Phluvcat 6th Gear August 28, 2012 Share August 28, 2012 Dear all these few days I noticed that when I step on the gas, the handbrake light will come on. It will go off after awhile when I am on very very light throttle and just coasting. It will turn off when I brake. Check handbrake is fully down when that happens. Could it be the brake assembly is stuck? Need some experience and advice please. Thanks and regards. ↡ Advertisement Link to post Share on other sites More sharing options...
Kwanheng 1st Gear August 28, 2012 Share August 28, 2012 Dear all these few days I noticed that when I step on the gas, the handbrake light will come on. It will go off after awhile when I am on very very light throttle and just coasting. It will turn off when I brake. Check handbrake is fully down when that happens. Could it be the brake assembly is stuck? Need some experience and advice please. Thanks and regards. bring to work shop check. no point asking here. Link to post Share on other sites More sharing options...
Prostcode Clutched August 28, 2012 Share August 28, 2012 top up brake fluid. Link to post Share on other sites More sharing options...
Paddie 3rd Gear August 28, 2012 Share August 28, 2012 Brake fluid level low. Link to post Share on other sites More sharing options...
Yewheng Twincharged August 28, 2012 Share August 28, 2012 Brake fluid level low. Brake fluid level low could mean brake pad is going to finish. Link to post Share on other sites More sharing options...
Phluvcat 6th Gear August 28, 2012 Author Share August 28, 2012 Thanks Prostcode, Paddie and Yewheng. Link to post Share on other sites More sharing options...
Yewheng Twincharged August 28, 2012 Share August 28, 2012 Thanks Prostcode, Paddie and Yewheng. But if really brake fluid low, 1st thing to check is brake pad and whether any leakage at the brake fluid. As far as possible try not to top up brake fluid when it is low level as some cars equipped with sensors that detect low brake fluid and send warning message to check brake pad. Link to post Share on other sites More sharing options...
WTF 4th Gear August 28, 2012 Share August 28, 2012 Same thing happened to me yesterday when suddenly rain heavily as I ran to my car to take shelter........then found how come car move sluggishly when stepped on gas.......then discovered forgotten to release the handbrake....... Link to post Share on other sites More sharing options...
5936 1st Gear August 28, 2012 Share August 28, 2012 Luckily handbrake or parking brake is not over infested with electronics. My guess will be borderline low brake fluid. Link to post Share on other sites More sharing options...
Mlimhs 1st Gear August 29, 2012 Share August 29, 2012 Most probably brake fluid. Just top up ok liao. Your case was similar to mine. Link to post Share on other sites More sharing options...
Kb27 Supersonic August 29, 2012 Share August 29, 2012 Check rear drum brakes. Brake piston leaking fluid is common. Link to post Share on other sites More sharing options...
Phluvcat 6th Gear August 30, 2012 Author Share August 30, 2012 mine is 16 year old civic so should not be other electronic complication other than brake fluid as advised by some bros. ya front and back all disc brake. to play safe, topped up the brake fluid when I pump petrol this evening, no more handbrake light abnormality liao. tomorrow going for my servicing at about 7800km, just to make sure everything is alright, anyway car already felt sluggish and probably bushing not in good condition, right rear camber also more than the rest of the tyres. Thanks all for the advice siah. Link to post Share on other sites More sharing options...
Phluvcat 6th Gear August 30, 2012 Author Share August 30, 2012 Same thing happened to me yesterday when suddenly rain heavily as I ran to my car to take shelter........then found how come car move sluggishly when stepped on gas.......then discovered forgotten to release the handbrake....... haha what distance you drove with ur handbrake engaged? Link to post Share on other sites More sharing options...
Phluvcat 6th Gear August 30, 2012 Author Share August 30, 2012 Luckily handbrake or parking brake is not over infested with electronics. My guess will be borderline low brake fluid. below min line liao...going for early servicing tomorrow, I still value my life ler... Link to post Share on other sites More sharing options...
Gjkelvin Neutral Newbie August 30, 2012 Share August 30, 2012 I had this problem previously... Found out to be worn out brake pad... Link to post Share on other sites More sharing options...
Sga54g 1st Gear August 30, 2012 Share August 30, 2012 Same thing happened to me yesterday when suddenly rain heavily as I ran to my car to take shelter........then found how come car move sluggishly when stepped on gas.......then discovered forgotten to release the handbrake....... I often forgot to release the handbrake... Good thing car got sensor that beeps! Link to post Share on other sites More sharing options...
Phluvcat 6th Gear August 31, 2012 Author Share August 31, 2012 (edited) Hahaha at the garage now, right rear brake pump leak and bushing chui, camber out. Edited August 31, 2012 by Phluvcat Link to post Share on other sites More sharing options...
Phluvcat 6th Gear September 2, 2012 Author Share September 2, 2012 The mechanic "upgraded" my rear upper arms to a pair of secondhand after-market ones. Hopefully good riddance to PU bushings which had been giving me problems. Luckily that day at the garage, brake pump and upper arms all got second hand ones. ↡ Advertisement Link to post Share on other sites More sharing options...
Accident with step ladder, safety concern
Quad Light Bulb Size
P2096 Check engine light
