Dinosaka 1st Gear April 27, 2013 Author Share April 27, 2013 (edited) Double post Edited April 27, 2013 by Dinosaka ↡ Advertisement Link to post Share on other sites More sharing options...
Dinosaka 1st Gear April 27, 2013 Author Share April 27, 2013 Hi all, Thanks for the valuable input...I will get it replace soon... Hv a nice weekend all.... Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic April 27, 2013 Share April 27, 2013 the actual tire is extremely thick, in malaysia they regroove used tires and sell as new i don't think such a small scratch will be any problem True in indon they also do the same think, when the grid no more, they regroove again to make new grid but this is not safe, higher chance tyre to explode especially heavy load or high speed Link to post Share on other sites More sharing options...
Nicholas 5th Gear April 27, 2013 Share April 27, 2013 True in indon they also do the same think, when the grid no more, they regroove again to make new grid but this is not safe, higher chance tyre to explode especially heavy load or high speed Yup, no need to save on tyres. It's like the PSU in our CPUs, people can spend $500 on graphics cards but buy cheap lousy PSU. Bth. Link to post Share on other sites More sharing options...
Passion 5th Gear April 28, 2013 Share April 28, 2013 Sidewall got wire ah? Normally don't have. But from experience, this little chip not going to cost his life I guess. Mine got a cut within the groove line, still good to go for 10k km before I change out. By the way, then my tyre was XM1. Link to post Share on other sites More sharing options...
Pisces69 6th Gear April 28, 2013 Share April 28, 2013 Normally don't have. But from experience, this little chip not going to cost his life I guess. Mine got a cut within the groove line, still good to go for 10k km before I change out. By the way, then my tyre was XM1. I guess it also depends on how u drive. If u dun push it hard....maybe it wud b safer but if u like to push it hard....better change cos e sidewall takes a beating in hard cornering...braking... n acceleration. ↡ Advertisement Link to post Share on other sites More sharing options...
How are you using the SkillsFuture?
Using blower to dry car
Singapore indeed is a safe country
Dunlop SP Sport FM800
CPU chip - What are you using? Intel or AMD?
56 Delightful Victorian Slang Terms You Should Be Using
Fire extinguisher (safe to be kept inside car's boot?)
Who Still using STP Oil Treatment?
