Minikong 1st Gear October 18, 2011 Share October 18, 2011 yoz all, just to check, beside wheel alightment, handling, typre pump, and steering wheel alightment. what other can u do to do the wheel alightment. i had done all of the alightment, i had mentioned, but i still feel my car handling is like lighter on the right hand side ↡ Advertisement Link to post Share on other sites More sharing options...
Hamburger Hypersonic October 18, 2011 Share October 18, 2011 next stage.....coilover , instantaneous result ............. Link to post Share on other sites More sharing options...
Viceroymenthol 6th Gear October 18, 2011 Share October 18, 2011 yoz all, just to check, beside wheel alightment, handling, typre pump, and steering wheel alightment. what other can u do to do the wheel alightment. i had done all of the alightment, i had mentioned, but i still feel my car handling is like lighter on the right hand side What do you mean? The steering feels light and not as tight when you turn right? Sounds like control arm bushing is gone. If you want original MINI branded part rather than OEM, have to replace entire arm. If you don't mind OEM, can just replace the bushing. Link to post Share on other sites More sharing options...
Viceroymenthol 6th Gear October 18, 2011 Share October 18, 2011 next stage.....coilover , instantaneous result ............. Stock Cooper S suspension already bone rattling. If replace with coilover, sure go see doctor But you are right. With coilover, steering will feel stiffer and more precise. I use the word feel cos that was what it felt like with my merc last time. Real or not i dunno... Link to post Share on other sites More sharing options...
Jamesc Hypersonic October 18, 2011 Share October 18, 2011 I have the same problem, the right side feels lighter. But only when I carry my MIL. She likes to sit behind the wife on the left hand side. Link to post Share on other sites More sharing options...
Watwheels Supersonic October 18, 2011 Share October 18, 2011 yoz all, just to check, beside wheel alightment, handling, typre pump, and steering wheel alightment. what other can u do to do the wheel alightment. i had done all of the alightment, i had mentioned, but i still feel my car handling is like lighter on the right hand side Google camber kit. Link to post Share on other sites More sharing options...
Minikong 1st Gear October 18, 2011 Author Share October 18, 2011 argh ok thx, but any way to check on it? as i had try different garage all said my car no problem Link to post Share on other sites More sharing options...
Minikong 1st Gear October 18, 2011 Author Share October 18, 2011 Stock Cooper S suspension already bone rattling. If replace with coilover, sure go see doctor But you are right. With coilover, steering will feel stiffer and more precise. I use the word feel cos that was what it felt like with my merc last time. Real or not i dunno... u are right, my gf and mum kp alot already Link to post Share on other sites More sharing options...
Hamburger Hypersonic October 18, 2011 Share October 18, 2011 u are right, my gf and mum kp alot already keep it that way then, best excuse not for MIL to board... Link to post Share on other sites More sharing options...
Sky_vinz Clutched October 18, 2011 Share October 18, 2011 For every 10,000km, - Tyre rotation. - Wheel balancing. - High speed balancing. For every 20,000km, - Wheel alignment (include camber setting). This is the guide I've been using for my car. You may wish to purchase strut bars and chassis bars for extra stiffness, without sacrificing much of the comfort of stock suspension. Link to post Share on other sites More sharing options...
Luckcent 4th Gear October 19, 2011 Share October 19, 2011 yoz all, just to check, beside wheel alightment, handling, typre pump, and steering wheel alightment. what other can u do to do the wheel alightment. i had done all of the alightment, i had mentioned, but i still feel my car handling is like lighter on the right hand side It may be due to castor not correctly set. Link to post Share on other sites More sharing options...
Minikong 1st Gear October 19, 2011 Author Share October 19, 2011 It may be due to castor not correctly set. so how do i verfied this thing call castor Link to post Share on other sites More sharing options...
Luckcent 4th Gear October 19, 2011 Share October 19, 2011 so how do i verfied this thing call castor You need someone who is good at 4 wheel alignment to correct it. Also this guy should also be able to correct the setback. Link to post Share on other sites More sharing options...
Forgot2bme Clutched October 19, 2011 Share October 19, 2011 (edited) Can check bearings also may be worn out.. Edited October 19, 2011 by Forgot2bme Link to post Share on other sites More sharing options...
Mllcg 3rd Gear October 19, 2011 Share October 19, 2011 For every 10,000km, - Tyre rotation. - Wheel balancing. - High speed balancing. For every 20,000km, - Wheel alignment (include camber setting). This is the guide I've been using for my car. You may wish to purchase strut bars and chassis bars for extra stiffness, without sacrificing much of the comfort of stock suspension. what is high speed balancing? Link to post Share on other sites More sharing options...
Hamburger Hypersonic October 19, 2011 Share October 19, 2011 maybe he meant this........ Link to post Share on other sites More sharing options...
Viceroymenthol 6th Gear October 19, 2011 Share October 19, 2011 You need someone who is good at 4 wheel alignment to correct it. Also this guy should also be able to correct the setback. But he mentioned he already did correct alignment. Alignment means correct the toe, camber and castor. Anyway, i think conti cars castor is "dead" one. Have to do modifications to make it more positive/negative. Link to post Share on other sites More sharing options...
Viceroymenthol 6th Gear October 19, 2011 Share October 19, 2011 Google camber kit. He said he already did alignment. Means camber adjustment is included and already corrected by workshop. If he did all alignment and still got steering problems, means bushings gone or control arm is bent. ↡ Advertisement Link to post Share on other sites More sharing options...
Online purchase for car parts
i Wake Up Naked Today Morning
ODO Mileage Tampering
Enzo car mats
Enzo car mats
