Keen 1st Gear December 29, 2012 Share December 29, 2012 Due for my shock absorber change, wondering if its necessary to change stopper and mounting together? ↡ Advertisement Link to post Share on other sites More sharing options...
Pisces69 6th Gear December 29, 2012 Share December 29, 2012 Due for my shock absorber change, wondering if its necessary to change stopper and mounting together? U can remove shocks then chk stopper n mounts fr wear. I usually change stopper cos its cheap. Mount usually can last 10yrs. Remember to do a 4 wheel computerised alignment to get everything back to factory specs even if e mech say no need. Good alignment improves handling n roadholding n yr tires wil last much longer. Link to post Share on other sites More sharing options...
Furrynadz 5th Gear December 29, 2012 Share December 29, 2012 everything mount+stopper+bearing+bolts compressed mounts n bearings will cause premature failure of new absorber as its not in the correct aligned position Link to post Share on other sites More sharing options...
ER-3682 Supersonic December 29, 2012 Share December 29, 2012 Usually for my car,always the stopper wear out first,but in the end changed both the stopper & the shock absorbers,because mechanic said stopper is very cheap,but the labour is more,so not worth changing the stoppers only. Link to post Share on other sites More sharing options...
Keen 1st Gear January 3, 2013 Author Share January 3, 2013 thanks for the reply! Will change mounting, stopper and absorber together. Bearing? As in wheel bearing? Link to post Share on other sites More sharing options...
Keen 1st Gear January 3, 2013 Author Share January 3, 2013 Must do alignment after changing absorber right? any recommendation around ubi area that do wheel alignment? Approx how much ar? Link to post Share on other sites More sharing options...
Louiscyr 2nd Gear January 3, 2013 Share January 3, 2013 hi guys, my rear shock is a bit soft, thinking of sending it for a check, can i know where is recommended for nissan sylphy? Link to post Share on other sites More sharing options...
Tohto Hypersonic January 4, 2013 Share January 4, 2013 Must do alignment after changing absorber right? any recommendation around ubi area that do wheel alignment? Approx how much ar? Drive for about 2 weeks to let it settle down 1st before do alignment. Link to post Share on other sites More sharing options...
Kwanheng 1st Gear January 4, 2013 Share January 4, 2013 hi guys, my rear shock is a bit soft, thinking of sending it for a check, can i know where is recommended for nissan sylphy? any workshop can do the check, just use hand to feel can already. if u want to be sure, try going over 2 hump with pax. first bounce should be fine, 2nd bounce if you hear the knocking sound means rear shocks gone Link to post Share on other sites More sharing options...
Louiscyr 2nd Gear January 6, 2013 Share January 6, 2013 any workshop can do the check, just use hand to feel can already. if u want to be sure, try going over 2 hump with pax. first bounce should be fine, 2nd bounce if you hear the knocking sound means rear shocks gone ok confirmed gone liao.. first bounce already hit the hump.. :( anyway its an old car so will be getting it changed. Link to post Share on other sites More sharing options...
Forte3737 5th Gear January 6, 2013 Share January 6, 2013 Due for my shock absorber change, wondering if its necessary to change stopper and mounting together? Its only when the workshop inspect and take out the suspension, Then you will know what to change Link to post Share on other sites More sharing options...
Furrynadz 5th Gear January 6, 2013 Share January 6, 2013 thanks for the reply! Will change mounting, stopper and absorber together. Bearing? As in wheel bearing? in addition to absorbers front: suspension top mount, suspension bearing, suspension rest cup, suspension stopper rear : suspension rear top mount, stopper ↡ Advertisement Link to post Share on other sites More sharing options...
Tool to change Spark Plug
Change Disc Rotors
Change Disc Rotors
