Yewheng Twincharged April 1, 2013 Share April 1, 2013 (edited) I'm still confused. I am thinking of doing the engine flush for the next servicing package coz just got a second hand car. I see terms like engine flush + treatment, fuel Additives + Fuel Injector + System Cleaner. Are they all the same meaning of engine flushing? Some bros mentioned use mineral oil n run for certain km, then change oil again. I mean, for layman like us, we dun know how to DIY, n I dun think the workshops advise or do this for us. We only go for our regular servicing with or without engine flush. So, in conclusion, experts pls give correct advise. Thank u very much! Ok, Engine flush is using a chemical that can clean engine but at same time can also clean off seals that causes leakage. Excessive dirty particles that is inside engine oil if use engine flush may cause the dirt particles to get stuck at joint opening. Think of it this way, the slump is at the side of the pipe, if using chemical to remove the slump, the slump yes will come out but where else can the slump run to?? End up it get stuck somewhere further and accumulate a lot that can choke the pipe. ( In layman term ) . Fuel injector + system cleaner is a liquid that is poured to petrol tank that clean up fuel system. But than again it is quite useless as everytime top up petrol finish will close back and as long as got constantly top up petrol, there is no issue here of tank being rusty, dirty etc. Mineral oil is a cheaper oil as compared to syntactic oil and will lose it effectiveness at 5000 km. And people recommend using mineral oil to run for a few hundred km than go back drain off the mineral oil and top up with syntactic oil according to one preference on which brand driver want to use is because by running for a few hundred km on clean oil, hopefully some dirt particles can come out drain off together with the mineral oil when doing oil change after running few hundred km and thus clean the engine. If you regularly go for servicing there is no need to be so ma fan, just go with the normal servicing package can already. [laugh] Edited April 1, 2013 by Yewheng ↡ Advertisement 3 Link to post Share on other sites More sharing options...
Earthboy 4th Gear April 1, 2013 Share April 1, 2013 I'm still confused. I am thinking of doing the engine flush for the next servicing package coz just got a second hand car. I see terms like engine flush + treatment, fuel Additives + Fuel Injector + System Cleaner. Are they all the same meaning of engine flushing? Some bros mentioned use mineral oil n run for certain km, then change oil again. I mean, for layman like us, we dun know how to DIY, n I dun think the workshops advise or do this for us. We only go for our regular servicing with or without engine flush. So, in conclusion, experts pls give correct advise. Thank u very much! just tell them you dont want to flush any s--t. just do EO change with new filter. Link to post Share on other sites More sharing options...
Yewheng Twincharged April 1, 2013 Share April 1, 2013 just tell them you dont want to flush any s--t. just do EO change with new filter. [laugh] Link to post Share on other sites More sharing options...
Mockngbrd Supersonic April 1, 2013 Share April 1, 2013 just keep changing oil la.... flush engine is flush ur $$$ away only Link to post Share on other sites More sharing options...
Yrvsport 2nd Gear April 1, 2013 Share April 1, 2013 Juz follow the simple step..change every 5k or 10k...that's all..flushing juz to make ur engine damage for the long run... Link to post Share on other sites More sharing options...
Boi2uncle 2nd Gear April 1, 2013 Share April 1, 2013 What about those new technologies that use gas to clean out the sludge? Any gurus here can share their views? Link to post Share on other sites More sharing options...
Relagsingh 4th Gear April 1, 2013 Share April 1, 2013 I remember my 1st service experience when I saw how they do engine flush. During then my job was working on marine engines and generators. When I asked the mechanic whether is that how they do it, they sell koyo until very song and he said everywhere does it the same way. From then on, f**k engine flush. Link to post Share on other sites More sharing options...
Earthboy 4th Gear April 1, 2013 Share April 1, 2013 [laugh] my answer easier than yours right? Link to post Share on other sites More sharing options...
Moredhel 2nd Gear April 1, 2013 Share April 1, 2013 What about those new technologies that use gas to clean out the sludge? Any gurus here can share their views? Drain oil and then pump magic gas into the engine parts? How to run the engine without lubrication? Link to post Share on other sites More sharing options...
Johnnylim 5th Gear April 1, 2013 Share April 1, 2013 Ok, Engine flush is using a chemical that can clean engine but at same time can also clean off seals that causes leakage. Excessive dirty particles that is inside engine oil if use engine flush may cause the dirt particles to get stuck at joint opening. Think of it this way, the slump is at the side of the pipe, if using chemical to remove the slump, the slump yes will come out but where else can the slump run to?? End up it get stuck somewhere further and accumulate a lot that can choke the pipe. ( In layman term ) . Fuel injector + system cleaner is a liquid that is poured to petrol tank that clean up fuel system. But than again it is quite useless as everytime top up petrol finish will close back and as long as got constantly top up petrol, there is no issue here of tank being rusty, dirty etc. Mineral oil is a cheaper oil as compared to syntactic oil and will lose it effectiveness at 5000 km. And people recommend using mineral oil to run for a few hundred km than go back drain off the mineral oil and top up with syntactic oil according to one preference on which brand driver want to use is because by running for a few hundred km on clean oil, hopefully some dirt particles can come out drain off together with the mineral oil when doing oil change after running few hundred km and thus clean the engine. If you regularly go for servicing there is no need to be so ma fan, just go with the normal servicing package can already. [laugh] Thks very much for the so detailed explanation! Thks also to all the other bros for their short n sharp answers! That's why I love this forum. Link to post Share on other sites More sharing options...
C-K 2nd Gear April 1, 2013 Share April 1, 2013 For old car, try this. Much better than any engine flush in the market: Link to post Share on other sites More sharing options...
Adawang 1st Gear April 1, 2013 Share April 1, 2013 engine flush is to make your clean engine cleaner. However, if yr engine is DIRTY, do not attempt to flush it. It can be a DISASTER. If engine is clean ,theres no need to flush. If engine is dirty, see above quote Link to post Share on other sites More sharing options...
Fredhilman Neutral Newbie May 25, 2013 Share May 25, 2013 I do my general engine repairs by myself and replace its oil on a periodic basis that gives me more power output which keeps my car as new. Such tips effectively help me to flush my engine that I have found with http://www.hiperformer.com/engine_basics page where experts have provided all essential engine DIY guidelines. Link to post Share on other sites More sharing options...
Baal Supersonic February 6, 2014 Share February 6, 2014 I think when your engine is pretty clean, flushing won't cause much problem. But then, if it's pretty clean, then no point flushing. What's more important is regular engine oil change and to utilise your car regularly. The most missed point about engine oil change in Singapore is, most don't clock the extended interval of 15/20K or even 30K within 6 months, and most motorists change engine oil only in accordance to distance clocked, and not distance clocked OR 6 months whichever comes first. I saw that car lube sells a flush for like <$10. Says -Pour into engine oil sump, and let idle for 10-20 mins - do not drive the car as will heat up very fast Hence, I thought, next round, I drive to ws, park somewhere near, & do the above......then let the are "creep" in D mode to ws & change eo as per normal. From what I read from this thread, don't seem like a good idea... Link to post Share on other sites More sharing options...
Kangadrool Supersonic February 6, 2014 Share February 6, 2014 I saw that car lube sells a flush for like <$10. Says -Pour into engine oil sump, and let idle for 10-20 mins - do not drive the car as will heat up very fast Hence, I thought, next round, I drive to ws, park somewhere near, & do the above......then let the are "creep" in D mode to ws & change eo as per normal. From what I read from this thread, don't seem like a good idea... it's never a good idea to flush. Link to post Share on other sites More sharing options...
Kb27 Supersonic February 6, 2014 Share February 6, 2014 I saw that car lube sells a flush for like <$10. Says -Pour into engine oil sump, and let idle for 10-20 mins - do not drive the car as will heat up very fast Hence, I thought, next round, I drive to ws, park somewhere near, & do the above......then let the are "creep" in D mode to ws & change eo as per normal. From what I read from this thread, don't seem like a good idea... Yeap, not a good idea. Flush are usually solvent. Solvent does not lubricate, it dissolves. That's why you have to get it out of the oil system. If the engine had crud and sludge along small oil lines and it dislodged with a power flush, that will block oil from moving and starve the engine of lubrication and oil cooling. The gentle, albeit longer way of cleaning is simply use high quality detergent engine oil, which most branded engine oil already are; some with more cleaning power, some less. Change out oil more often and you're cleaning it at the same time. 1 Link to post Share on other sites More sharing options...
Baal Supersonic February 6, 2014 Share February 6, 2014 Yeap, not a good idea. Flush are usually solvent. Solvent does not lubricate, it dissolves. That's why you have to get it out of the oil system. If the engine had crud and sludge along small oil lines and it dislodged with a power flush, that will block oil from moving and starve the engine of lubrication and oil cooling. The gentle, albeit longer way of cleaning is simply use high quality detergent engine oil, which most branded engine oil already are; some with more cleaning power, some less. Change out oil more often and you're cleaning it at the same time. In this case, which u think is a better idea. Based on 13k /yr mileage. ? a) Use CL, change every 6 mths b) Use Mobil1/Agip/Helix Ultra change once a yr Link to post Share on other sites More sharing options...
Knoobie Supercharged February 6, 2014 Share February 6, 2014 In other words, the best way to clear slumps in your engine is to strip it down and clear it using petrol right? ↡ Advertisement Link to post Share on other sites More sharing options...
Engine Mounting
Engine Mounting
SCHNELL Engine Oil 5W40
