Lattesurf Neutral Newbie May 30, 2012 Share May 30, 2012 actually you can, but not 205/65 R15, it's 205/65 R14 now your stock one 185/65 R15 diameter 512mm, 205/65 R14 has the same diameter, so your speedo and odo no change Abit overkill right? Change tyres become change rims as well.. 15 to 14. ↡ Advertisement Link to post Share on other sites More sharing options...
Ngsengpoh Neutral Newbie May 30, 2012 Author Share May 30, 2012 Hi all, just change my tyres to 205/65 R15. Seem everything ok. Driving seem to be more stable due to the big tyres. FC seem to be stable also. Drive for 2 days abt 180km but still maintain at 12.5km per litre. Link to post Share on other sites More sharing options...
Iiiusion 2nd Gear May 30, 2012 Share May 30, 2012 Hi all, just change my tyres to 205/65 R15. Seem everything ok. Driving seem to be more stable due to the big tyres. FC seem to be stable also. Drive for 2 days abt 180km but still maintain at 12.5km per litre. FC confirm will b affected... Link to post Share on other sites More sharing options...
Ngsengpoh Neutral Newbie June 1, 2012 Author Share June 1, 2012 FC confirm will b affected... Just top up my petrol. Still maintain 12.5km per litre. Actually I think won't affect anything. Another good think is more stable driving. Sharp turning become more stable. Link to post Share on other sites More sharing options...
Caldina 1st Gear June 1, 2012 Share June 1, 2012 FC confirm will b affected... The mileage shown on your meter does not refelect the real mileage. Due to a higher OD, your mileage reflected on your meter will be higher, hence you will feel that your car has a better FC. Link to post Share on other sites More sharing options...
Lattesurf Neutral Newbie June 1, 2012 Share June 1, 2012 So far after changing 205/55/16 to 225/40/18, the slight increase in OD actually resulted in a minor improvement in FC. From 12.5km/L on old tires, to 12.8km/L on the 18" tyres. Link to post Share on other sites More sharing options...
Roberttan 5th Gear June 2, 2012 Share June 2, 2012 The mileage shown on your meter does not refelect the real mileage. Due to a higher OD, your mileage reflected on your meter will be higher, hence you will feel that your car has a better FC. brother changing from 185/65/15 to 205/65/15 your speedo reading is UNDER your actual speed is faster Link to post Share on other sites More sharing options...
Raz6662012 Neutral Newbie June 4, 2012 Share June 4, 2012 can i use 205 45 16" on a toyota yaris Link to post Share on other sites More sharing options...
Ungtiong 2nd Gear June 6, 2012 Share June 6, 2012 my speedometer is 9% out so thinking to upsize my stock 195/65/15 to 205/65/15.....tyres only 14k. Link to post Share on other sites More sharing options...
Ngsengpoh Neutral Newbie July 4, 2012 Author Share July 4, 2012 Thanks bros for all your advises. Had changed my tyres to 195/65 R15. Think should be alright. Link to post Share on other sites More sharing options...
Passion 5th Gear July 4, 2012 Share July 4, 2012 Bro, you very rich hor. Keep changing to and fro. You trade in 205/65/15 tires? Link to post Share on other sites More sharing options...
ER-3682 Supersonic July 4, 2012 Share July 4, 2012 Bro, you very rich hor. Keep changing to and fro. You trade in 205/65/15 tires? He changed it maybe due to the tyres rubbed the fenders when carry 2 persons.?? Link to post Share on other sites More sharing options...
Roberttan 5th Gear July 6, 2012 Share July 6, 2012 He changed it maybe due to the tyres rubbed the fenders when carry 2 persons.?? you are GOD. but you are not necessary right i always believe and share with fellow friend, always stick to car maker recommended size (either orginally fitted or refer to owner manual or door pillar/petrol cap cover for more tyre size and pressure info. Stick to OE size and go for better or Premium Quality tyre is the BEST choice. 1 sad example last saw a BMW 645 (4500 cc ) fitted with 22 inch well reputable Brand rim fitted with (roadstone ) my guess the rim could cost up to $1500 @ but just can not understand the owner only will to pay cheap price tyre Tyres is the only 4 contacts you or we had inside the car. Link to post Share on other sites More sharing options...
Lattesurf Neutral Newbie July 6, 2012 Share July 6, 2012 you are GOD. but you are not necessary right i always believe and share with fellow friend, always stick to car maker recommended size (either orginally fitted or refer to owner manual or door pillar/petrol cap cover for more tyre size and pressure info. Stick to OE size and go for better or Premium Quality tyre is the BEST choice. 1 sad example last saw a BMW 645 (4500 cc ) fitted with 22 inch well reputable Brand rim fitted with (roadstone ) my guess the rim could cost up to $1500 @ but just can not understand the owner only will to pay cheap price tyre Tyres is the only 4 contacts you or we had inside the car. Expensive tyres doesn't mean any safer than cheaper tyres. Unless there are statistics to prove the higher occurrences of accidents due to cheaper tyres, else it's just a mindset that Expensive = Good, Cheap = Lousy. Link to post Share on other sites More sharing options...
Prostcode Clutched July 6, 2012 Share July 6, 2012 Hellaflush Link to post Share on other sites More sharing options...
Roberttan 5th Gear July 6, 2012 Share July 6, 2012 Expensive tyres doesn't mean any safer than cheaper tyres. Unless there are statistics to prove the higher occurrences of accidents due to cheaper tyres, else it's just a mindset that Expensive = Good, Cheap = Lousy. each of every one has different definition EXPENSIVE AND CHEAP accidents can due to many reasons. TYRE is only 1 of many reason just like the recent ferrari case shown that the CAR or TYRE is NO good? EXP car like mercedes is definitely suffer less demaged compare to other cheaper car TOYOTA ? PROTON ? MAZDA ? ↡ Advertisement Link to post Share on other sites More sharing options...
Petlas Or Giti?
Petlas Or Giti?
Is this tyre good? Made in SG!! Giti tyres!
