ER-3682 Supersonic February 2, 2013 Share February 2, 2013 Hi friends/forumers,i would like to use 5w-20 Motul 300v 100% Syn oil on my new car,anybody use 5w-20 oil before,it is really very good.? ↡ Advertisement Link to post Share on other sites More sharing options...
Ilmw 1st Gear February 2, 2013 Share February 2, 2013 Hi friends/forumers,i would like to use 5w-20 Motul 300v 100% Syn oil on my new car,anybody use 5w-20 oil before,it is really very good.? honda civic 1.8 2007. default is to use 5w-30, cos almost everyone is using that. not bad, nothing fantastic to talk abt - not good not bad. at that time, car engine also new, so a bit rough (engine block fresh cut from factory) is to be expected. after a year or two, i discover my colleague, due to save petrol, uses 5w-20. i think why not, so use. wow. much better. smooth. people say, as cars get older, use thicker oil, like 5w-40 or 5w-50 as gaps in engine grow. bec of this, every now and then, i switch back to 5w-30. yucks. next round, i go back to 5w-20. shiok. i use redline since day 1. everyone say motul is better, but i doubt it is worth the cost difference. my 2 cents. Link to post Share on other sites More sharing options...
Gobbler Clutched February 2, 2013 Share February 2, 2013 using amsoil asm 0w20 for past 6 yrs Link to post Share on other sites More sharing options...
Jamesc Hypersonic February 2, 2013 Share February 2, 2013 Redline is ester oil so the 5W-20 gives as much protection as other normal 5W-30 oils. Link to post Share on other sites More sharing options...
Aloytryp Neutral Newbie February 2, 2013 Share February 2, 2013 Engine will be noise and not suitable for long distance driving. Link to post Share on other sites More sharing options...
PaulMeng 2nd Gear February 2, 2013 Share February 2, 2013 Redline 5W-20 !! BEST !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Link to post Share on other sites More sharing options...
Celicar Turbocharged February 2, 2013 Share February 2, 2013 Wah, use so thin oil? Mileage how much? If high mileage better use thicker, I think. Link to post Share on other sites More sharing options...
Mits_jc 5th Gear February 2, 2013 Share February 2, 2013 so long as your car does not consume engine oil, w20 oil can be used without any issues. Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged February 2, 2013 Share February 2, 2013 Hi friends/forumers,i would like to use 5w-20 Motul 300v 100% Syn oil on my new car,anybody use 5w-20 oil before,it is really very good.? I have been using 0w20, 5w20, 5w30 on current car since day one. Last oil change at 69000km, I used 0w20.. So far no engine oil consumption problem. My manual spec specifies 5w30 as minimum though. The car is a 1.5l japanese non turbo car. Just to state, for the previous w20 oil, they are Redline, Amsoil and current 0w20 is Renewable Lube. I didn't use Motul or Mobil. Link to post Share on other sites More sharing options...
ER-3682 Supersonic February 2, 2013 Author Share February 2, 2013 Thanks guys,i will try it on my 1K km,1 st service.... Link to post Share on other sites More sharing options...
Aaronlkl Supersonic February 2, 2013 Share February 2, 2013 Thanks guys,i will try it on my 1K km,1 st service.... U not using this grade on a performance vehicle aren't u? Link to post Share on other sites More sharing options...
Pureness Clutched February 2, 2013 Share February 2, 2013 for anybody who is interested to try, my advise is to drop by 1 grade intervals so from 40 go to 30 then finally to 20 Link to post Share on other sites More sharing options...
ER-3682 Supersonic February 3, 2013 Author Share February 3, 2013 U not using this grade on a performance vehicle aren't u? Not on my 370z,but on my new Mazda 6. Link to post Share on other sites More sharing options...
KaKiLang 4th Gear February 3, 2013 Share February 3, 2013 Been using 0-20 fuchs, double easter base on my 9yrs civic no issue, did a rebuild last year @2200000 nothing change engine still tip top, never need to top up either. Link to post Share on other sites More sharing options...
Deckbuild 6th Gear February 4, 2013 Share February 4, 2013 Bought 4 bottles of 0w20 Royal Purple for my Prius C, yet to use them as still on free servicing. Link to post Share on other sites More sharing options...
Deckbuild 6th Gear February 4, 2013 Share February 4, 2013 Been using 0-20 fuchs, double easter base on my 9yrs civic no issue, did a rebuild last year @2200000 nothing change engine still tip top, never need to top up either. 220k km sibo, 2.2M KM sounds super lot Link to post Share on other sites More sharing options...
Robin 4th Gear February 4, 2013 Share February 4, 2013 what car u driving? consult yr driver manual to see if 5w-20 is suitable if yr car got forced induction, then 5w-20 is too thin. If NA, still ok Link to post Share on other sites More sharing options...
ER-3682 Supersonic February 4, 2013 Author Share February 4, 2013 what car u driving? consult yr driver manual to see if 5w-20 is suitable if yr car got forced induction, then 5w-20 is too thin. If NA, still ok NA,i think 5w-20 not a problem. ↡ Advertisement Link to post Share on other sites More sharing options...
Iceland : Has anybody driven in Iceland before?
How are you using the SkillsFuture?
Using blower to dry car
Anybody know what happened eventually?
CPU chip - What are you using? Intel or AMD?
56 Delightful Victorian Slang Terms You Should Be Using
Who Still using STP Oil Treatment?
Anybody bought those portable car washer
