Stratovarius Turbocharged April 4, 2013 Share April 4, 2013 As topic. This morning found out that my car battery is totally flat. Can't even unlock door using remote. My batt is more than 2 yrs but the cranking sounded normal when i last drove it. i normally leave the car camera plugged into the lighter socket, could this be a reason why the batt is totally drained? Or could it be the alternater issue? ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Strat 6th Gear April 4, 2013 Share April 4, 2013 is your car dvr running 24/7 even when the car is off? Link to post Share on other sites More sharing options...
Weewee1976 3rd Gear April 4, 2013 Share April 4, 2013 is your car dvr running 24/7 even when the car is off? To be exact, is TS car's cigarette lighter socket's power running 24x7 even when the car is turned off? 1 Link to post Share on other sites More sharing options...
Zapp 1st Gear April 4, 2013 Share April 4, 2013 lighter socket power will be cut off, once you turn off the engine. 1 Link to post Share on other sites More sharing options...
LoverofCar 6th Gear April 4, 2013 Share April 4, 2013 (edited) As topic. This morning found out that my car battery is totally flat. Can't even unlock door using remote. My batt is more than 2 yrs but the cranking sounded normal when i last drove it. i normally leave the car camera plugged into the lighter socket, could this be a reason why the batt is totally drained? Or could it be the alternater issue? did you check whether your lighter socket still supplying power when you shut down your car engine? some car..the lighter socket will still supply power even with engine off.......some don't.......if it cut off after engine shut down..it shouldn't be drained by the DVR. Edited April 4, 2013 by LoverofCar Link to post Share on other sites More sharing options...
HP_Lee 5th Gear April 4, 2013 Share April 4, 2013 As topic. This morning found out that my car battery is totally flat. Can't even unlock door using remote. My batt is more than 2 yrs but the cranking sounded normal when i last drove it. i normally leave the car camera plugged into the lighter socket, could this be a reason why the batt is totally drained? Or could it be the alternater issue? Normally not. The car main battery will automatically cut off supply, when you switch off the car. Unless, you wired it direct to the car battery, than it will drain off. Is advice to have a separate battery pack that wires direct to the DVR, if you need it to be recording after you have leave your car. Link to post Share on other sites More sharing options...
Joseph22 Turbocharged April 4, 2013 Share April 4, 2013 As topic. This morning found out that my car battery is totally flat. Can't even unlock door using remote. My batt is more than 2 yrs but the cranking sounded normal when i last drove it. i normally leave the car camera plugged into the lighter socket, could this be a reason why the batt is totally drained? Or could it be the alternater issue? i think about time to change. Link to post Share on other sites More sharing options...
Chiawy 1st Gear April 4, 2013 Share April 4, 2013 My car's DVR is 24/7 and the DVR got a in-built battery, think those 900mAH type and charging cable is those USB mini type, so when my engine is on, it will power and charge thru my car's USB outpput. When my car engine is off, I disconnect the charging cable and connect it to an external powerbank to continue the recording. 1 Link to post Share on other sites More sharing options...
Stratovarius Turbocharged April 4, 2013 Author Share April 4, 2013 Think no supply. The dvr will off itself after I off the engine. My thinking is if there will be small leakages through the socket? normally I use the strength of the cranking sound to gauge the life of the battery. But this time, the batt just died overnight. Or could it be the alternator? Any signs I should look out for failing alternators? Link to post Share on other sites More sharing options...
Stratovarius Turbocharged April 4, 2013 Author Share April 4, 2013 i think about time to change. No need about. Already changed. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic April 4, 2013 Share April 4, 2013 lighter socket power will be cut off, once you turn off the engine. Not all. VW will still have power, even when engine off. Link to post Share on other sites More sharing options...
Erinio Neutral Newbie April 4, 2013 Share April 4, 2013 My car's DVR is 24/7 and the DVR got a in-built battery, think those 900mAH type and charging cable is those USB mini type, so when my engine is on, it will power and charge thru my car's USB outpput. When my car engine is off, I disconnect the charging cable and connect it to an external powerbank to continue the recording. what powerbank are you using? can last how long? do you charge the powerbank with cig socket or you have 2 powerbank to swap? Link to post Share on other sites More sharing options...
Antleow Clutched April 4, 2013 Share April 4, 2013 What brand is that? My car's DVR is 24/7 and the DVR got a in-built battery, think those 900mAH type and charging cable is those USB mini type, so when my engine is on, it will power and charge thru my car's USB outpput. When my car engine is off, I disconnect the charging cable and connect it to an external powerbank to continue the recording. 1 Link to post Share on other sites More sharing options...
Maxus-MIFA9 Supersonic April 4, 2013 Share April 4, 2013 As topic. This morning found out that my car battery is totally flat. Can't even unlock door using remote. My batt is more than 2 yrs but the cranking sounded normal when i last drove it. i normally leave the car camera plugged into the lighter socket, could this be a reason why the batt is totally drained? Or could it be the alternater issue? Battery more than 2 years is as good as gone.... Normally it will last about 18 ~24 months. Link to post Share on other sites More sharing options...
LookingBusy Neutral Newbie April 4, 2013 Share April 4, 2013 Those using cig sockets one, won't the camera be turned off already when you off the engine and from there you can pluck out your sd card? Like that there won't be any battery power charging to the cam, how come the battery will drain? At least that's for my case as i use the cig socket also instead of tapping to ignition. Link to post Share on other sites More sharing options...
Cluboxed 1st Gear April 5, 2013 Share April 5, 2013 Those using cig sockets one, won't the camera be turned off already when you off the engine and from there you can pluck out your sd card? Like that there won't be any battery power charging to the cam, how come the battery will drain? At least that's for my case as i use the cig socket also instead of tapping to ignition. thats my case too...and should be the usual case i suppose... Link to post Share on other sites More sharing options...
Tarzan666 2nd Gear April 5, 2013 Share April 5, 2013 Im using a popular DVR, those can record over nite & got power saver kind. Used for 2 weeks, skali car cant start in morning, same like TS, remote also cannot work. Called the dealer..ask me how old my batt..i say 2 years..he say muz change batt, batt more than 2 years will give problem. in my mind..wah knn like dat every 2 years muz change batt if use DVR, my previous car batt last me near 4 years. Link to post Share on other sites More sharing options...
Pisces69 6th Gear April 5, 2013 Share April 5, 2013 As topic. This morning found out that my car battery is totally flat. Can't even unlock door using remote. My batt is more than 2 yrs but the cranking sounded normal when i last drove it. i normally leave the car camera plugged into the lighter socket, could this be a reason why the batt is totally drained? Or could it be the alternater issue? Ciggy lighter auto switch off when u switch off engine n remove key. I think more likely yr battery eol n needs to b changed. ↡ Advertisement Link to post Share on other sites More sharing options...
COE Bidding – Mar 2025
Car of Politician
Car of Politician
Anyone missing a car plate?
Xiaomi EV is Coming
Xiaomi EV is Coming
