Cooling spray for radiator
Moredhel
Dear Bros,
I understand that msot stock radiators are made to take the heat from both the EO and ATF/MTF and
I"ve been advised by several WS and experienced bros that this is actually not enough to handle the
cooling especially when you're driving long distance during a hot day.
Someone mentioned to be that it is possible to install water cooling sprays that some intercoolers use
for the stock radiator. Anyone knows where that can be done along with the relays and cabin controls?
I'm considering changing to an aluminium radiator but looking at other options.
Any bros can advise a newbie?
Thanks!
Can, you can even DIY yourself. All you need is a fine nozzle and a high pressure pump and thermistor that will activate the pump when temp rises to a certain degree. Ebay actually sells those intercooler spray kits you can buy and install it yourself. If you are even more KS, can go for CO2 spray instead of water.
However, I don't see the need for that and its a pain to top up water all the time.
If your stock radiator is insufficient, its either radiator is too small or there is insufficient air flow over it. You can get a bigger radiator at low price from ebay. Don't need to go for those $600 branded ones, its just a waste of money......
Edited by Mini-itx
Jeleburacer:
Steady lah. Looks quite easy to do. But I tot you gave me jap porn site link. ^^
It's just the wiring up to he cabin that is lay chey.
I prefer to spray it manually so I'll probably do a relay switch with a pulse delay module.
Something like a wiper pump system. Thanks for the link.
Itx:
Top up water easy easy. Pump petrol time top up can leh.
Or can do a rainwater catch tank, but bay no space to put.
Mai CO2 lah. Scared of chemicals. And must put tank. Later kenna by ROV for having CO2 tank in my car. Then emmision
cannot pass. I want also put Nitrogen Oxide tank right? [laugh]
Larger radiator I also want. But in the end cost alot. Also dunno if bracket can fit.
Can fit later must get bigger cooling fans. Then must uprate the motor to run the
bigger cooling fans. Then after that to control the cooling fans I must get the
fan control unit. Then after that to run the fans at optimal I must uprate my alternator.
Then I must uprate my battery to efficiently store the charge from my uprated alternator.
I think spray still better. ^^
Edited by Moredhel
Dear Bros,
Thanks!
what car are u driving? tat u want improved cooling?
Don't think it would be useful replacing the radiator without replacing of the thermostat - Thermostat opens gradually at a specific range of temperature, if the radiator is highly efficient, it would be useless if no hot coolant goes through it.
I'm not driving any sports/power car if that's what you mean.
Driving a humble B&B 1.6 car. No turbo. No SC. For now. [laugh]
But I'm thinking and learning ways to improve the engine efficiency and FC and
better cooling is one of the core mod steps to prevent overheating and other more
extreme stuff from running lean with advance timing over long distances.
Also interested in combining the spray with some sort of cooling
system to lower the temperature of my engine bay for 2 main reasons,
to reduce heated intake air temperature and my engine bay gets super hot
with the lousy design ventilation and no vent mods allowed on the side fenders
and hood(for safety reasons, the LTA says).
ATF coolers got thermostat one meh? Cause I thought TS is talking about his ATF radiator.
If water radiator, just get a bigger one lar. Ebay selling lots of them at low prices. I am using a cheap china made ebay radiator right now and not problems. Much thicker than stock radiator.
Btw, thermostat will not aid cooling if radiator is unable to extract heat out of the water. Can get bigger fans though. Again, ebay.... Lots of them...
Ebay is really my friend.
Some steps to cool your intake.
1. CAI, I don't mean open pod, just CAI, have a duct outside engine back to take in cool air.
2. shield and insulate your intake pipes form the engine heat.
3. Get a phenolic intake gasket. This will reduce your intake manifold temp.
4. Paint or shield your intake manifold from engine heat.
5. Shield your fuel rails and pipes from engine heat.
I re-read again, TS talking about radiator.
Like I said earlier, bigger radiator is useless if the thermostat don't open and let the water flow from engine to radiator.
You're right that thermostat don't aid cooling if radiator is unable to extract heat out of the water. In the first place,
under normal conditions, the stock radiator will do the job of extracting heat and maintaining it at the right temperature.
No doubt you can get bigger fans and extract as much heat from the water thereby lowering the coolant temperature.
However, bear in mind that if the temperature is too low, engine oil might not work effectively.
Dear Bros,
Thanks!
As long as yr cooling system is working as it sud, u can b stuck in a jam at hot afternoon sun n yr temp gauge sud stay just beow e 1/2 mark, which is e normal temp.
If yr temp gauge shows much hotter than normal, there is something wrong with yr cooling system like fans/thermostat faulty or too little coolant or blockage at exterior fins r water channels clogged.
Either way u need to send to a good reliable ws to check.
I dont advise putting those snake-oil stuff. It is a waste of yr $.
Also u usually get overheating while stuck in a jam. If u r moving along at a reasonable speed, the moving air sud b able to cool e coolant in yr cooling system unless it is faulty.
There is no need to change yr stock radiator as it was designed for yr car.
i am interested too ^_^
Fr yr case, i can re-route yr windscreen washers to spray water on yr radiatrs n inside yr cabin to keep yr engine n u cool. :D:D
Another option is place a bucket of water in yr back n once in awhile u come down n pour some water on yr engine block n on u n yr passengers to keep cool. [rolleyes]
yap, agree, nowadays, stock cooling system is good enough to handle most situation...
Unlike 30 yrs ago, u caneasily see car breakdown during traffic jam... 1 of the hot spot is causeway.. i still remember my father always worry that his dutson 120Y overheated when stucked in jam....
unless your car is more than 10 yrs old, or you have heavily moded your engine.... with proper maintainace of the radiator (change and flush the coolant according to manufacturer requirement), the stock radiator should be able to handle the heat generated from the engine...
Why wud u want to play around wh yr air/fuel n ignition timing settings?
U r only looking fr more trouble. If u dont know what u r doing, u gona burn yr valves n pistons which means a big overhaul n lots of $.
As long as yr temp gauge does not go much higher than normal, u r fine.
I fully agree.
Stock radiator is good enough for stock N.A. car.
TS hand/backside itchy only.
Cooling systems fail only when there is a fault in e system.
My 19 year old corona also never overheat.
