Windwaver Turbocharged June 19, 2012 Author Share June 19, 2012 my car power totally cut-off when im still driving at 2pm along yio chu kang road. Lucky, behind no car. if not, sure chain accident. Heng ah!!!!! Brake and steering wheel is still working well. 1st time SOS for a flat towing car to tow back to agent Aiyo, battery dead or alternator died? ↡ Advertisement Link to post Share on other sites More sharing options...
Timex1441 1st Gear June 19, 2012 Share June 19, 2012 I just changed my alternator for s$2k. Blardy kui! u kidding rite? $2K? Is it a titanium material n then gold-plated? Link to post Share on other sites More sharing options...
Kia0042 2nd Gear June 19, 2012 Share June 19, 2012 Aiyo, battery dead or alternator died? I kenna before, don't play play if alternator faulty. Was thinking just battery indicator light, no big problem can still drive lah. So, what happened when I was at high speed 120km/hr towards CTE tunnel, firstly radio power auto cut off, 10sec later speed meter indicator started to "dance" like crazy and the steerling became heavier and heavier that almost uncontrollable. Luckily not many cars at that time (new year 1 jan 11, 7AM), I reduced speed, switched into lane 2 , lane 3 and managed to stop at road shoulder, phew~~~ Paid for my 2nd hand alternator + labour $1k+. 2nd hand already cost more than 1k, huh? Confirmed no "carrot chop" coz repaired at good friend's workshop. Unless my good friend "chopped" me. Link to post Share on other sites More sharing options...
Windwaver Turbocharged June 19, 2012 Author Share June 19, 2012 What's the total mileage of your ride before the alternator gave way? Link to post Share on other sites More sharing options...
Kia0042 2nd Gear June 19, 2012 Share June 19, 2012 What's the total mileage of your ride before the alternator gave way? Me? around 100k, I am a "heavy duty" user, my ride travels 30k-40k KM per year, I changed my 3rd battery and had my left drive axel replaced last month . Link to post Share on other sites More sharing options...
Windwaver Turbocharged June 19, 2012 Author Share June 19, 2012 Me? around 100k, I am a "heavy duty" user, my ride travels 30k-40k KM per year, I changed my 3rd battery and had my left drive axel replaced last month . OK, that's reasonable I think. Mine failed before 20K :angry: Link to post Share on other sites More sharing options...
Fcw75 Hypersonic June 19, 2012 Share June 19, 2012 Actually battery indicator lights up doesn't mean battery weak, more like alternator not working liao. Which workshop asked you to change battery? What is your car model? Only less than 20K alternator spoiled? Link to post Share on other sites More sharing options...
Windwaver Turbocharged June 19, 2012 Author Share June 19, 2012 Actually battery indicator lights up doesn't mean battery weak, more like alternator not working liao. Which workshop asked you to change battery? What is your car model? Only less than 20K alternator spoiled? 2nd family car, kia loh but kind of weird cos my dad's korean ride didn't give him problem even after 5 years. Link to post Share on other sites More sharing options...
Mcf777 Turbocharged June 19, 2012 Share June 19, 2012 My alternator died. Cost of the alternator almost S$1.6K! PLus others parts, total about S$2k. my car now like brand new. changed so many worn-out parts within 1year A) whole steering gear (1 of the joint broke and leaking oil) B) Left/Right control arm C) All the 4 suspension D) Master brake system (no brake at all) E) All 4 brakes pads and Rotors F) Left/Right engine mounting Link to post Share on other sites More sharing options...
Windwaver Turbocharged June 19, 2012 Author Share June 19, 2012 My alternator died. Cost of the alternator almost S$1.6K! PLus others parts, total about S$2k. my car now like brand new. changed so many worn-out parts within 1year A) whole steering gear (1 of the joint broke and leaking oil) B) Left/Right control arm C) All the 4 suspension D) Master brake system (no brake at all) E) All 4 brakes pads and Rotors F) Left/Right engine mounting Is that like after 5 years? Link to post Share on other sites More sharing options...
Windwaver Turbocharged June 19, 2012 Author Share June 19, 2012 Bump for those who have similar problems Link to post Share on other sites More sharing options...
Mcf777 Turbocharged June 19, 2012 Share June 19, 2012 7yrs old. 1st time change alternator, brake system, steering gear and suspension. Link to post Share on other sites More sharing options...
Windwaver Turbocharged June 19, 2012 Author Share June 19, 2012 (edited) 7yrs old. 1st time change alternator, brake system, steering gear and suspension. I see, 7 years quite worth it liao but having said that, you car really like almost new Edited June 19, 2012 by Windwaver Link to post Share on other sites More sharing options...
Windwaver Turbocharged June 19, 2012 Author Share June 19, 2012 I see. My mileage is not even 20K, does a alternator fail that easily? BTW, other than alternator and fuse failing, what other things can cause the batter indicator to light up? Wiring? My timing belt still running fine so maybe not that. Link to post Share on other sites More sharing options...
Windwaver Turbocharged June 19, 2012 Author Share June 19, 2012 BTW, other than alternator and fuse failing, what other things can cause the batter indicator to light up? Wiring? My timing belt still running fine so maybe not that. Bump bump Link to post Share on other sites More sharing options...
Windwaver Turbocharged June 19, 2012 Author Share June 19, 2012 BTW, other than alternator and fuse failing, what other things can cause the batter indicator to light up? Wiring? My timing belt still running fine so maybe not that. Bump again Link to post Share on other sites More sharing options...
Adrianli Hypersonic June 20, 2012 Share June 20, 2012 Bump again What has timing belt got to do with alternator??? ↡ Advertisement Link to post Share on other sites More sharing options...
My EV journey to the i4
Battery for Honda Vezel
