Ingenius Turbocharged February 8, 2015 Share February 8, 2015 Anyone has ever experienced steering wheel has a wobbly feel when turning ? Like a loose belt like that. What could be the cause ? Where can repair ? Thanks. ↡ Advertisement Link to post Share on other sites More sharing options...
Hussaini20 3rd Gear February 8, 2015 Share February 8, 2015 Anyone has ever experienced steering wheel has a wobbly feel when turning ? Like a loose belt like that. What could be the cause ? Where can repair ? Thanks. How abt driving on the road? Does it sway for no apparent reason as well? If it does, do check your control arm bushings and tie rods. If it doesn't act up during ddriving, only turning, check the steering wheel bearing, wear out liao. Link to post Share on other sites More sharing options...
Ingenius Turbocharged February 8, 2015 Author Share February 8, 2015 Thank you for your suggestions, will check for the possible causes you suggested. Link to post Share on other sites More sharing options...
Fuelsaver Supercharged February 9, 2015 Share February 9, 2015 is it very sudden when u feel like that? if so, mayb u've hit some hard object n likely to affect ur bush / control arm / tie rod n the likes? anyway, try jack up each side of front wheel to check for any free play first by holding with ur hand to pull / push left right up down - if still tight, may b other issue in steering shaft components. worst case scenario mayb ur drive shaft, but recon / oem one probably cost few hundred bucks for both sides. Link to post Share on other sites More sharing options...
Watwheels Supersonic February 9, 2015 Share February 9, 2015 It could the strut mounting from your front suspension. Might not be steering rack issue. ↡ Advertisement Link to post Share on other sites More sharing options...
Rear seat passenger : Do they belt up?
Wheel bolts and Wheel spacer
Wheel Spacer Installation DIY
Wheel Spacer, where to buy?
Steering leather wrapping
Wheel Hubs
Wheel Hubs
