inlinesix Hypersonic January 7, 2018 Share January 7, 2018 that's 1:450 very far from getting a smoking/wet pipe ↡ Advertisement Link to post Share on other sites More sharing options...
Ivan_06 5th Gear January 7, 2018 Share January 7, 2018 at the end of the day what qualitative gain are there? engine flush or not add cleaner additives or not with or without both cars still run until scrap the added expenses is it worth it? is it for most of us it is often a mental feel goodis exercise I think most are device by entrepreneurs My previous ride, Toyota vios, drove till last 9.5 years, fc still damn good. Never flushed at all. 15km/l... Fuel simi. Waste money. 2 Link to post Share on other sites More sharing options...
Sdf4786k Twincharged January 7, 2018 Share January 7, 2018 My previous car. I knew a driver whose car had an engine which I think was the same as mine. He used a very popular engine oil and added an engine oil additive. He had very good FC. He also had a "golden" engine caused by varnish. I had used the same popular engine oil before. I had mild varnish which was detected from my "golden" dipstick. It eventually went away. I used to have varnish, slight sludging, dirty throttle body (every 30-40k) and leaky engine top cover. . I contemplated to use engine flush to do some cleaning. Eventually, after much experiment, I did not need to. This is what I did :- Every tank I use a fuel with PEA. Every 5000km, I use a PEA based fuel system cleaner. Evert 10,000km, I use an ester based engine oil which has good cleaning properties. Just to add, I recall any driver who also had a "golden" dipstick. The issue went away because he used a pureplus engine oil which has good cleaning properties. can share whats a pureplus engine oil and what brand are those? I only know previous a certain racing engine oil had a bad reputation of causing oil gasket failure. But they have since improved on it. Link to post Share on other sites More sharing options...
Kklee 6th Gear January 7, 2018 Share January 7, 2018 can share whats a pureplus engine oil and what brand are those? I only know previous a certain racing engine oil had a bad reputation of causing oil gasket failure. But they have since improved on it. AFAIK, pureplus engine oil are derived from natural gas. The brands I know are Shell Helix Ultra and Pennzoil. They have pureplus on the bottle. Which brand is the racing engine oil ? Depending on the application, racing EO have less or no detergent. My previous ride, Toyota vios, drove till last 9.5 years, fc still damn good. Never flushed at all. 15km/l... Fuel simi. Waste money. What's your mileage at the end? Link to post Share on other sites More sharing options...
Ivan_06 5th Gear January 7, 2018 Share January 7, 2018 AFAIK, pureplus engine oil are derived from natural gas. The brands I know are Shell Helix Ultra and Pennzoil. They have pureplus on the bottle. Which brand is the racing engine oil ? Depending on the application, racing EO have less or no detergent. What's your mileage at the end? 150k Link to post Share on other sites More sharing options...
Kklee 6th Gear January 7, 2018 Share January 7, 2018 150k Alrite, thanks for the info. Link to post Share on other sites More sharing options...
aspirin_666 January 15, 2018 Share January 15, 2018 Don't waste $$$. Even if previous owner drag the maintenance interval, just fill up with mineral oil and run for 1K, drain off and repeat until you song. It is reasonable. 1 Link to post Share on other sites More sharing options...
Terratoss 1st Gear February 4, 2018 Share February 4, 2018 Hi all, i saw that some have mentioned about using mineral oil to run for 1000km to clean the engine. May I know what brand and weight do you use? I saw on lazada msia only got 10w-30 or 20w-50. Link to post Share on other sites More sharing options...
Jamesc Hypersonic February 4, 2018 Share February 4, 2018 Hi all, i saw that some have mentioned about using mineral oil to run for 1000km to clean the engine. May I know what brand and weight do you use? I saw on lazada msia only got 10w-30 or 20w-50. That's the correct way to clean your engine. Weight should be specified in your owners manual. Link to post Share on other sites More sharing options...
inlinesix Hypersonic February 5, 2018 Share February 5, 2018 Hi all, i saw that some have mentioned about using mineral oil to run for 1000km to clean the engine. May I know what brand and weight do you use? I saw on lazada msia only got 10w-30 or 20w-50.No need la. Just do oil change at 1k km will be enough Link to post Share on other sites More sharing options...
Terratoss 1st Gear February 5, 2018 Share February 5, 2018 (edited) No need la. Just do oil change at 1k km will be enough haha.. full syn oil change at every 1k km? like that even if i buy turtle oil also quite ex u know. That's the correct way to clean your engine. Weight should be specified in your owners manual. thks for the tip. just that i did read if XXw-50 oil might hurt non-mod/high performance engines? Edited February 5, 2018 by Terratoss Link to post Share on other sites More sharing options...
Vinceng Turbocharged February 14, 2018 Share February 14, 2018 (edited) You don't need a flush if you have been using good quality synthetic oil. Take a look at what happen after using Pennzoil Ultra for 1000 mile, works as advertised. http://www.youtube.com/user/Arctic388/videos And any brand of engine oil is good enough - no need to get branded ones. Engine oil all come from the same source. German made Schnell at $30 for 4 litres is good enough. better to use this cheap engine oil and change every 5,000km, than to use an expensive branded engine oil like Mobil 1 that costs almost triple the price and change oil every 10,000km. Edited February 14, 2018 by Vinceng Link to post Share on other sites More sharing options...
BoRui2014 1st Gear February 14, 2018 Share February 14, 2018 And any brand of engine oil is good enough - no need to get branded ones. Engine oil all come from the same source. German made Schnell at $30 for 4 litres is good enough. better to use this cheap engine oil and change every 5,000km, than to use an expensive branded engine oil like Mobil 1 that costs almost triple the price and change oil every 10,000km. I half agree bro. I agree that changing oil often makes a significant difference. In Taiwan, they change oil every 4000-5000km, even if they are using synthetic. That's why their cars can still be running smoothly after 20 years (we only need 10 years though). As for oil source... Lubricants got two main components - base oil and additives. Two oils can be fully synthetic (dependent on base-oil), and cost can still be dramatically different because of the additives used. And because different additives have a different make-up of materials, the wrong additives can damage your car. If you are driving an Asian make, still not so bad. But if you are driving Conti, best to check for the various approval ratings on the oil. Got difference one. If you try Brand X and it seems fine for a few months, that's normal, because damage only surfaces years after. And the costs incurred due to engine damage a bit hard to project, if not can do a comparison to see whether the pros outweigh the cons. My take is that it's most important that my car can reliably start and go as and when I need it to. Otherwise, I wouldn't have plonked in the money to get one, but just Grab or Uber all the way. Link to post Share on other sites More sharing options...
Spinelli_ck 6th Gear February 14, 2018 Share February 14, 2018 Hi all, i saw that some have mentioned about using mineral oil to run for 1000km to clean the engine. May I know what brand and weight do you use? I saw on lazada msia only got 10w-30 or 20w-50. i used an inexpensive Mobil mineral oil for this purpose. the oil's viscosity to use is largely dependent on the type of engine you have. Link to post Share on other sites More sharing options...
RogerNg_185295 6th Gear February 14, 2018 Share February 14, 2018 Why is there a vast difference in prices between Shell oil sold in Giant and official distributors? Is it because of the additives used? I half agree bro. I agree that changing oil often makes a significant difference. In Taiwan, they change oil every 4000-5000km, even if they are using synthetic. That's why their cars can still be running smoothly after 20 years (we only need 10 years though). As for oil source... Lubricants got two main components - base oil and additives. Two oils can be fully synthetic (dependent on base-oil), and cost can still be dramatically different because of the additives used. And because different additives have a different make-up of materials, the wrong additives can damage your car. If you are driving an Asian make, still not so bad. But if you are driving Conti, best to check for the various approval ratings on the oil. Got difference one. If you try Brand X and it seems fine for a few months, that's normal, because damage only surfaces years after. And the costs incurred due to engine damage a bit hard to project, if not can do a comparison to see whether the pros outweigh the cons. My take is that it's most important that my car can reliably start and go as and when I need it to. Otherwise, I wouldn't have plonked in the money to get one, but just Grab or Uber all the way. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear February 14, 2018 Share February 14, 2018 Why is there a vast difference in prices between Shell oil sold in Giant and official distributors? Is it because of the additives used? i think no one can prove this about the addictives. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear February 14, 2018 Share February 14, 2018 i think no one can prove this about the addictives. found an interesting video. does that mean that we use cheap oil our oil filter are like that? So far i didnt see this happening when we buy promo engine oil and used it. https://youtu.be/SgvC1S3ULOo Link to post Share on other sites More sharing options...
BoRui2014 1st Gear February 14, 2018 Share February 14, 2018 i think no one can prove this about the addictives. Sometimes this happens because of parallel imports in large quantities. Often times dealers (local and overseas) and distributors have 'quota' to meet. In the event that they cannot sell enough, they release the goods to willing buyers (usually overseas) in bulk. In order to achieve this, they sell mostly to break even, so it's substantially cheaper. Then the local buyer/parallel importer sells these in bulk to Giant and/or other supermarkets at a cheap price, so that they would move, making a small profit. ↡ Advertisement Link to post Share on other sites More sharing options...
Engine Mounting
Engine Mounting
SCHNELL Engine Oil 5W40
