flashbang Turbocharged February 15, 2016 Share February 15, 2016 Easiest way to increase acceleration is to buy a new car. If you bought a slow car, don't expect it to fly like a F1 racecar... ↡ Advertisement Link to post Share on other sites More sharing options...
Terri 1st Gear February 15, 2016 Share February 15, 2016 Easiest way to increase acceleration is to buy a new car. If you bought a slow car, don't expect it to fly like a F1 racecar... Just to add... If want to play, buy a car that can play. If want to play but want to go cheap, you will play forever but will still not be satisfied 1 Link to post Share on other sites More sharing options...
Stanfordho96 2nd Gear February 15, 2016 Share February 15, 2016 idk why, on dyno my car shows 333nm of torque from 2200rpm all the way to 4000rpm. on paper the acceleration is 8s. but when i do real world test i get slower timing? gear ratio problem? Link to post Share on other sites More sharing options...
F355 Turbocharged February 16, 2016 Share February 16, 2016 idk why, on dyno my car shows 333nm of torque from 2200rpm all the way to 4000rpm. on paper the acceleration is 8s. but when i do real world test i get slower timing? gear ratio problem? That's around 260 to 280 bhp ; on a normal saloon car you should be going under 6 sec . Is it a heavy SUV since you are getting 8 sec ? Link to post Share on other sites More sharing options...
Stanfordho96 2nd Gear February 16, 2016 Share February 16, 2016 That's around 260 to 280 bhp ; on a normal saloon car you should be going under 6 sec . Is it a heavy SUV since you are getting 8 sec ? 333Nm is on crank. wheels ard 250+ mine is the all new C180 with monster tuned. now doing 201bhp That's around 260 to 280 bhp ; on a normal saloon car you should be going under 6 sec . Is it a heavy SUV since you are getting 8 sec ? 333Nm is on crank. wheels ard 250+ mine is the all new C180 with monster tuned. now doing 201bhp 1 Link to post Share on other sites More sharing options...
F355 Turbocharged February 16, 2016 Share February 16, 2016 333Nm is on crank. wheels ard 250+ mine is the all new C180 with monster tuned. now doing 201bhp Your torque of 333Nm is available from 2200 to 4000 rpm . At 4,000 rpm , your power output is already 186 bhp . If you are having 201 bhp max , it means that your max power occurs relative close to 4,000 rpm , my estimation probably around 4,200 rpm . Beyond 4,200 rpm , your torque drops dramatically .That's why you are getting 8 sec , the engine simply runs out of steam beyond 4,200 . Because century sprints are done with WOT , you need peak power output preferably all the way to 6000 rpm and beyond . C180 is 1.6L . A 1.6L NA engine gives you around 120 bhp , and in your C180 with turbocharging , you get 150 bhp stock . And because you are squeezing another massive 50bhp out of it to make it 200 bhp , the engine becomes grossly inefficient at the higher rpms hence the massive drop in torque at the higher revs. 1 Link to post Share on other sites More sharing options...
Stanfordho96 2nd Gear February 16, 2016 Share February 16, 2016 Your torque of 333Nm is available from 2200 to 4000 rpm . At 4,000 rpm , your power output is already 186 bhp . If you are having 201 bhp max , it means that your max power occurs relative close to 4,000 rpm , my estimation probably around 4,200 rpm . Beyond 4,200 rpm , your torque drops dramatically .That's why you are getting 8 sec , the engine simply runs out of steam beyond 4,200 . Because century sprints are done with WOT , you need peak power output preferably all the way to 6000 rpm and beyond . C180 is 1.6L . A 1.6L NA engine gives you around 120 bhp , and in your C180 with turbocharging , you get 150 bhp stock . And because you are squeezing another massive 50bhp out of it to make it 200 bhp , the engine becomes grossly inefficient at the higher rpms hence the massive drop in torque at the higher revs. i look at my torque graphs. the 333nm comes in at 2200pm and stretches flat out till 4000pm b4 it starts to drop. so its better if i use pedal shift and change gear at 4k? Link to post Share on other sites More sharing options...
F355 Turbocharged February 16, 2016 Share February 16, 2016 Shifting at 4k will not give you a lower sprint time ; but it will give you the feeling of a very torquey drive . 1 Link to post Share on other sites More sharing options...
Stanfordho96 2nd Gear February 16, 2016 Share February 16, 2016 Shifting at 4k will not give you a lower sprint time ; but it will give you the feeling of a very torquey drive . so ur advice to get a better sprint time. when do i shift my gears? Link to post Share on other sites More sharing options...
Mkl22 Supersonic February 16, 2016 Share February 16, 2016 At the redline of course 1 Link to post Share on other sites More sharing options...
Terri 1st Gear February 20, 2016 Share February 20, 2016 If you have lauch control then you need to use launch control to achieve that figure. Otherwise if just stepping from idling RPM from stationary you will not hit it. Temperature, tyres, driver, weight, fuel, all affects. Mfg data is controlled data performed at controlled environment. real life... will never get close.. But as long your car out accelerate others means your car better than theirs already. Link to post Share on other sites More sharing options...
Terri 1st Gear February 27, 2016 Share February 27, 2016 i look at my torque graphs. the 333nm comes in at 2200pm and stretches flat out till 4000pm b4 it starts to drop. so its better if i use pedal shift and change gear at 4k? It's not pedal shift. All automatic cars are smart enough to shift gears depending on your acceleration / speed condition. If you stepped lightly on the gas pedal, it's going to shift gears at 2000 rpm generally. If you stepped harder during acceleration, the gears will shift later, probably say 3500 rpm. Well,, if you then stepped pretty hard, lets say 90% to 100% to the metal, then it will shift at say 5500 rpm. To use pedal shifters, might as well just step harder. In my car, if I use the +/- gears, the shifting becomes more harsh, can feel the engine / gbox will feel a bit fierce during gear shifting. If I just step fully, the gears shifts smoothly, even at 5500 rpm Just use leg. That's what automatics are for. Forget about pedal shifters. They are for posers. Link to post Share on other sites More sharing options...
Mercury1 Turbocharged February 29, 2016 Share February 29, 2016 Don't stress out your engine man, does your car come with drive settings i.e sports mode, comfort mode etc? 333Nm is on crank. wheels ard 250+ mine is the all new C180 with monster tuned. now doing 201bhp 333Nm is on crank. wheels ard 250+ mine is the all new C180 with monster tuned. now doing 201bhp Link to post Share on other sites More sharing options...
KelvinAng_164458 Clutched February 29, 2016 Share February 29, 2016 Optimum timing of gear shifting, proper inflated tires and turn off your air con (air con take up some HP from the car) will increase your car acceleration. Checkout how its works at http://www.carreviewsncare.com/my-ride/ Link to post Share on other sites More sharing options...
KennyLee83 1st Gear March 1, 2016 Share March 1, 2016 surprised no one mention lose weight... aka driver + passenger :P *tongue in cheek* Link to post Share on other sites More sharing options...
Stanfordho96 2nd Gear March 1, 2016 Share March 1, 2016 Don't stress out your engine man, does your car come with drive settings i.e sports mode, comfort mode etc? yeah it does. twitch the gear shifts and more sensitive gas pedal(like a sprint booster) I went to tune the car again. its now about 350nm. the wheels spin when i do a sudden flooring of the pedals. Link to post Share on other sites More sharing options...
Mercury1 Turbocharged March 1, 2016 Share March 1, 2016 I see, given the case if you switch to sports it should change at optimal no need to use the pedals. Normally I use the pedals in comfort mode when the gear lags on the previous one too long while driving. Whats the width of your rear tyres? My car puts out about 350nm but has a 275 rear tyre profile which matches the output so no lose of traction. yeah it does. twitch the gear shifts and more sensitive gas pedal(like a sprint booster) I went to tune the car again. its now about 350nm. the wheels spin when i do a sudden flooring of the pedals. Link to post Share on other sites More sharing options...
ElisaGrace March 2, 2016 Share March 2, 2016 If you do any modification it won't always improve the acceleration, but what you really need is more horse power or less weight. A different transmission system might increase acceleration but it is expensive. The cheap and best way to improve acceleration is by removing unnecessary components and reducing the overall weight. Getting an oil change, getting higher quality oil, or even checking the spark plugs might improve your car's performance. https://www.yourmechanic.com/cars/hyundai ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Unichip Q
Unichip Q
Toyota Corolla Altis AB error causing ECU to restart
After stage 1 ecu remap, big decrease in fuel
Car with cheapest horsepower in SG
Volvo tuning help
Volvo tuning help
Giving away SwissTech Piggyback ECU for BMW 20/25/28i (N20)
Intermittent erratic idling and hesitant acceleration
