Sarion 4th Gear October 21, 2020 Share October 21, 2020 (edited) On 10/17/2020 at 1:10 PM, richard_crl032 said: Hi, Still not happy with sti pink spring and adjustable cusco touring A especially after trying bro Jason's fna with tein endura pro plus dampers that was markly more stable and compliant. More of the special feature of HBS and slightly oversized construction here: https://www.tein.com/products/endurapro.html Got weak and went ahead with the endura pro bks woodlands at 1k while ordered the edfc active pro controller from Japan at 1.1k including shipping and kena gst but was glad I did ! Pink springs are no longer jittery and new ride was obviously more compliant than cusco touring A dampers whatever setting tried with its incabin controller. Yesterday fitted received Tein efdc active pro and was up at 3-4 am last nite on cte, sle, aerospace etc. doing adjustment and wow !! With g sensor for both lateral and longitudinal adjustment, accelerating sees rear dampers tightens up and deceleration sees front damping tightens up for a stable ride without head rearing up or dipping down. At increasing speed, my setting for comfort tightens up which is fine to have the needed stability for again a stable ride. Last but most important at turns when lateral, longitudinal and speed auto adjustment kicks in, left damper stiffens up when turning right to pull car flat and vice versa. The result is 80kmhr cornering around usual bend from cte to seletar aerospace area from no confidence became 90 kmhr and still room to push. I now swears by such dynamic suspension set up with dampers for compliance that was never achievable before 😍. However, bad news is that while I cannot hear motor noise from front motors, the rear motor noise was unbearable .. it is basically in cabin for forester unlike sedan. This morning attempt with 3m insulation and SP material heavily wrapped made no significant improvement ... now in attempt to box it with the help of my friend and tba. Have no doubt .. tein endura pro plus that is adjustable and tein edfc active pro for most compliant ride while rear motor noise need to be fixed 😔 Cheers. Richard hi Richard, did you install the EDFC Active Pro at BKS also? also, how would you rate the Endura Pro just by themselves without EDFC? also regarding earlier post for coilover.... comfort + handling -> Ohlins 😁 just that bank account need to be comfortable also with the price... Edited October 21, 2020 by Sarion ↡ Advertisement Link to post Share on other sites More sharing options...
richard_crl032 6th Gear October 24, 2020 Share October 24, 2020 (edited) On 10/21/2020 at 9:36 PM, Sarion said: hi Richard, did you install the EDFC Active Pro at BKS also? also, how would you rate the Endura Pro just by themselves without EDFC? also regarding earlier post for coilover.... comfort + handling -> Ohlins 😁 just that bank account need to be comfortable also with the price... Hi Sarion, BKS c/o Ah Keong only stocks dampers and bo edfc .. I bought direct from Japan as usual cos small boxes and local quoted 1.8k, no stock needing to order longer time as well as no warranty reportedly instead of 1.3k I paid including shipping, gst and installation in double quick time. BMS AMK c/o Heng/Hua helped with installation 2-3 weeks later upon receipt of the edfc active pro after running the Endura Pro plus by its own. Endura Pro plus is the adjustable version and it damps well compared to cusco touring A ... seems that its marketed HBS really works. However, it is with edfc active pro that takes it to a different level via dynamic adjustment. As an example, I set to medium setting without edfc or simply put to manual with edfc, it is fine but with lateral adjustment, acceleration will see rear dampers tightening up for a flat stable ride and when it gathers speed, it tightens all 4 which then allows you to set it cushy softer at lower speed in the 1st place. No experience with mega bucks ohlin coilover but as long as not dynamic, there is no comparison since road surfaces, speed and cornering conditions ALWAYS changes continuously unless hardcore sepang bro with known track conditions .. that including Peddars coilover which I will avoid is not for compliant ride. Do keep in mind that I am now on sti pink springs ... if back to stiffer rsr, it would have been more stable but less compliant. For me, pink springs stays as road holding is already fantastic and beats rsr with cusco touring A at whatever adjustment ... again, watching the edfc display reading tighten left dampers and differently for front and rear when engaging a right bend and you will understand why it is so stable, compliant and in much much better control. Endgame .... but you have to fix noise issue from rear or accepts it which I cannot. 2 sets of motors and extenders ordered pending arrival to prepare soundproofing it by kaki perhaps vouch for the quantum leap and no way I can do without endura pro plus and edfc active pro after this 3 years search on acceptable ride comfort and handling ? 😅 Cheers. Richard Edited October 24, 2020 by richard_crl032 Link to post Share on other sites More sharing options...
shutterbox 3rd Gear October 26, 2020 Share October 26, 2020 on the question of suspension: 1) how much improvement will i get to change out stock SJG springs to STI pink? anyone change just rear or front springs instead of all? 2) will installing a front tower strut, with and without changing springs, do any improvement? 3) SJG's factory rear ARB is the 16mm one? I read that upgrading to a thicker ARB (eg the STI one) is going to get a more stable, but harsher ride, especially on rougher roads. not sure if just changing springs (front or rear of both) or installing ARB or/and strut bar is going to provide a more planted ride without introducing too much harshness Link to post Share on other sites More sharing options...
richard_crl032 6th Gear October 26, 2020 Share October 26, 2020 https://www.torquenews.com/1084/all-new-forester-18l-turbo-vs-20xt-and-subarus-plan-you-won-t-be-happy Subaru Corporation dropped the Forester 2.0XT because the brand is focusing on global fuel-economy standards. Fuel economy in the 2.0XT with a CVT was 27/23 city/highway mpg. Subaru reports the new 2021 Forester Sport 1.8-liter turbocharged engine gets 24.2/35.7 Focus on fuel but city driving like ours in Singapore with lower FC efficiency ? Must start saving $ for 2nd COE for my collectible FXT liao 😅 Link to post Share on other sites More sharing options...
Stratovarius Turbocharged October 26, 2020 Share October 26, 2020 51 minutes ago, richard_crl032 said: https://www.torquenews.com/1084/all-new-forester-18l-turbo-vs-20xt-and-subarus-plan-you-won-t-be-happy Subaru Corporation dropped the Forester 2.0XT because the brand is focusing on global fuel-economy standards. Fuel economy in the 2.0XT with a CVT was 27/23 city/highway mpg. Subaru reports the new 2021 Forester Sport 1.8-liter turbocharged engine gets 24.2/35.7 Focus on fuel but city driving like ours in Singapore with lower FC efficiency ? Must start saving $ for 2nd COE for my collectible FXT liao 😅 This is the real collectible But 1.8T is not that bad la. 300Nm is still quite fun, but the CVT will zap a lot of fun from it. Link to post Share on other sites More sharing options...
richard_crl032 6th Gear October 26, 2020 Share October 26, 2020 (edited) 16 minutes ago, Stratovarius said: This is the real collectible But 1.8T is not that bad la. 300Nm is still quite fun, but the CVT will zap a lot of fun from it. Haha ... indeed for many without cvt but not for me .. cannot mod to my aesthetic requirement and too noisy as well as a chore to maintain cos too worn liao. Cheers. Richard Edited October 26, 2020 by richard_crl032 1 Link to post Share on other sites More sharing options...
Tohto Hypersonic October 26, 2020 Share October 26, 2020 (edited) 42 minutes ago, Stratovarius said: This is the real collectible But 1.8T is not that bad la. 300Nm is still quite fun, but the CVT will zap a lot of fun from it. Our FXT with 350Nm, due to the CVT already loss a lot of torque through it already. Other SUV with around 240bhp+ and 350Nm with 8 speed auto are all getting 0-100km/h of 6sec++. This 1.8T is a joke. Edited October 26, 2020 by Tohto 1 Link to post Share on other sites More sharing options...
Stratovarius Turbocharged October 26, 2020 Share October 26, 2020 4 hours ago, shutterbox said: on the question of suspension: 1) how much improvement will i get to change out stock SJG springs to STI pink? anyone change just rear or front springs instead of all? 2) will installing a front tower strut, with and without changing springs, do any improvement? 3) SJG's factory rear ARB is the 16mm one? I read that upgrading to a thicker ARB (eg the STI one) is going to get a more stable, but harsher ride, especially on rougher roads. not sure if just changing springs (front or rear of both) or installing ARB or/and strut bar is going to provide a more planted ride without introducing too much harshness 1. Change all 4. 2. Changing springs will have a bigger effect for body roll than front strut 3. Springs will affect the ride both straight and corners - harsher on straights, smoother on corners. ARB will have less effect on straights and not as smooth on corners. If you have the budget and don't mind a lowered SUV, go for springs or coilovers. Else, ARB is good enough. Link to post Share on other sites More sharing options...
Sarion 4th Gear October 26, 2020 Share October 26, 2020 On 10/24/2020 at 2:05 PM, richard_crl032 said: Hi Sarion, BKS c/o Ah Keong only stocks dampers and bo edfc .. I bought direct from Japan as usual cos small boxes and local quoted 1.8k, no stock needing to order longer time as well as no warranty reportedly instead of 1.3k I paid including shipping, gst and installation in double quick time. BMS AMK c/o Heng/Hua helped with installation 2-3 weeks later upon receipt of the edfc active pro after running the Endura Pro plus by its own. Endura Pro plus is the adjustable version and it damps well compared to cusco touring A ... seems that its marketed HBS really works. However, it is with edfc active pro that takes it to a different level via dynamic adjustment. As an example, I set to medium setting without edfc or simply put to manual with edfc, it is fine but with lateral adjustment, acceleration will see rear dampers tightening up for a flat stable ride and when it gathers speed, it tightens all 4 which then allows you to set it cushy softer at lower speed in the 1st place. No experience with mega bucks ohlin coilover but as long as not dynamic, there is no comparison since road surfaces, speed and cornering conditions ALWAYS changes continuously unless hardcore sepang bro with known track conditions .. that including Peddars coilover which I will avoid is not for compliant ride. Do keep in mind that I am now on sti pink springs ... if back to stiffer rsr, it would have been more stable but less compliant. For me, pink springs stays as road holding is already fantastic and beats rsr with cusco touring A at whatever adjustment ... again, watching the edfc display reading tighten left dampers and differently for front and rear when engaging a right bend and you will understand why it is so stable, compliant and in much much better control. Endgame .... but you have to fix noise issue from rear or accepts it which I cannot. 2 sets of motors and extenders ordered pending arrival to prepare soundproofing it by kaki perhaps vouch for the quantum leap and no way I can do without endura pro plus and edfc active pro after this 3 years search on acceptable ride comfort and handling ? 😅 Cheers. Richard thanks again for details. probably difficult for me to sacrifice the rear cargo space and ability to fold flat for bikes, etc.... i probably will have to sacrifice and just go dampers only with stock springs on my XV when the stock dampers up lorry 😛 can't go very fast on XV anyway great that you found your setup... 1 Link to post Share on other sites More sharing options...
Sarion 4th Gear October 26, 2020 Share October 26, 2020 9 hours ago, Stratovarius said: This is the real collectible But 1.8T is not that bad la. 300Nm is still quite fun, but the CVT will zap a lot of fun from it. actually should wait a bit longer for the next Gen, so that it can have new Levorg technologies : digital meter cluster and 11" center screen plus Eyesight X, and hopefully STi version with active dampers. slight tune sure go > 200bhp and 3years time should see Subaru with strong hybrid tech from Toyota, hopefully then can have something like the new Tucson/Sorento with 1.6T+motor -> 230hp... and yet close to 20km/l efficiency... Link to post Share on other sites More sharing options...
Tohto Hypersonic October 26, 2020 Share October 26, 2020 9 minutes ago, Sarion said: actually should wait a bit longer for the next Gen, so that it can have new Levorg technologies : digital meter cluster and 11" center screen plus Eyesight X, and hopefully STi version with active dampers. slight tune sure go > 200bhp and 3years time should see Subaru with strong hybrid tech from Toyota, hopefully then can have something like the new Tucson/Sorento with 1.6T+motor -> 230hp... and yet close to 20km/l efficiency... They need to replace the CVT with a proper 8 speed auto. Link to post Share on other sites More sharing options...
OnceInALifeTime 2nd Gear October 27, 2020 Share October 27, 2020 On 10/26/2020 at 8:43 AM, shutterbox said: on the question of suspension: 1) how much improvement will i get to change out stock SJG springs to STI pink? anyone change just rear or front springs instead of all? 2) will installing a front tower strut, with and without changing springs, do any improvement? 3) SJG's factory rear ARB is the 16mm one? I read that upgrading to a thicker ARB (eg the STI one) is going to get a more stable, but harsher ride, especially on rougher roads. not sure if just changing springs (front or rear of both) or installing ARB or/and strut bar is going to provide a more planted ride without introducing too much harshness Why change to STi pink springs and not the shock absorber? By just changing to pink springs, you will get a slightly lower right height. But the design of the original shock absorber is not meant to work with the pink springs although it will fit. Next, the shock absorber is supposed to damp the minor movements but after fitting the pink springs, the shock absorber will be compressed, because it is lower and the damping effect might not be good. By just installing the FLEXIBLE TOWER BAR F without the rest of the components; such as FLEXIBLE DRAW STIFFENER FRONT and FLEXIBLE SUPPORT SUB FRAME R. Might not have a big impact on the handling. However, with a lowered springs and lower C.G. The initial feel will provide more confidence in cornering. However, after awhile, might feel weird. As the springs are not meant for the shock absorber, the feel will not be good when taking bigger bends or curves. In e.g. exiting or entering into highways. Using the stock 16mm ARB, during cornering. It seems that there is more body roll. I will recommend to go for the 19mm ARB instead. It will provide a more stable feel during road drives without being too harsh. For change of springs, there is a need to change in 4 pieces, front 2 pieces and rear 2 pieces. However, it is better to obtain the shock dampers that was meant for the springs and vehicle. Even for shock dampers, there are monotube, twin tube, so on so forth... But mainly is those two. There are pros and cons to each design. Perhaps, there is a need to look at the focus of a planted ride. If there is an intention, to taking corners like a WRX. Then, there is a need to lower SJG to similar height as a WRX. Change the rims and tyres to wider profile and using road tyres. Or just simply change to a WRX... Else, you will be spending quite a sum on possible mods to achieve the above said effect. Link to post Share on other sites More sharing options...
OnceInALifeTime 2nd Gear October 27, 2020 Share October 27, 2020 20 hours ago, Tohto said: They need to replace the CVT with a proper 8 speed auto. Haha... The CVT is either you love it or hate it. But it is surely smooth... Link to post Share on other sites More sharing options...
GoodCar 4th Gear October 27, 2020 Share October 27, 2020 Will the Forester Sport 1.8T come to Singapore? Link to post Share on other sites More sharing options...
richard_crl032 6th Gear October 27, 2020 Share October 27, 2020 (edited) On 10/26/2020 at 8:43 AM, shutterbox said: on the question of suspension: 1) how much improvement will i get to change out stock SJG springs to STI pink? anyone change just rear or front springs instead of all? 2) will installing a front tower strut, with and without changing springs, do any improvement? 3) SJG's factory rear ARB is the 16mm one? I read that upgrading to a thicker ARB (eg the STI one) is going to get a more stable, but harsher ride, especially on rougher roads. not sure if just changing springs (front or rear of both) or installing ARB or/and strut bar is going to provide a more planted ride without introducing too much harshness 1. Subjective and hard to say how much better since related to your past experiences and expectation but yes, indeed better for roadholding and since harder and lowered by 15mm. One thing about pink springs is that it is jittery and I dun advice mix and matched on your own by having incomplete set ... dun think worth the try to engineer by by trial and error to what subaru or sti had already done and hope you can do better. 2. Slight improvement in cornering handling and nothing more with front strut. 3. Wrx sti rear arb is minor on harshness but also minor in improving roll which is what anti roll bar or arb is about. As mentioned, not much effect on front strut and harshness sure increases with thicker arb and stiffer springs. To be on the safe side against harshness which is also subjective, pink springs and sti wrx rear arb is fine. For me if I know now back then, tein endura pro plus and tein edfc active pro first and fine tune from there is still not satisfactory .. dynamic suspension cannot be beaten due to changing road conditions and speed .. endgame. Cheers. Richard Edited October 27, 2020 by richard_crl032 Link to post Share on other sites More sharing options...
richard_crl032 6th Gear October 27, 2020 Share October 27, 2020 (edited) On 10/26/2020 at 10:37 PM, Sarion said: thanks again for details. probably difficult for me to sacrifice the rear cargo space and ability to fold flat for bikes, etc.... i probably will have to sacrifice and just go dampers only with stock springs on my XV when the stock dampers up lorry 😛 can't go very fast on XV anyway great that you found your setup... Hi Sarion, Thanks ! Why must give up rear cargo space ? Din know yours is XV and you have to check how Tein edfc motors will installed if at all available and you dun have to forgo your rear cargo space. Edfc active pro with dynamic suspension setup will be a major different league in compliance and roadholding even if you have the endura pro plus. Cheers. Richard Edited October 27, 2020 by richard_crl032 Link to post Share on other sites More sharing options...
Stratovarius Turbocharged November 3, 2020 Share November 3, 2020 My blackvue that came with the car keeps repeating "resetting the time" everytime I crank the engine. Formatted the sd card but no use. Anyone encounter the same? Or is it time to change a new one?😒 Link to post Share on other sites More sharing options...
James996 4th Gear November 4, 2020 Share November 4, 2020 22 hours ago, Stratovarius said: My blackvue that came with the car keeps repeating "resetting the time" everytime I crank the engine. Formatted the sd card but no use. Anyone encounter the same? Or is it time to change a new one?😒 The internal batt sot liao...time to change a new one or check out how much to repair the batt. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
New Subaru XV
New Subaru XV
2015 Mazda CX3
2015 Mazda CX3
Advice on exhaust.
Advice on exhaust.
Hyundai Sonata (2015)
