Subzro Neutral Newbie January 12, 2011 Share January 12, 2011 Watch this video for headlight restoration. ↡ Advertisement Link to post Share on other sites More sharing options...
V200 Neutral Newbie March 3, 2011 Author Share March 3, 2011 OOT abit. i noticed that most conti cars' headlights tend to turn "blur" after like 3yrs old. but for Jap/Kor cars' headlights, after 5yrs still as clear as crystal. how come ah? I have seen many jap cars headlights turn yellowish. I think it is because they park under sun. Most of the time. And don't wash often ? Link to post Share on other sites More sharing options...
5936 1st Gear March 3, 2011 Share March 3, 2011 Material degrade by UV lights. Certain clear lens have this problem. Link to post Share on other sites More sharing options...
Fcuktion Neutral Newbie March 3, 2011 Share March 3, 2011 i just sand and polished my almost 20 years old clear headlamps, at least it doesnt look so tired now. 2500 grit > 3000 grit > rotary + orange pad + IP Link to post Share on other sites More sharing options...
Mlee 1st Gear March 3, 2011 Share March 3, 2011 Yawnzzzzz..... Link to post Share on other sites More sharing options...
Kspchew 2nd Gear March 4, 2011 Share March 4, 2011 Try using Hi Glaze 88. Did a couple of treatment and it looks good even after 6yrs under sun, rain.... Link to post Share on other sites More sharing options...
Parkingidiot 1st Gear March 4, 2011 Share March 4, 2011 OOT abit. i noticed that most conti cars' headlights tend to turn "blur" after like 3yrs old. but for Jap/Kor cars' headlights, after 5yrs still as clear as crystal. how come ah? Actually I've noticed this esp with Mercedes headlights.... and always left me wondering ... many mercs' headlights on the roads are totally blurred or fogged, can't see the bulbs at all, after a couple of years. Link to post Share on other sites More sharing options...
5936 1st Gear March 4, 2011 Share March 4, 2011 Are you good with sand paper? I ruined my windscreen after I used sandpaper to to remove the rough surface. Now it was battled with scratches. So I have fear for sand paper on glass Link to post Share on other sites More sharing options...
Fresh Clutched March 4, 2011 Share March 4, 2011 it depends on the grit you use, the higher the # the finer it is Link to post Share on other sites More sharing options...
5936 1st Gear March 4, 2011 Share March 4, 2011 I think waxing the headlight covers will provide some levels of protection against environment, Link to post Share on other sites More sharing options...
Blueraven Clutched March 4, 2011 Share March 4, 2011 OT abit... that headlight is not stock, how to pass LTA inspection? Link to post Share on other sites More sharing options...
5936 1st Gear March 4, 2011 Share March 4, 2011 What happeded to your stock headlamps? Link to post Share on other sites More sharing options...
Crawling Neutral Newbie March 15, 2011 Share March 15, 2011 great difference Link to post Share on other sites More sharing options...
Frog 1st Gear March 15, 2011 Share March 15, 2011 my ride's headlights also bit not as clear. gonna try colgate on my next wash Link to post Share on other sites More sharing options...
Hoytusa84 1st Gear March 15, 2011 Share March 15, 2011 Some say you can use tooth paste and rub it on the affected area while others use expensive headlight treatment/cleaner solutions. Tell us if it works. Mine also fogged up and condense inside the headlamp after went into flood water.. How long should I leave the toothpaste on? Link to post Share on other sites More sharing options...
Ichibawa 5th Gear March 16, 2011 Share March 16, 2011 Mine also fogged up and condense inside the headlamp after went into flood water.. How long should I leave the toothpaste on? Bro, no amount of rubbing and toothpaste is going to cure that. Its either you fill up the gaps or you can start choosing which guppies will look nice in your headlights for you to charm girls with. Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged March 16, 2011 Share March 16, 2011 actually apply wax over headlight plastics helps in preventing them from turning yellowish or blur. I wax car once every 3 month & also wax headlight, back signal lights, & wash car once evry 5 weeks or so. Car confirm dirty everytime but the headlight is always clear.. Same thing on 2 cars. My neighbour wash & wax every week, but never wax headlight. His car's paintwork looks new although car is 5 yr old.. But headlight looks old & used Link to post Share on other sites More sharing options...
Hoytusa84 1st Gear March 17, 2011 Share March 17, 2011 Bro, no amount of rubbing and toothpaste is going to cure that. Its either you fill up the gaps or you can start choosing which guppies will look nice in your headlights for you to charm girls with. Wahh.. I was so tempted to try it out that after reading the thread at 6am I went down wit a tube of Colgate and applied on my headlights! Surprisingly I left it for 8 hours and the condesation reduced! Anyway what kind of guppies you recommend? ↡ Advertisement Link to post Share on other sites More sharing options...
Energy Savings / Non Heat up LED Headlights Technology
Need help with water trapped in my headlight lamp cover. Anywhere to get it fix?
Car inspection questions
LED head light
LED head light
Theives Gouged Out This Poor Porsche Taycan's Headlights
Toyota Camry
Toyota Camry
Brighter headlights needed
