Ctng Neutral Newbie December 24, 2011 Share December 24, 2011 (edited) Guys, My ride is having tein ss with 225/40/18 tyres. should i adjust the tyres pressure then the suspension or the other way? Should i set my suspension firm and lower the tyre pressure? because right now my ride is abit harsh when going over uneven road but on flat surface its very firm. Edited December 24, 2011 by Ctng ↡ Advertisement Link to post Share on other sites More sharing options...
Yeobh 4th Gear December 24, 2011 Share December 24, 2011 The best person to ask is the one that do the recomendation/modifications - he should be an expert in car suspension. Link to post Share on other sites More sharing options...
Watwheels Supersonic December 24, 2011 Share December 24, 2011 Your setup will definitely give you a harsh ride at slow speed. No matter how you adjust it won't help. IMO unless you are driving in a track or circuit most of the time, in sgp roads if I were you I keep my ride's suspension and rim size in stock condition. Your setup now is not just making you uncomfortable but also making you tired easily. Good luck with your adjustments. Link to post Share on other sites More sharing options...
Thedream 3rd Gear December 24, 2011 Share December 24, 2011 Guys, My ride is having tein ss with 225/40/18 tyres. should i adjust the tyres pressure then the suspension or the other way? Should i set my suspension firm and lower the tyre pressure? because right now my ride is abit harsh when going over uneven road but on flat surface its very firm. I suggest to pump your tyres to the recommended pressures, then adjust your coilovers till you're comfortable. If in the softest setting you're still not comfortable, then you'll know that you'll just need to get used to it... in general, performance should be better on harder settings. You should set your suspension to a hard setting that you can accept. And to correct understeer, your front should be softer than the rear (vice versa for oversteer). A lot of trial and error, but you can consider investing in an EDFC which lets you set your damping by using the controller... Link to post Share on other sites More sharing options...
Forummer Neutral Newbie December 24, 2011 Share December 24, 2011 (edited) It shouldn't be. Tein SS is quite comfortable. I'm using it too. I'm on 205/50/17. Tyre pressure at 230. I set my damper to be 1/3 firm only. Family likes it. It depends on how short you adjusted your struts and springs. If they are all extremely short then your travel will be short and harsh. Mine is just nice. I adjusted mine at BKS. Great job done. Edited December 24, 2011 by Forummer Link to post Share on other sites More sharing options...
Ctng Neutral Newbie December 24, 2011 Author Share December 24, 2011 I suggest to pump your tyres to the recommended pressures, then adjust your coilovers till you're comfortable. If in the softest setting you're still not comfortable, then you'll know that you'll just need to get used to it... in general, performance should be better on harder settings. You should set your suspension to a hard setting that you can accept. And to correct understeer, your front should be softer than the rear (vice versa for oversteer). A lot of trial and error, but you can consider investing in an EDFC which lets you set your damping by using the controller... my car is a rwd so front pump lesser and rear more? how much air should i pump for 225/40/18? my car weights abt 1500kg Link to post Share on other sites More sharing options...
Ctng Neutral Newbie December 24, 2011 Author Share December 24, 2011 It shouldn't be. Tein SS is quite comfortable. I'm using it too. I'm on 205/50/17. Tyre pressure at 230. I set my damper to be 1/3 firm only. Family likes it. It depends on how short you adjusted your struts and springs. If they are all extremely short then your travel will be short and harsh. Mine is just nice. I adjusted mine at BKS. Great job done. i try setting it to firm setting. i set to max and release 3 click. i find that my ride handle better a with firm settings but my cabin starts to rattle. =( Link to post Share on other sites More sharing options...
Thedream 3rd Gear December 24, 2011 Share December 24, 2011 my car is a rwd so front pump lesser and rear more? how much air should i pump for 225/40/18? my car weights abt 1500kg try the manufacturer's recommended first. Adjust your coilover damping using that to see whether you can accept the "harshness." As Forummer has said, Tein SS are supposed to be quite comfortable... Link to post Share on other sites More sharing options...
Forummer Neutral Newbie December 24, 2011 Share December 24, 2011 i try setting it to firm setting. i set to max and release 3 click. i find that my ride handle better a with firm settings but my cabin starts to rattle. =( It's a lot of trial n error. Just adjust the damping yourself. It's easy. Then go for test drive. If not good then adjust again. It really boils down to what you want. How firm or how comfortable? Link to post Share on other sites More sharing options...
Ctng Neutral Newbie December 25, 2011 Author Share December 25, 2011 It shouldn't be. Tein SS is quite comfortable. I'm using it too. I'm on 205/50/17. Tyre pressure at 230. I set my damper to be 1/3 firm only. Family likes it. It depends on how short you adjusted your struts and springs. If they are all extremely short then your travel will be short and harsh. Mine is just nice. I adjusted mine at BKS. Great job done. bks is where? ↡ Advertisement Link to post Share on other sites More sharing options...
Michelin Primacy 5 Energy
Golden Village opens first all-laser cinema in Paya Lebar
China First Aircraft Carrier ....
Pirelli P Zero PZ5
Pirelli P Zero PZ5
