bambind 1st Gear November 18, 2013 Share November 18, 2013 for me have change the spark ignition coils and some tubes small and big as mention by my workshop still the problem presist. started die at ard 600 to 800km of driving then now daily. tried cleaning throttle body, not bad lasted aweek before old friend came back. seems nobody can solve this problem including going back to agent. and wasted alot of $$$$$$$ ↡ Advertisement Link to post Share on other sites More sharing options...
Karbonphyber 1st Gear November 19, 2013 Share November 19, 2013 thats not a good thing... sorry to hear about that man. i'm not about to become e-mechanic here. just wanna know what you've changed for brand new items. Link to post Share on other sites More sharing options...
bambind 1st Gear November 19, 2013 Share November 19, 2013 well ... throttle body calibration throttle body cleaning spark plugs ignition coil spark plugs cables vacuum hose (small and big ones) diagnostic n resetting Link to post Share on other sites More sharing options...
Bicolor 5th Gear November 19, 2013 Share November 19, 2013 (edited) For those who encounter stalling problems without check engine light and workshops cannot diagnose correctly even after changing lots of parts, ask your workshop to check if the ECU wiring harness connection is lose. Just sharing my personal experience with one of my family's cars, a Mazda 3. Encountered strange stalling problems even though the car seemed fine in every other way. The workshop did all the usual diagnostic tests and changed oxygen sensor, spark plugs, MAF sensor, etc., but the problem continued. Finally, they found out that the ECU wiring connection was loose. They managed to do some tweaks to it to hold it on firmly and the problem was solved once and for all. They say this is more commonly found on cars with the ECU located in the engine bay (such as the Mazda 3) as opposed to under the floorboard on the passenger seat, due to the amount of heat the components are exposed to. Characteristics of such stalling due to loose ECU wiring: No check engine light or fault codes when OBD diagnostic tools plugged in. If there are any such error codes, they are not related and the stalling will continue even after dealing with them. No idling problems - if your car has problematic, rough or erratic idling, you can rule out the problem. Stalling is very "gentle" and quiet, you only notice it once the steering goes dead and all the dashboard lights come on. Usually occurs at very low speeds, mainly when coming back on throttle after a hump or exiting a carpark, or sometimes when coming to a stop, either at the moment when you release the accelerator or tap the brake pedal. Sometimes occurs at random when parked and stationary with engine on. Edited November 19, 2013 by Bicolor 2 Link to post Share on other sites More sharing options...
Yeobh 4th Gear November 19, 2013 Share November 19, 2013 well ... throttle body calibration throttle body cleaning spark plugs ignition coil spark plugs cables vacuum hose (small and big ones) diagnostic n resetting Apparently you have a part changer doing the work, yr so call mech just don't have the ability to logically diagnose the problem. Keep clear from such shops, they probably don't even own a simple digital voltmeter. 1 Link to post Share on other sites More sharing options...
Hasram Clutched November 19, 2013 Author Share November 19, 2013 thanks all for the advised. i have sent for check n the mechanic had check that batt n altenator ok. he jusclean up the air sensor (if not mistaken the name). now so far so gd. thanks again. Link to post Share on other sites More sharing options...
Gogg3r Clutched November 19, 2013 Share November 19, 2013 Did u check yr electronic coil pack/distributor? Changed that too. Cables too. I got a lot of spare parts in my storeroom now due to this problem. Almost can make one new engine. for me have change the spark ignition coils and some tubes small and big as mention by my workshop still the problem presist. started die at ard 600 to 800km of driving then now daily. tried cleaning throttle body, not bad lasted aweek before old friend came back. seems nobody can solve this problem including going back to agent. and wasted alot of $$$$$$$ Sama sama boat la ah brudder. Just relax and drive slowly. For those who encounter stalling problems without check engine light and workshops cannot diagnose correctly even after changing lots of parts, ask your workshop to check if the ECU wiring harness connection is lose. Just sharing my personal experience with one of my family's cars, a Mazda 3. Encountered strange stalling problems even though the car seemed fine in every other way. The workshop did all the usual diagnostic tests and changed oxygen sensor, spark plugs, MAF sensor, etc., but the problem continued. Finally, they found out that the ECU wiring connection was loose. They managed to do some tweaks to it to hold it on firmly and the problem was solved once and for all. They say this is more commonly found on cars with the ECU located in the engine bay (such as the Mazda 3) as opposed to under the floorboard on the passenger seat, due to the amount of heat the components are exposed to. Characteristics of such stalling due to loose ECU wiring: No check engine light or fault codes when OBD diagnostic tools plugged in. If there are any such error codes, they are not related and the stalling will continue even after dealing with them. No idling problems - if your car has problematic, rough or erratic idling, you can rule out the problem. Stalling is very "gentle" and quiet, you only notice it once the steering goes dead and all the dashboard lights come on. Usually occurs at very low speeds, mainly when coming back on throttle after a hump or exiting a carpark, or sometimes when coming to a stop, either at the moment when you release the accelerator or tap the brake pedal. Sometimes occurs at random when parked and stationary with engine on. My ECU not in engine bay one. But I'll still go tamper around with it la. Maybe that could be the cause. Haha. Use cable ties can already right? Link to post Share on other sites More sharing options...
bambind 1st Gear November 19, 2013 Share November 19, 2013 for me driving slowly is not an issue,problem is one time turning into lane and there was a zebra crossing and engine dead at the moment without brakes and steering control can imagine if someone is crossing at that moment.......... it just dangerous that's all and dare not bring family along and u can cause accident also as u know our people r not so patience will honk u for everything not knowing u have car problem. that is y i take bus and drive only nearby when less traffic. Link to post Share on other sites More sharing options...
bambind 1st Gear November 19, 2013 Share November 19, 2013 refer to bro bicolour, look at all the parts u have change and the cost inccur for items replaced and not in fault and finally found another item that was the problem. did your workshop changes u for all the unnescessary item change? and lucky for u the problem was resolved but to some of us not so lucky have spend close to 4K but got nothing in return. can imgine some bros out there can't expect to spend like this.(that is why taking bus) i hope that workshop out there try to understand,not charging us items in which was diagnoses wrongly. Link to post Share on other sites More sharing options...
Bicolor 5th Gear November 19, 2013 Share November 19, 2013 My ECU not in engine bay one. But I'll still go tamper around with it la. Maybe that could be the cause. Haha. Use cable ties can already right? Possibly not as likely then, but still, can ask your workshop about it. In my case they didn't use cable ties, but they added in something else to hold the wires in place. Couldn't really see what it was. refer to bro bicolour, look at all the parts u have change and the cost inccur for items replaced and not in fault and finally found another item that was the problem. did your workshop changes u for all the unnescessary item change? and lucky for u the problem was resolved but to some of us not so lucky have spend close to 4K but got nothing in return. can imgine some bros out there can't expect to spend like this.(that is why taking bus) i hope that workshop out there try to understand,not charging us items in which was diagnoses wrongly. They gave big discounts on some of the parts and completely waived other charges on diagnostics and labour. Also, they put in a lot of effort to get to the bottom of this rare problem, so overall we were quite satisfied. Link to post Share on other sites More sharing options...
Gogg3r Clutched November 19, 2013 Share November 19, 2013 for me driving slowly is not an issue,problem is one time turning into lane and there was a zebra crossing and engine dead at the moment without brakes and steering control can imagine if someone is crossing at that moment.......... it just dangerous that's all and dare not bring family along and u can cause accident also as u know our people r not so patience will honk u for everything not knowing u have car problem. that is y i take bus and drive only nearby when less traffic. Yeah, I know what you are saying. I got the same things from other cars too. No choice in this I guess. Possibly not as likely then, but still, can ask your workshop about it. In my case they didn't use cable ties, but they added in something else to hold the wires in place. Couldn't really see what it was. They gave big discounts on some of the parts and completely waived other charges on diagnostics and labour. Also, they put in a lot of effort to get to the bottom of this rare problem, so overall we were quite satisfied. Will do. Thanks for the tip bro. Link to post Share on other sites More sharing options...
Pisces69 6th Gear November 19, 2013 Share November 19, 2013 refer to bro bicolour, look at all the parts u have change and the cost inccur for items replaced and not in fault and finally found another item that was the problem. did your workshop changes u for all the unnescessary item change? and lucky for u the problem was resolved but to some of us not so lucky have spend close to 4K but got nothing in return. can imgine some bros out there can't expect to spend like this.(that is why taking bus) i hope that workshop out there try to understand,not charging us items in which was diagnoses wrongly. Most ws is only trying to make as much $$$ from us. The more parts u change, the more $$$ ty earn from u. Thats why I only go to ws with a good honest mech. If the mech poor at troubleshooting, u r going to spend a lot more $$$ than needed. And ty make tons of extra $$$ from u at the same time. Link to post Share on other sites More sharing options...
Stevocanes Neutral Newbie March 22, 2021 Share March 22, 2021 My 2007 stream done the same thing. My oil rag was sucked into the air pump where the battery sits and it was blocking the pipe. If you're oil rag has mysteriously disappeared this might be your problem Hope this helps someone 1 1 Link to post Share on other sites More sharing options...
lfeppp Neutral Newbie June 1, 2021 Share June 1, 2021 this issue happened to me on the road last week, and for me the issue was a spoilt fuel pump.. had to get the car towed and replaced it at the workshop. repair done within 24 hrs though, free of charge 1 Link to post Share on other sites More sharing options...
Hamburger Hypersonic June 1, 2021 Share June 1, 2021 Car make and model?? Link to post Share on other sites More sharing options...
Jest1081 Neutral Newbie August 2, 2021 Share August 2, 2021 I saw a video on yt a 12 year old lexus having a similar issue. It turn out to be fuse ↡ Advertisement Link to post Share on other sites More sharing options...
Sudden death due to cardiac arrest
Manmohan Singh, former Indian prime minister, dies at 92
Ngee Ann Poly lecturer, 59, dies 1 day after brother, 56, dies of cancer, leaving their mum behind
SCHNELL Engine Oil 5W40
