inlinesix Hypersonic June 10, 2020 Share June 10, 2020 39 minutes ago, JimmyRacerboy said: Hi any mini owners faced drive shaft issue? Just got advised to change mine, any recommended workshops for this? Thank you. Mini R or F series? ↡ Advertisement Link to post Share on other sites More sharing options...
Fcw75 Hypersonic June 10, 2020 Share June 10, 2020 3 hours ago, JimmyRacerboy said: Hi any mini owners faced drive shaft issue? Just got advised to change mine, any recommended workshops for this? Thank you. Elite driveshaft at Sin Ming. Link to post Share on other sites More sharing options...
inlinesix Hypersonic June 11, 2020 Share June 11, 2020 2 minutes ago, JimmyRacerboy said: F series What kind of drive shaft issue? Mini can't resolve it? Link to post Share on other sites More sharing options...
Andrewcwz Neutral Newbie June 16, 2020 Share June 16, 2020 Anyone knows the rough number of R53 Cooper S in manual guise in Sg nowadays? Interested in one ahaha. 1 Link to post Share on other sites More sharing options...
inlinesix Hypersonic June 25, 2020 Share June 25, 2020 Link to post Share on other sites More sharing options...
Frozentouch Clutched August 27, 2020 Share August 27, 2020 Hi all. Any recommendations for tyres for a 2018 Mini One, 16" for a softer ride? 1 Link to post Share on other sites More sharing options...
inlinesix Hypersonic August 28, 2020 Share August 28, 2020 9 hours ago, Frozentouch said: Hi all. Any recommendations for tyres for a 2018 Mini One, 16" for a softer ride? Skip all Run-flat. Michelin Primacy should be able to fit. 1 Link to post Share on other sites More sharing options...
Frozentouch Clutched August 28, 2020 Share August 28, 2020 1 hour ago, inlinesix said: Skip all Run-flat. Michelin Primacy should be able to fit. Ok. Thanks! Link to post Share on other sites More sharing options...
villan 2nd Gear October 4, 2020 Share October 4, 2020 Am considering a 2015 MINI Cooper S 2.0A 5DR. are they problematic or generally reliable? Is the ride very harsh and bumpy? 1 Link to post Share on other sites More sharing options...
inlinesix Hypersonic October 4, 2020 Share October 4, 2020 16 minutes ago, villan said: Am considering a 2015 MINI Cooper S 2.0A 5DR. are they problematic or generally reliable? Is the ride very harsh and bumpy? Whether the ride is very harsh and bumpy or not, it is better you test drive with your family. Do rem that this is a very low car (ground clearance: 146mm) vs Toyota Corolla (ground clearance: 175mm). Since it is a 5 year old car, get it check prior to purchase. If coolant piping leak, it is a huge work. 1 Link to post Share on other sites More sharing options...
villan 2nd Gear October 4, 2020 Share October 4, 2020 3 minutes ago, inlinesix said: Whether the ride is very harsh and bumpy or not, it is better you test drive with your family. Do rem that this is a very low car (ground clearance: 146mm) vs Toyota Corolla (ground clearance: 175mm). Since it is a 5 year old car, get it check prior to purchase. If coolant piping leak, it is a huge work. thanks for sharing. Any issues with huge/high humps and all given the low ground clearance? looking at rides with low mileage (<60k) 1 Link to post Share on other sites More sharing options...
inlinesix Hypersonic October 4, 2020 Share October 4, 2020 Just now, villan said: thanks for sharing. Any issues with huge/high humps and all given the low ground clearance? looking at rides with low mileage (<60k) As disclaimer, i am driving Mini R56. I have never any hugh/high humps yet. I usually don't do completely stop before humps. Link to post Share on other sites More sharing options...
Hamburger Hypersonic October 4, 2020 Share October 4, 2020 Even Mat Watson described Mini ride as firm or even harsh. But the handing is the rewarding part. Need to try it out yourself whether you could live with the trades off. 1 Link to post Share on other sites More sharing options...
inlinesix Hypersonic December 24, 2020 Share December 24, 2020 1 Link to post Share on other sites More sharing options...
Sdf4786k Twincharged January 1, 2021 Share January 1, 2021 On 10/4/2020 at 6:14 PM, inlinesix said: As disclaimer, i am driving Mini R56. I have never any hugh/high humps yet. I usually don't do completely stop before humps. The alternative is the countryman but that’s sort of not a mini but a maxi 1 Link to post Share on other sites More sharing options...
inlinesix Hypersonic January 1, 2021 Share January 1, 2021 21 minutes ago, Sdf4786k said: The alternative is the countryman but that’s sort of not a mini but a maxi No need countryman. Confirmed will not hit hump even factory short spring. Link to post Share on other sites More sharing options...
inlinesix Hypersonic January 13, 2021 Share January 13, 2021 Link to post Share on other sites More sharing options...
Sdf4786k Twincharged January 14, 2021 Share January 14, 2021 18 hours ago, inlinesix said: thats rather nice for a mid life update.. Would you know if its LTA friendly or must switch during STA inspection ? ↡ Advertisement Link to post Share on other sites More sharing options...
[Official] 2024 Mini Cooper
Renting a Mini bus to go Malaysia
Selling a 2017 Nissan Pulsar to buy a used 2016 Mini
Mini JCW GP Roll Over Shortly After Owner Takes Delivery
Next-Gen Mini Cooper Gets Special EV Sounds, Infotainment Modes, OTA Updates
The Best Cooling Measures: Ice Cream! 😂
