flikmy 1st Gear May 12, 2020 Share May 12, 2020 On 5/11/2020 at 8:53 AM, richard_crl032 said: Hi Goh, There is known early failure of bushing of our sj forester that can happen from 20-50k km regardless with upgrade front arb or not. When bks woodlands replaces them, they do so with compatible sh forester ones that is reportedly more lasting from past experiences. Dun be surprised if your whole steering wheel vibrates up and down violently when even making slight turn at 90kmhr ... it shocked me and thought the steering mechanism failed which is a much bigger issue. Cheers. Richard Seems like my experience as well. Was on about 30k km when this happened. When doing slight turns on NSHW above 90kmh, car kept juddering. Initially though it was differential that was a problem but when I brought back to MI, they replaced the bushing and problem seems to have gone. Unsure if this is definitely the cause but I think this problem caused one of my tyres to thin more than the others as well. Drove close to 1000km with the issue. So had to change the whole set. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
richard_crl032 6th Gear June 4, 2020 Share June 4, 2020 (edited) Ummh, a bit quiet here nowadays. Anyway, embarked on my recurring last major mod .... Received used mint part of headlight marked 8Q which I do not know why so rarely available in Yahoo Japan ... usual is 8P or something else: https://page.auctions.yahoo.co.jp/jp/auction/j638713747 Hope to modify it to slightly whitish leds and not sure whether can even be done ... CB period quite hard to make inquiries at usual accessory shops. Currently, our headlight is off warm white at probably 5k temp and hope for 6k cool white to match the DRL light that I modded with Osram leds without getting expensive original one and certainly not unreliable tiong ones. The DRL lights are from there if anyone interesting .... I added clear silicon as further waterproofing to the already included ring washer and accessories shop simply drilled to connect up .. 1.5 yrs and all good: https://www.amazon.com/gp/product/B00QUGWV4Q/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1 Hope to report back when this "final" mod is completed else will be kept as spares since local new ones are probably 1.5k or more EACH side. Cheers, Richard Edited June 4, 2020 by richard_crl032 1 Link to post Share on other sites More sharing options...
richard_crl032 6th Gear June 23, 2020 Share June 23, 2020 Finally MI installing solar film on new subaru cars with eyesight ! Link to post Share on other sites More sharing options...
Hydesg 1st Gear June 29, 2020 Share June 29, 2020 anyone using the STI suspension set? any reviews? Am thinking of upgrading the XT suspension. https://www.sti.jp/en/parts/forester_sj/suspension/ST20310SF000/ can install at motor image? Link to post Share on other sites More sharing options...
richard_crl032 6th Gear July 1, 2020 Share July 1, 2020 On 6/29/2020 at 11:25 AM, Hydesg said: anyone using the STI suspension set? any reviews? Am thinking of upgrading the XT suspension. https://www.sti.jp/en/parts/forester_sj/suspension/ST20310SF000/ can install at motor image? Hi Bydesg, Sure can as one bro received his year back with them but not cheap. However, my recommendation is to stay with adjustable one to tune to your liking against this fixed one. Cheers. Richard Link to post Share on other sites More sharing options...
richard_crl032 6th Gear July 1, 2020 Share July 1, 2020 On 6/4/2020 at 10:58 PM, richard_crl032 said: Ummh, a bit quiet here nowadays. Anyway, embarked on my recurring last major mod .... Received used mint part of headlight marked 8Q which I do not know why so rarely available in Yahoo Japan ... usual is 8P or something else: https://page.auctions.yahoo.co.jp/jp/auction/j638713747 Hope to modify it to slightly whitish leds and not sure whether can even be done ... CB period quite hard to make inquiries at usual accessory shops. Currently, our headlight is off warm white at probably 5k temp and hope for 6k cool white to match the DRL light that I modded with Osram leds without getting expensive original one and certainly not unreliable tiong ones. The DRL lights are from there if anyone interesting .... I added clear silicon as further waterproofing to the already included ring washer and accessories shop simply drilled to connect up .. 1.5 yrs and all good: https://www.amazon.com/gp/product/B00QUGWV4Q/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1 Hope to report back when this "final" mod is completed else will be kept as spares since local new ones are probably 1.5k or more EACH side. Cheers, Richard Hi bros, A bit of bad news on this mod ... had been advised that main projection lights of FL with SRH are LED type that cannot be modded. The unused pair is now on carousell or will be used to replace aged in 7 yrs if my plan to keep for COE renewal. No heart to get pre FL's halogen or HID ones to mod unless super bored as I also found out that aftermarket ones are not easily matched on drl and projector colors and nowhere nice as those stock audi, merc or evem vezel ones. Cheers. Richard Link to post Share on other sites More sharing options...
richard_crl032 6th Gear July 2, 2020 Share July 2, 2020 Hi bros, Some minor mods sharing here out of boredom. Cheers Richard Link to post Share on other sites More sharing options...
Hydesg 1st Gear July 3, 2020 Share July 3, 2020 Richard, what do you recommend to upgrade to? for coilovers Link to post Share on other sites More sharing options...
richard_crl032 6th Gear July 3, 2020 Share July 3, 2020 (edited) 4 hours ago, Hydesg said: Richard, what do you recommend to upgrade to? for coilovers Hi Hydesg, I have limited experience on coilover in testing out rides of generous bros with them which are primarily from Pedders and Tein. I am however bias against getting into coilover from my experience with my estima which was a bad one since i covet comfort and not roadhandling but it is highly subjective due to individual preference and no same identical ride. Pedders are for the hardcore which is still loved by some but many gave up in the end. Tein is softer but still, some owners are trying to soften up their ride further. Be wary when workshop tells you that you can adjust coilovers to the softer and it is comfortable .. ymmv. Unless hardcore driver, I would recommend to stay away from coilover and stay with damper+spring setup Whichever route of aftermarket damper+spring or coilover, it will be nice for dynamically adjusting ones according to speed and even G forces like Tein which my current Cusco Touring A is not. Believe we all want nice comfortable ride most of the time while having things tighten up in higher speed and spirited cornering. Key considerations then are the $ and associated failures due to more complex system after you make this move but please note I had not had the opportunity to experience this active edfc pro and damper+spring setup.. Cheers, Richard Introduction to edfc active pro and compatible spring+dampers (and also coilover): <<https://www.tein.com/products/edfc_active_pro.html>> << >> << >> Edited July 3, 2020 by richard_crl032 1 Link to post Share on other sites More sharing options...
richard_crl032 6th Gear July 3, 2020 Share July 3, 2020 Hi, Looks like no turbo forester ever again. 《https://www.torquenews.com/1084/2020-subaru-forester-shines-bright-while-all-new-outback-drops-rock》 Cheers Richard Link to post Share on other sites More sharing options...
teomingern Supercharged July 6, 2020 Share July 6, 2020 Not sure about the excellent fuel mileage bit though... ha ha... my experience is rather dismal fuel consumption especially with all city driving. But I guess overseas with four seasons, it may make a lot more sense... 1 Link to post Share on other sites More sharing options...
Hydesg 1st Gear July 8, 2020 Share July 8, 2020 anyone knows where to get bilstein suspension for the forester xt? Link to post Share on other sites More sharing options...
Evilernie 4th Gear July 11, 2020 Share July 11, 2020 On 7/8/2020 at 8:56 AM, Hydesg said: anyone knows where to get bilstein suspension for the forester xt? There isn't any for forester XT. Link to post Share on other sites More sharing options...
WML888 2nd Gear July 11, 2020 Share July 11, 2020 Was looking at STi rims (12 spokes), with +55 offset (stock is +45 offset). But, it claims can clear BBK ... is that due to spoke design ? Link to post Share on other sites More sharing options...
richard_crl032 6th Gear July 12, 2020 Share July 12, 2020 On 7/8/2020 at 8:56 AM, Hydesg said: anyone knows where to get bilstein suspension for the forester xt? Hi Hydesg, Japan has B12 which I bought and sold ... I also just been advised by kaki that USA released B6: https://www.vividracing.com/bilstein-shock-absorber-subaru-forester-rear-20142018-p-152594852.html Cheers. Richard Link to post Share on other sites More sharing options...
Hydesg 1st Gear July 15, 2020 Share July 15, 2020 On 7/12/2020 at 10:40 AM, richard_crl032 said: Hi Hydesg, Japan has B12 which I bought and sold ... I also just been advised by kaki that USA released B6: https://www.vividracing.com/bilstein-shock-absorber-subaru-forester-rear-20142018-p-152594852.html Cheers. Richard I am wondering if coilovers are good lowered? I am thinking of cusco street zero A red. There is not much confidence turning sometimes on the highway... Link to post Share on other sites More sharing options...
richard_crl032 6th Gear July 16, 2020 Share July 16, 2020 On 7/15/2020 at 8:22 AM, Hydesg said: I am wondering if coilovers are good lowered? I am thinking of cusco street zero A red. There is not much confidence turning sometimes on the highway... Hi Hydesg, Prepare for harder and more harsh ride with aftermarket suspension .. ymmv 😞 Do consider front cusco anti-roll bar (arb) and rear wrx sti arb which will help your handling which also intro some harshness but marginal .. ymmv 🙂 Cheers. Richard Link to post Share on other sites More sharing options...
Jamesgetz 4th Gear July 16, 2020 Share July 16, 2020 (edited) On 7/11/2020 at 11:39 PM, WML888 said: Was looking at STi rims (12 spokes), with +55 offset (stock is +45 offset). But, it claims can clear BBK ... is that due to spoke design ? Yes, it’s due to the spoke design and thinness. STi rims can fit STi Brembo BBK but not necessarily other brands of BBK. Edited July 16, 2020 by Jamesgetz ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Advice on exhaust.
Advice on exhaust.
New Subaru XV
New Subaru XV
2015 Mazda CX3
2015 Mazda CX3
Hyundai Sonata (2015)
