee. i am replacing system 4 back to system 4 Link to post Share on other sites More sharing options...
Opel17 6th Gear May 25, 2010 Share May 25, 2010 my piping keep clogging up resulting in water leaking from the unit itself. any DIY solutions to recommend instead of paying the aircon man to come and clear the pipes? I had been using those aircon cleaner foam [in aerosol can]. The foam will clean the coils/fins in the room units, and will also loosen those "algae" that accumulate in the pipings, especially at the room unit drain hole. These aircon cleaners are available in Mustafa, Homely Hardware, ........ You can give a try. Simply follow the instructions on the can. Link to post Share on other sites More sharing options...
Zyrofillica 1st Gear May 26, 2010 Share May 26, 2010 I had been using those aircon cleaner foam [in aerosol can]. The foam will clean the coils/fins in the room units, and will also loosen those "algae" that accumulate in the pipings, especially at the room unit drain hole. These aircon cleaners are available in Mustafa, Homely Hardware, ........ You can give a try. Simply follow the instructions on the can. thx for the suggestions. Link to post Share on other sites More sharing options...
Xtrocious 1st Gear May 26, 2010 Share May 26, 2010 I had been using those aircon cleaner foam [in aerosol can]. The foam will clean the coils/fins in the room units, and will also loosen those "algae" that accumulate in the pipings, especially at the room unit drain hole. These aircon cleaners are available in Mustafa, Homely Hardware, ........ You can give a try. Simply follow the instructions on the can. At IMM, I keep seeing this pushcart that sells such cleaners - Mckenzie or something... Anyway, my aircon guy will use compressed air to clear the pipes every 6 months when he comes over to service my aircons... But my system 4 (McQuay) is coming to 10 years old and will need to replace them soon... Link to post Share on other sites More sharing options...
Actan72 5th Gear May 26, 2010 Share May 26, 2010 Aircon at home fail so went down to Courts,the salesman there tell me that if my existing piping is conceal behine warobe or floor ceilling,they will not be able to change.The price of the system 4 aircon will still be the same even without piping changed. Will the performance of the new aircon be affected if piping are not change? What are the recomended brands for aircon. Mitsubishi,Carrier,Toshiba? FYI, i would not go to courts.. I will go to Gain City.. They are very good and professsional... ↡ Advertisement Link to post Share on other sites More sharing options...
Home Aircon
Home Aircon
Aircon Cabin Filter
Aircon Cabin Filter
Aircon oil renewal necessary?
Car air-con
Car air-con
Dehumidifier recommendations
