Shorty Turbocharged May 11, 2014 Share May 11, 2014 what car are u driving? proton exora. Hence the reason y i go to a shop in jb. Will find another time to go proton svc ctr in jb also. ↡ Advertisement Link to post Share on other sites More sharing options...
Kb27 Supersonic May 11, 2014 Share May 11, 2014 nope, not spongy brakes.. it just cannot stop that well..or should say the braking distance is long.. There's other things to look at before attempting any expensive "downgrade" to normal pump. 1. Stainless steel brake hose - reduce the swelling of rubber to cut the hydraulic power "loss" due to ballooning, in ebrake. 2. Upgrade to better brake pads 3. Check brake calipers 4. Is the vacuum hose to the booster brake pump broken or disconnected ? Some people install guni gong which essentially steals the brake boosting power. Link to post Share on other sites More sharing options...
Kurty Supercharged May 11, 2014 Share May 11, 2014 There's other things to look at before attempting any expensive "downgrade" to normal pump. 1. Stainless steel brake hose - reduce the swelling of rubber to cut the hydraulic power "loss" due to ballooning, in ebrake. 2. Upgrade to better brake pads 3. Check brake calipers 4. Is the vacuum hose to the booster brake pump broken or disconnected ? Some people install guni gong which essentially steals the brake boosting power. 1, really helps? If so, I don't mind investing in a ptfe telfon. After all, the original, I believe is 14yrs old 2, Yeah, I will go for ceramic type. Although kinda wasted, original still plentiful. 3, I guess nothing wrong as it was Just replaced... 4, didn't install such stuff... Will upgrade to 4 bbk, helps in stopping the distance? Link to post Share on other sites More sharing options...
Kb27 Supersonic May 11, 2014 Share May 11, 2014 1, really helps? If so, I don't mind investing in a ptfe telfon. After all, the original, I believe is 14yrs old 2, Yeah, I will go for ceramic type. Although kinda wasted, original still plentiful. 3, I guess nothing wrong as it was Just replaced... 4, didn't install such stuff... Will upgrade to 4 bbk, helps in stopping the distance? 1. Stainless steel brake hose is actually steel braid lined on the outside and ptfe on the inside. Go for Goodridge http://www.amazon.com/Goodridge-Stainless-Subaru-IMPREZA-Outback/dp/B000IJFHTC They are excellent hose, makes your braking much sharper. I had them on my Getz previously. It's a worthwhile investment. 4. Brake booster pump, vacuum hose should be checked, in case there's crack or leak, to be replaced. I won't go that far with big brake kit yet. Just try the above first. Link to post Share on other sites More sharing options...
sanga Neutral Newbie February 14, 2019 Share February 14, 2019 I just got the same problem here today. It's only been 4 month since I bought the car Link to post Share on other sites More sharing options...
Kklee 6th Gear February 14, 2019 Share February 14, 2019 I just got the same problem here today. It's only been 4 month since I bought the car Under warranty just send back to AD to rectified. Where you wash you car? ↡ Advertisement Link to post Share on other sites More sharing options...
Low Engine Oil Warning
How Much Do You Know About ABS?
Understanding Anti-lock Braking System (ABS)
Speed warning device for Vans/Lorries
Clown offer money to students to follow him
Town Council Issued with Fire Hazard Abatement Notices (FHAN) by SCDF
Combo Fog cum DRL LED lamp kit
Formula 1 Singapore GP Diary (Warning: Pics Intensive)
