Home aircon not cold..
Blackyv
I like to set to 26 for aircon with a fan blowing at me, not rotating.. just nice, not too cold, not too hot...... [:p]
Thought the normal night time room temperature is around 24-26 degree at night, need air con meh?
Twincharged
I have no air con. [bigcry]
I do not even have bloody fan!
Anyway, aircon switch on too long not very good leh. Cause too dry. Maybe open windows a bit.
Just a question, what you guys think is a comfortable room temperature at night?
I always set my aircon at around 16-18. But the fan not blowing directly at me.
25 deg c
do u know u are using aircon unit to cool down the air then use fan to heat up the air again?
a/c also serves to dehumidify the air. SG's night air humidity is about 80% and beyond at night. Comfortable range is between 55% to 65%.
23 deg C.
SG night room temp where got 24-26 deg C? its usually 28-29 deg C. on some really hot months can even go up to 30 deg C.
I think air cond servicing is another one of those carrot jobs that charges very high
I understand if keep filter clean and pipe clear is good enough
My previous Toshiba system 3 aircon has 2 small compressor.
One compressor for materroom unit, the others 2 room unit share 1 compressor.
I've got the same issue 2 weeks back..
What i did was clear the dust from the filter and vaccum the fins of the blower and the cold air came back.
Try it before calling for service.
Ummm... then there is a chance the compressor kaput hor.... will check it out later....
I did that regularly and nope, didn't work this round... it's not as simple as a dirty blower.. the air out is like any air from a fan.. not a slight feel of coldness... even at 18deg...
If yours is a old unit, you might like to consider to change a new one that has higher Hp and lower ele consuption. Sg is getting warmer and wamer.
5yrs old only... very new still....
Yes, I think Tohto is right. Inside the compressor there are 2 motors.
My master room also no aircon. All others are still working fine. To change will be big construction as all pipes are inside the wall. [:(]
Edited by Ben5266
