King 1st Gear May 21, 2013 Share May 21, 2013 Anyone know any workshop that can do the centre bore? Thank you, ↡ Advertisement Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear May 21, 2013 Share May 21, 2013 Anyone know any workshop that can do the centre bore? Thank you, Its not a easy job...need to be precises...else your rims can throw away once its out. Link to post Share on other sites More sharing options...
Driver57 Neutral Newbie May 21, 2013 Share May 21, 2013 Anyone know any workshop that can do the centre bore? Thank you, Of cos you can. What size to what size ???? I know a shop that can do it but he is not available until end of this month. Link to post Share on other sites More sharing options...
Achtung 6th Gear May 21, 2013 Share May 21, 2013 In Toa Payoh? Of cos you can. What size to what size ???? I know a shop that can do it but he is not available until end of this month. Link to post Share on other sites More sharing options...
Roberttan 5th Gear May 22, 2013 Share May 22, 2013 Anyone know any workshop that can do the centre bore? Thank you, yes you can do it First you have to remove the tyre out and bring to the machine shop tell them how big the hole you want Do note the they only follow your instruction and No guaranty you can fit into your car. 1 borther mentioned onve the hole size out you got to throw away your rim. Link to post Share on other sites More sharing options...
Roberttan 5th Gear May 23, 2013 Share May 23, 2013 yes you can do it First you have to remove the tyre out and bring to the machine shop tell them how big the hole you want Do note the they only follow your instruction and No guaranty you can fit into your car. 1 borther mentioned onve the hole size out you got to throw away your rim. If you give the machine shop correct hole size , they a quite accurate . most cases the rim has to throw away is hole size given are wrong (too big or too small ) Link to post Share on other sites More sharing options...
Watwheels Supersonic May 23, 2013 Share May 23, 2013 To install some kinda logo? Center bore do not have to be precise coz there's little use for it. What matters for the rims are the correct PCD of the bolt holes and the offset. Any workshop whose machines are big enough to accomodate the size of the rims can do it. But you have to remove the tires first. Hence you have to find a tireshop and a machining workshop within the same area. Link to post Share on other sites More sharing options...
Beregond Supersonic May 23, 2013 Share May 23, 2013 the centre bore size is very important leh, the rim is suppose to rest inside the wheel hub. if the centre bore of your rim is too big, it become your rim is support by only the 4/5 /6 screws or bots. that y sport rim alway need to put the centre bore ring inside to cover up the excess spare, failure to do so might result in virbrating of wheel and transmite to your steering wheel. in the worst case it might recult in your bot bended 1 side. when u mention u want to rebore the rim, my guess is properly your rim is the same pcd with your car, but the rim centre bore is too small and cannot fit into your car hub. machine shop can do the rebore for u, but very hard, cos very hard to clamp the rim, an alternatve method is to use a hand grinder and manual grind the rim to make the centre bore size bigger, ( if only smaller by 1 mm-2mm ) Link to post Share on other sites More sharing options...
Roberttan 5th Gear May 25, 2013 Share May 25, 2013 the centre bore size is very important leh, the rim is suppose to rest inside the wheel hub. if the centre bore of your rim is too big, it become your rim is support by only the 4/5 /6 screws or bots. that y sport rim alway need to put the centre bore ring inside to cover up the excess spare, failure to do so might result in virbrating of wheel and transmite to your steering wheel. in the worst case it might recult in your bot bended 1 side. when u mention u want to rebore the rim, my guess is properly your rim is the same pcd with your car, but the rim centre bore is too small and cannot fit into your car hub. machine shop can do the rebore for u, but very hard, cos very hard to clamp the rim, an alternatve method is to use a hand grinder and manual grind the rim to make the centre bore size bigger, ( if only smaller by 1 mm-2mm ) centre bore(hole) is important(technically) ( i think they are still some car running without properly sit centre bore rim without any issue for those vibration without proper bore knows the problem. Not all machine shop can rebore because of the machine clamping. those can do one sure no problem if you give them the correct number (bore diameter) BY using hand job i strongly against it because your bore wont be perfect circle Link to post Share on other sites More sharing options...
Pisces69 6th Gear May 25, 2013 Share May 25, 2013 To install some kinda logo? Center bore do not have to be precise coz there's little use for it. What matters for the rims are the correct PCD of the bolt holes and the offset. Any workshop whose machines are big enough to accomodate the size of the rims can do it. But you have to remove the tires first. Hence you have to find a tireshop and a machining workshop within the same area. Center bore hole is VERY IMPORTANT. Read e 2 posts above. Wheel sud rest on it n not e 4-5 studs. Studs r not strong enough to support e weight of e car. Link to post Share on other sites More sharing options...
Beehive3783 Turbocharged May 25, 2013 Share May 25, 2013 the centre bore size is very important leh, the rim is suppose to rest inside the wheel hub. if the centre bore of your rim is too big, it become your rim is support by only the 4/5 /6 screws or bots. that y sport rim alway need to put the centre bore ring inside to cover up the excess spare, failure to do so might result in virbrating of wheel and transmite to your steering wheel. in the worst case it might recult in your bot bended 1 side. when u mention u want to rebore the rim, my guess is properly your rim is the same pcd with your car, but the rim centre bore is too small and cannot fit into your car hub. machine shop can do the rebore for u, but very hard, cos very hard to clamp the rim, an alternatve method is to use a hand grinder and manual grind the rim to make the centre bore size bigger, ( if only smaller by 1 mm-2mm ) Yes you're right. I originally wanted to get a set of Lexus rims for my ride, until I found out that the centre bore diameter of the Lexus rims are smaller than my wheel hub. So had to give up the idea. Link to post Share on other sites More sharing options...
King 1st Gear June 11, 2013 Author Share June 11, 2013 which shop can do centre bore? can recommed a workshop? thank you, Link to post Share on other sites More sharing options...
Toeknee_33 Turbocharged July 10, 2013 Share July 10, 2013 To install some kinda logo? Center bore do not have to be precise coz there's little use for it. What matters for the rims are the correct PCD of the bolt holes and the offset. You are very wrong here. ↡ Advertisement Link to post Share on other sites More sharing options...
Wheel bolts and Wheel spacer
Wheel Spacer Installation DIY
Wheel Spacer, where to buy?
Strange Mural at Holland Drive Food Center
Wheel Hubs
Wheel Hubs
Paddle shifters - fixed to wheel or column?
Wheel spacers - the real truth...
