Kazuo Neutral Newbie October 27, 2013 Share October 27, 2013 Is disc rotor universal? As long as the hole and diameter match? For example, 5 x 100 296mm can be used for any make and model which is using the same spec? ↡ Advertisement Link to post Share on other sites More sharing options...
Picanto 3rd Gear October 27, 2013 Share October 27, 2013 its always best to use the OEM stuff Link to post Share on other sites More sharing options...
Hondasteam 1st Gear March 2, 2014 Share March 2, 2014 Is disc rotor universal? As long as the hole and diameter match? For example, 5 x 100 296mm can be used for any make and model which is using the same spec? Disc Thickness 20 Num. of holes 4 Height 41.4 Centering Diameter 58.6 Font/Rear Front Pitch Circle Ø 98 Got a few parameters to watch out for rotor. Anyway, just go to a reseller and tell them what's your car make/model. Link to post Share on other sites More sharing options...
ER-3682 Supersonic March 2, 2014 Share March 2, 2014 Depends on certain model,i saw some "souped up" VW using Porsche brake system. Link to post Share on other sites More sharing options...
Achtung 6th Gear March 2, 2014 Share March 2, 2014 Depends on certain model,i saw some "souped up" VW using Porsche brake system. As long as the bracket fits, the Porsche system can be used. I am using it on my Merc :) Link to post Share on other sites More sharing options...
Ichibawa 5th Gear March 3, 2014 Share March 3, 2014 basically all these parameters ↡ Advertisement Link to post Share on other sites More sharing options...
Singpost courier dishonesty with incredibly lousy service
Reform Party loses another GE candidate
Another Kungfu actor/master pass away
What is Chevy's top model?
