Yuan 6th Gear July 1, 2010 Share July 1, 2010 Just to add. Some cars like my current Passat, it's ok to leave the electrical stuff on because the ECU is "smart" enough to cut the current to all electrical stuff during cranking and switch them on only 2 or 3 secs after the engine has started up. But then, I still switch everything off due to habit. That is a good practice. ↡ Advertisement Link to post Share on other sites More sharing options...
RadX Moderator July 1, 2010 Share July 1, 2010 I notice alot of swtich off brain before starting their car and then forget to switch on. Any remedy? er...they have meh??? :angry: :angry: Link to post Share on other sites More sharing options...
Dunno Neutral Newbie July 1, 2010 Share July 1, 2010 er...they have meh??? :angry: :angry: They don't have an ECU but, however, they have lots of buttons, so many that you don't know which ones are the right combinations to press in order not to set off a nuclear bomb. For guys, there's only one on/off switch. Link to post Share on other sites More sharing options...
Yuan 6th Gear July 1, 2010 Share July 1, 2010 then some cars got gauge....machiam jet fighter lah..with the meters So you saying my car like jet fighter lah........But I don't fly aeroplane wor. Link to post Share on other sites More sharing options...
RadX Moderator July 1, 2010 Share July 1, 2010 So you saying my car like jet fighter lah.... ....But I don't fly aeroplane wor. er..lau ahpek like you need the meters la..i understand..to measure: 1. glucose level 2. Blood pressure 3. Water level 4. oxygen level...(for you hor not car intake) so for u in understand Link to post Share on other sites More sharing options...
Yuan 6th Gear July 1, 2010 Share July 1, 2010 (edited) er..lau ahpek like you need the meters la..i understand..to measure: 1. glucose level 2. Blood pressure 3. Water level 4. oxygen level...(for you hor not car intake) so for u in understand Hard to understand. Edited July 1, 2010 by Yuan Link to post Share on other sites More sharing options...
Joseph22 Turbocharged July 1, 2010 Share July 1, 2010 They don't have an ECU but, however, they have lots of buttons, so many that you don't know which ones are the right combinations to press in order not to set off a nuclear bomb. For guys, there's only one on/off switch. Link to post Share on other sites More sharing options...
Joseph22 Turbocharged July 1, 2010 Share July 1, 2010 Hard to understand. cause that one not for you to view. you dont understand no problem. Nurse understand can liao Link to post Share on other sites More sharing options...
The_Bear Turbocharged July 1, 2010 Share July 1, 2010 Hard to understand. when your under stand, its hard. Link to post Share on other sites More sharing options...
Krado Clutched July 1, 2010 Share July 1, 2010 I notice alot of swtich off brain before starting their car and then forget to switch on. Any remedy? Link to post Share on other sites More sharing options...
Vooth 2nd Gear July 1, 2010 Share July 1, 2010 Hey learn something new! Thanks! Link to post Share on other sites More sharing options...
Mandan Neutral Newbie July 1, 2010 Share July 1, 2010 But I said shake gear stick... ...its people like you who try to sound sexually explicit. Where got? All i asked was u sure gear stick or......... Noed,in red it's fill in the blanks, u answered yourself sexually explicit wad.. Link to post Share on other sites More sharing options...
Toledo 1st Gear July 1, 2010 Share July 1, 2010 I think it makes a diff to the batt life. in one of my previous rides i used to switch off the AC and radio b4 i turn off the engine and the batt lasted 3+ yrs. subsequently when i changed rides, i din bother and left the AC and radio on when i started the engine. after all the car was 'smart' and both the AC and radio will not start immed when the engine is cranked. however, the batt all lasted <1.5yrs. for my current ride, the batt lasted abt 2.5 yrs but i think it is partly also bec it is located at the boot which is much cooler than the engine bay. Link to post Share on other sites More sharing options...
Tom_kkh 1st Gear July 2, 2010 Share July 2, 2010 Hehe...it applies to all VW cars as well if I'm not wrong. I only noticed it when I forgot to off everything one day. Then after I start engine, few seconds later then the air con and head unit turn on. Actually, most modern cars has this feature, its nothing new, just that Singaporean got the habit of switching almost everything off. I know Kia caren confirm have. And i believe all those cars that comes with auto on headlights/wipers does have this feature. One way to test is very simple, like you mentioned, crank your key and see if your aircon/headlights/stereo(purposely turn on first) is off during the cranking and comes back again after the engine starts. Its much easier to spot if you have climate control, those knob type a bit tough to spot. Link to post Share on other sites More sharing options...
Mrmilktooth Supercharged July 2, 2010 Share July 2, 2010 Hello! Just some doubts that you guys can help: When you start your car EVERYTIME, is it better to switch off aircon and radio first? Or just aircon enough? Or it is perfectly alright just leave them on when switiching off and starting up your car? Read somewhere that it affects the car battery or alternator or something like that.. Cheers just insert key n crank... Link to post Share on other sites More sharing options...
Joseph22 Turbocharged July 2, 2010 Share July 2, 2010 Actually, most modern cars has this feature, its nothing new, just that Singaporean got the habit of switching almost everything off. I know Kia caren confirm have. And i believe all those cars that comes with auto on headlights/wipers does have this feature. One way to test is very simple, like you mentioned, crank your key and see if your aircon/headlights/stereo(purposely turn on first) is off during the cranking and comes back again after the engine starts. Its much easier to spot if you have climate control, those knob type a bit tough to spot. knob type very easy to spot also lah. just on your blower to max. then crank. most car will find a cut in air flow from the blower. Anyway my CS3 also will auto cut off when cranking the engine or iszi power all drained away to crank the engine? Link to post Share on other sites More sharing options...
Tom_kkh 1st Gear July 2, 2010 Share July 2, 2010 knob type very easy to spot also lah. just on your blower to max. then crank. most car will find a cut in air flow from the blower. Anyway my CS3 also will auto cut off when cranking the engine or iszi power all drained away to crank the engine? most of our doubts are answered here http://www.thecarcounselor.com/Assets/Articles/Myths.htm Link to post Share on other sites More sharing options...
Gabriel 1st Gear July 3, 2010 Share July 3, 2010 ↡ Advertisement Link to post Share on other sites More sharing options...
Lower your car interior temp when parking in the hot SUN
How to get car financing loan?
To be Happy, start thinking about Death!
COE Bidding – Jun 2026
