Wubb Clutched September 2, 2011 Share September 2, 2011 been trying to find the stock 17 inch B-Class rims but to no avail. So no choice but to get the standard 17 inch C-Class rims. It can fit B-Class, right? If anyone came across the stock 17 inch B-Class rims, please let me know. Thanks a lot. ↡ Advertisement Link to post Share on other sites More sharing options...
Chickenbackside 1st Gear September 2, 2011 Share September 2, 2011 From these sources, quite unlikely. C-class 17" is 7.5J with an offset of 47mm. B-Class 17" is only 7J with an offset of 49mm. The C-class rims might stick out or rub against your fenders. But factory offsets tend to be on the conservative side, so the best way to find out is simply to try it on and see. http://www.originalwheels.com/mercedes-whe...ass2011rims.php http://www.benzworld.org/forums/w245-b-cla...t-question.html Link to post Share on other sites More sharing options...
Stooky 6th Gear September 2, 2011 Share September 2, 2011 can fit. my dad's B class is using the C class rims and tyres Link to post Share on other sites More sharing options...
Hamburger Hypersonic September 2, 2011 Share September 2, 2011 the difference in spec is minimum and well within tolerance. Its ok to use. Link to post Share on other sites More sharing options...
King_of_abalone Clutched September 2, 2011 Share September 2, 2011 From these sources, quite unlikely. C-class 17" is 7.5J with an offset of 47mm. B-Class 17" is only 7J with an offset of 49mm. The C-class rims might stick out or rub against your fenders. But factory offsets tend to be on the conservative side, so the best way to find out is simply to try it on and see. http://www.originalwheels.com/mercedes-whe...ass2011rims.php http://www.benzworld.org/forums/w245-b-cla...t-question.html Actually, it is perfect. You know many people try to find more aggressive offset wheels for their cars so that the wheels are flush with the fender? Seems like the C rims on B will do nicely. Rolling the fenders will be good to solve the problem of rubbing, although i don't think they are likely to rub. The only other possible problem that may arise will be the width of the C rims, that may rub against the suspension of the B. Link to post Share on other sites More sharing options...
Mecontle 1st Gear September 7, 2011 Share September 7, 2011 been trying to find the stock 17 inch B-Class rims but to no avail. So no choice but to get the standard 17 inch C-Class rims. It can fit B-Class, right? If anyone came across the stock 17 inch B-Class rims, please let me know. Thanks a lot. my auntie b170 comes stock 215/45/17 Link to post Share on other sites More sharing options...
Wubb Clutched September 7, 2011 Author Share September 7, 2011 my auntie b170 comes stock 215/45/17 ur auntie selling her b class wheels?? ↡ Advertisement Link to post Share on other sites More sharing options...
2016 Mercedes E-class (W213)
Aquatic Plants - Anyone into it as well?
