Peqasus 1st Gear May 24, 2011 Share May 24, 2011 hey i;m staying in the west and it's jus way too dusty. any <$200 air purifier to recommend? So far looking at Novita Airpace Sharp Key critieria Small room <25 sqm replacement filter not too expensive dun hv to replace so frequently ↡ Advertisement Link to post Share on other sites More sharing options...
Wamphyri Neutral Newbie May 24, 2011 Share May 24, 2011 Hi there, Just want to share some info with you. The air purifier would only be able to work at its best if the room is closed. If you open the windows the air purifier efficiency would drop significantly. If you really want a good air purifier I would suggest honeywell. The filter size is large to give you maximum filtration and the filters are easy to maintain. It's used extensively in hospitals and they are well know in production of air purifiers. Other brand like sharp may look good but the filter size is no where near those in honeywell. Hope this little info helps you. Link to post Share on other sites More sharing options...
Dafansu Turbocharged May 24, 2011 Share May 24, 2011 get this honeywell, $399 china set http://www.massmark.com.sg/products/19219-...well-17200.html Link to post Share on other sites More sharing options...
Freestylers09 5th Gear May 24, 2011 Share May 24, 2011 http://www.daikin.com.sg/products.asp?series=r5 i got this for my office before think 400+ given specs to specs,this is 1 of the most wu hua compare to prices Daikin somemore,wont go wrong..give free filters etc easy maintain..got turbo mode also..haha Link to post Share on other sites More sharing options...
Hutan 1st Gear May 24, 2011 Share May 24, 2011 Hi there, Just want to share some info with you. The air purifier would only be able to work at its best if the room is closed. If you open the windows the air purifier efficiency would drop significantly. If you really want a good air purifier I would suggest honeywell. The filter size is large to give you maximum filtration and the filters are easy to maintain. It's used extensively in hospitals and they are well know in production of air purifiers. Other brand like sharp may look good but the filter size is no where near those in honeywell. Hope this little info helps you. bro, care to share more? why and what make u think sharp brand is not good at all? Link to post Share on other sites More sharing options...
Stingerquek Clutched May 24, 2011 Share May 24, 2011 hey i;m staying in the west and it's jus way too dusty. any <$200 air purifier to recommend? So far looking at Novita Airpace Sharp Key critieria Small room <25 sqm replacement filter not too expensive dun hv to replace so frequently As what I know,there are 2 different types of HEPA filter found in the air purifier in the market.Usually those <$300 use HEPA filter (99.95%).The more expensive one use True HEPA filter (99.97%) which is the type found in new born baby room, ICU,burn unit....etc at hospital.As I know,true HEPA can filter and "trap" virus and gems more effectively.As other filteraion function like carbonize filter (remove bad smell),platsmaculster (Active Ions) to kills virus,gems....etc in the air,negative ions,ultra long ray UV lights......etc is other unique features of different brands air purifier.That really boils down to what is your most important needs. Link to post Share on other sites More sharing options...
Panerex77 1st Gear May 26, 2013 Share May 26, 2013 Digging up this thread as i am looking ard for one purifier for my baby room. Did some comparisons at best denki earlier on. Comparing between panasonic and novita, which brand will you go for, assuming both at the same price but the novita has more layers of filter? Also, i am puzzled why purifiers will work better in a closed room? I have intennded to deploy it in a room wherer the windows are always slighlty ajar. Will it work? Link to post Share on other sites More sharing options...
Icedbs Turbocharged May 26, 2013 Share May 26, 2013 Digging up this thread as i am looking ard for one purifier for my baby room. Did some comparisons at best denki earlier on. Comparing between panasonic and novita, which brand will you go for, assuming both at the same price but the novita has more layers of filter? Also, i am puzzled why purifiers will work better in a closed room? I have intennded to deploy it in a room wherer the windows are always slighlty ajar. Will it work? Novita is more proven and specialized in air purifying. of course close room work better. If you have a window open, then whatever purified will be dirty again right since bad air will keep flowing in and clean air will always escape out. Link to post Share on other sites More sharing options...
Panerex77 1st Gear May 26, 2013 Share May 26, 2013 Novita is more proven and specialized in air purifying. of course close room work better. If you have a window open, then whatever purified will be dirty again right since bad air will keep flowing in and clean air will always escape out. Thanks So does it mean it does not make sense to deploy the unit near windows or door? Link to post Share on other sites More sharing options...
Cook123 Supercharged May 26, 2013 Share May 26, 2013 take note. a no of cheap ones produce ions which long term effects not proven n some research shows they can cause cells to mutate n cause cancer. i would get non ion ones. Link to post Share on other sites More sharing options...
Voodooman Supersonic May 26, 2013 Share May 26, 2013 (edited) I only trust honeywell, extremely reliable and effective, a little noisy but you get used to it. But expensive, cost me close to 800 when new. Edited May 26, 2013 by Voodooman Link to post Share on other sites More sharing options...
Jtay 1st Gear May 26, 2013 Share May 26, 2013 I only trust honeywell, extremely reliable and effective, a little noisy but you get used to it. But expensive, cost me close to 800 when new. I bought Honeywell HA170 from mjhub. Costs slightly less than $500. Although it's not the quietest one in the market, it seems to work well. My children have sensitive nose, and they seemed to be sleeping better now. The purifier is especially useful during those hazy days Link to post Share on other sites More sharing options...
Panerex77 1st Gear May 26, 2013 Share May 26, 2013 take note. a no of cheap ones produce ions which long term effects not proven n some research shows they can cause cells to mutate n cause cancer. i would get non ion ones. Hopefully novita ones are not one of those Link to post Share on other sites More sharing options...
Eliew Neutral Newbie May 28, 2013 Share May 28, 2013 http://www.systemswinners.com.sg/airfree/ Got this during Groupon promo - maintenance free, no harmful chemicals Link to post Share on other sites More sharing options...
Yewnotme Neutral Newbie June 19, 2013 Share June 19, 2013 You may want to consider the airflow rate, the efficiency and also how much can the filter hold. I can't cool effectively my 5 room flat hall with a small fan, similarly it is the same for Air Purifier, it is only effective if the air in the room can be sucked in and purified, so you may want the salesperson to know your requirements and let them recommend what is most suitable for your needs. As for filters, do not expect those thin slim units can hold unlimited dusts and last longer than some of those bigger, bulkier units. Link to post Share on other sites More sharing options...
Ysc3 Twincharged June 19, 2013 Share June 19, 2013 http://www.qoo10.sg/GMKT.INC/Goods/Goods.a...scode=410901271 Link to post Share on other sites More sharing options...
Summertime Neutral Newbie June 23, 2013 Share June 23, 2013 Hello I'm selling my Novita one for $189. Used only for few days. Have receipt to prove. PM me if you are interested? Can pass you at MRT station. Now everywhere sold out. Link to post Share on other sites More sharing options...
Fitvip Supersonic June 23, 2013 Share June 23, 2013 Hello I'm selling my Novita one for $189. Used only for few days. Have receipt to prove. PM me if you are interested? Can pass you at MRT station. Now everywhere sold out. Is yours NAP-101? ↡ Advertisement Link to post Share on other sites More sharing options...
Any Top Notch Buffet Catering to recommend? PLEASE!!
