Keithchue 5th Gear July 29, 2010 Share July 29, 2010 guys, i do not know why, hope someone can enlighten me, does anyone feel that the engine is pulling harder when your EO hits 6K mark. is there anyhing wrong with my car? ↡ Advertisement Link to post Share on other sites More sharing options...
Roadhogger 2nd Gear July 30, 2010 Share July 30, 2010 what oil and grade is that? Link to post Share on other sites More sharing options...
Keithchue 5th Gear July 30, 2010 Author Share July 30, 2010 IMDEMTISU 5/40 my car is quite old...high mileage, suprisingly it is not eating any EO it is just sluggish when it hits 6k mark shell is 5k Link to post Share on other sites More sharing options...
Yuan 6th Gear July 30, 2010 Share July 30, 2010 IMDEMTISU 5/40 my car is quite old...high mileage, suprisingly it is not eating any EO it is just sluggish when it hits 6k mark shell is 5k When you say your car is quite old, I presume that it should be more than 3 years and the mileage should be more than 75k....I think the 5W40 should be fine to use and Imdemtisu is quite alright. Have you sent your car down to workshop for checking? Link to post Share on other sites More sharing options...
Keithchue 5th Gear July 30, 2010 Author Share July 30, 2010 my car is 5yrs old with 116K on the clock. have been sending to the same workshop and they said this is alright. just want to be sure that this is a norm. and usually FC will rise after 6k mark Link to post Share on other sites More sharing options...
Djdp Clutched July 30, 2010 Share July 30, 2010 that becos of the oil. Try FK Massimo. am using it and no more such feeling like previous oil used. Link to post Share on other sites More sharing options...
Robo 2nd Gear July 30, 2010 Share July 30, 2010 that becos of the oil. Try FK Massimo. am using it and no more such feeling like previous oil used. expensive n over rated. Link to post Share on other sites More sharing options...
Robo 2nd Gear July 30, 2010 Share July 30, 2010 IMDEMTISU 5/40 my car is quite old...high mileage, suprisingly it is not eating any EO it is just sluggish when it hits 6k mark shell is 5k imdemtisu isnt great... try others. my experienced with idemitsu with my old car wasnt great also. Link to post Share on other sites More sharing options...
Ehchang8 Neutral Newbie July 30, 2010 Share July 30, 2010 how about adding a can of oil treatment at 5k ? Link to post Share on other sites More sharing options...
Robo 2nd Gear July 30, 2010 Share July 30, 2010 how about adding a can of oil treatment at 5k ? normally if EO is of a certain quality no need oil treatment Link to post Share on other sites More sharing options...
Quirky_ster Clutched July 30, 2010 Share July 30, 2010 When my car was 4yrs old at 120K KM, I did a top overhaul. The amount of sludge and dirt that sits on the piston, valves, intake are just unbelievable.. Did that and you will your engine will be good as new... my FC improve by 1 notch and no heavy feeling even after 15K. me using Voltronics EO 5/40. and my ride was Opel Astra. Link to post Share on other sites More sharing options...
Robo 2nd Gear July 30, 2010 Share July 30, 2010 When my car was 4yrs old at 120K KM, I did a top overhaul. The amount of sludge and dirt that sits on the piston, valves, intake are just unbelievable.. Did that and you will your engine will be good as new... my FC improve by 1 notch and no heavy feeling even after 15K. me using Voltronics EO 5/40. and my ride was Opel Astra. clearing carbon n such every now and then helps keep the engine healthy also. prolong periods driving at <3k will harm the engine and den sludges will form will piston will not be able to work OT anymore Link to post Share on other sites More sharing options...
Yuan 6th Gear July 30, 2010 Share July 30, 2010 imdemtisu isnt great... try others. my experienced with idemitsu with my old car wasnt great also. Okay la.....Better than SHU. Link to post Share on other sites More sharing options...
Krado Clutched July 30, 2010 Share July 30, 2010 Okay la.....Better than SHU. My last oil change blur blur use SHU.. after 4-5k, Kwanza like to growl at me.. like an angry lion. Link to post Share on other sites More sharing options...
Robo 2nd Gear July 30, 2010 Share July 30, 2010 (edited) Okay la.....Better than SHU. IMO no difference both as bad. i have a friend who use the idemitsu metal can MIJ ones he say not bad. but i dun dare try also. stick to my regular EO better Edited July 30, 2010 by Robo Link to post Share on other sites More sharing options...
Mike1234 1st Gear July 30, 2010 Share July 30, 2010 So wad are the engine oils that you guys used??? [confused] Link to post Share on other sites More sharing options...
Krado Clutched July 30, 2010 Share July 30, 2010 So wad are the engine oils that you guys used??? [confused] Castrol Edge. Next change, gonna try Elf Excellium.. ↡ Advertisement Link to post Share on other sites More sharing options...
Engine Mounting
Engine Mounting
Questions about Toyota Mark X
