Robo 2nd Gear July 30, 2010 Share July 30, 2010 So wad are the engine oils that you guys used??? [confused] my regular is Redline. ↡ Advertisement Link to post Share on other sites More sharing options...
Mike1234 1st Gear July 30, 2010 Share July 30, 2010 Castrol Edge. Next change, gonna try Elf Excellium.. One thing i like about Castrol is that its Clear... Compared to other engine oil which is much "duller"... Not sure if there's any diff in terms of performance or not Link to post Share on other sites More sharing options...
Jamstart 1st Gear July 30, 2010 Share July 30, 2010 When you mentioned noisy, was it on the move or stationary? Link to post Share on other sites More sharing options...
Zanter 3rd Gear July 30, 2010 Share July 30, 2010 that becos of the oil. Try FK Massimo. am using it and no more such feeling like previous oil used. I used royal purple b4..its sucks after 5k. Amsoil..lotsa hype & reviews but useless for both my cars! FK Massimo...just 1 word..WOW..V smooth, very good boundary film strength and can last 10k for the fully syn range no problem. The more you rev, the sweeter your engine will sound. That why the Vtec guys or people who track often use this oil cos the temp stability of the engine..no over heating. Downside is expensive and I think no use for grocery shoppers. 1 other oil is better is ELF which Stuggart uses and is even better but at $60 a liter, it should be. Link to post Share on other sites More sharing options...
Yuan 6th Gear July 30, 2010 Share July 30, 2010 Castrol Edge. Next change, gonna try Elf Excellium.. Elf Excellium is good. Tried that engine oil on 2 separate occasions. Might be using back that oil again in the near future. Last oil change was CLTR. Recently change to Voltronic 5W40. Link to post Share on other sites More sharing options...
Yuan 6th Gear July 30, 2010 Share July 30, 2010 One thing i like about Castrol is that its Clear... Compared to other engine oil which is much "duller"... Not sure if there's any diff in terms of performance or not I have tried Castrol before. Very smooth till 10k mileage for me. Link to post Share on other sites More sharing options...
Yuan 6th Gear July 30, 2010 Share July 30, 2010 IMO no difference both as bad. i have a friend who use the idemitsu metal can MIJ ones he say not bad. but i dun dare try also. stick to my regular EO better I have not settled on 1 brand yet. Currently my regulars are Elf and Voltronic. Link to post Share on other sites More sharing options...
Djdp Clutched July 30, 2010 Share July 30, 2010 expensive n over rated. ha, to me worth every cents. not that ex too, normal price around 120-130 including labour depending on which grade, think the most ex one is around 160-170. company van uses the diesel engine oil, more power n travel 30-50km more every 3/4 tank compare to previous M****1 Link to post Share on other sites More sharing options...
Robo 2nd Gear July 30, 2010 Share July 30, 2010 ha, to me worth every cents. not that ex too, normal price around 120-130 including labour depending on which grade, think the most ex one is around 160-170. company van uses the diesel engine oil, more power n travel 30-50km more every 3/4 tank compare to previous M****1 Sounds like u're a dealer Link to post Share on other sites More sharing options...
Djdp Clutched July 30, 2010 Share July 30, 2010 Sounds like u're a dealer dun assume. i'm a car owner using FK oil & happy with it only. Link to post Share on other sites More sharing options...
Picanto 3rd Gear July 30, 2010 Share July 30, 2010 my car is 5yrs old with 116K on the clock. have been sending to the same workshop and they said this is alright. just want to be sure that this is a norm. and usually FC will rise after 6k mark get another WS to check. sometimes a 2nd opinion is better. Link to post Share on other sites More sharing options...
Wolfy3769 2nd Gear July 30, 2010 Share July 30, 2010 usually EO will last for 10K for fully synthetic one.. did not experience what u say before 10K.. was using the M*****1...(using the silver one.. think is 5W50) alos u mention that ur car was 5yr. maybe it is better than u use thicker EO.. that what my mech usually will do when car get oder... oil treatment.. that one might work.. but mostly i use thos fuel addictive to clean up the engine... it work for me... another could be the tire pressure that could give what u mention.. maybe just check the tire... cheers Link to post Share on other sites More sharing options...
Darkblue 1st Gear July 30, 2010 Share July 30, 2010 For brand, I will go for Amsoil & Redline. For quality of oils, I will ensure oil is ACEA A3/A5 or ILSAC GF-4. Coincidentally, these 2 brands oils are A3/A5 (depending on grade) & GF-4 (depending on grade) compliant. Cheers Link to post Share on other sites More sharing options...
Mr_w124 Neutral Newbie July 30, 2010 Share July 30, 2010 Been following this thread. Sorry TS to hijack your thread. i have been using penzoil in my ride for the past 1 year. so far ok. now, my mech told me its ok to use diesel engine oil since he says its ok for old cars. have tried it for the past week. seems quite smooth. the oil is toyota brand diesel oil. anyway, my car is 19yrs old so mech said its not a prob. Anyone knows if its ok? Link to post Share on other sites More sharing options...
Furrynadz 5th Gear July 30, 2010 Share July 30, 2010 yes and no can be use cos diesel oil usually thicker, but they usually contain some stuff like anti foaming agents..etc which are of no use to petrol engines the approach he is going is probably "spend less on petrol oriented oils and use a semi syn oil formulated for diesel which is cheaper" get a good oil formulated for older/high mileage cars Link to post Share on other sites More sharing options...
Winterrealm Neutral Newbie July 30, 2010 Share July 30, 2010 Hi everyone, im new here. sorry abt the hijack... need some quick answer Got a noob question to ask regarding on the features of the car http://www.sgcarmart.com/used_cars/info.ph...228&DL=1059 Features: This Is 1 Car That Everybody Love For The Retro Look And Super Safe Value. At $20k, How Much Can You Lose? If COE Goes Down, You Might Even Drive For Free! What does it mean by free drive when coe goes down? im new to it.. someone kindly to enlighten me. thankss Link to post Share on other sites More sharing options...
Kb27 Supersonic July 30, 2010 Share July 30, 2010 When my car was 4yrs old at 120K KM, I did a top overhaul. The amount of sludge and dirt that sits on the piston, valves, intake are just unbelievable.. Did that and you will your engine will be good as new... my FC improve by 1 notch and no heavy feeling even after 15K. me using Voltronics EO 5/40. and my ride was Opel Astra. Wow, what oil you normally used that you still get sludge ? Link to post Share on other sites More sharing options...
Jchuacl Clutched July 30, 2010 Share July 30, 2010 If it is consistent, use a OBD reader to capture the baseline readings and use it to compare after the 6K mark. I would probably look at ignition timing to see whether there is any retard. I did a dyno at the wheels for my celica at 145k and there is no loss of horsepower, so for me it is not normal. Even up till the 180k mark when I exported my celica, I don't have any increase in FC between oil changes. my car is 5yrs old with 116K on the clock. have been sending to the same workshop and they said this is alright. just want to be sure that this is a norm. and usually FC will rise after 6k mark ↡ Advertisement Link to post Share on other sites More sharing options...
Engine Mounting
Engine Mounting
Questions about Toyota Mark X
