subie4e Neutral Newbie December 1, 2021 Share December 1, 2021 @richard_crl032 Hi Richard, Please PM me the details for walnut blasting and packaged deal for the injector cleaning. Thanks, Jas ↡ Advertisement Link to post Share on other sites More sharing options...
richard_crl032 6th Gear December 1, 2021 Share December 1, 2021 @subie4e done ! 🙏🙏 Link to post Share on other sites More sharing options...
richard_crl032 6th Gear December 1, 2021 Share December 1, 2021 @marcuskok Hi Marcus, Good to hv but I found that having thicker cusco front arb has much more impact ... feedback and stability improvement are obvious. Cheers. Richard Link to post Share on other sites More sharing options...
Incom 1st Gear December 2, 2021 Share December 2, 2021 @richard_crl032 Wah, front ARB still need thicker? I am still waiting to install the following: STI Flexible Draw Stiffener, Rear Cusco POWER BRACE MEMBER SIDE Cusco Power Brace Front Side Cusco Rear Differential Carrier Torque Solution Rear Differential Bushings Keeping front ARB stock. Hoping the setup is good enough for daily drives. Link to post Share on other sites More sharing options...
richard_crl032 6th Gear December 2, 2021 Share December 2, 2021 1 hour ago, Incom said: @richard_crl032 Wah, front ARB still need thicker? I am still waiting to install the following: STI Flexible Draw Stiffener, Rear Cusco POWER BRACE MEMBER SIDE Cusco Power Brace Front Side Cusco Rear Differential Carrier Torque Solution Rear Differential Bushings Keeping front ARB stock. Hoping the setup is good enough for daily drives. Nice plan especially rear sti flexible braces that replaced stock thick steel ones. I did not ventured into some of your mentioned braces but all sti flexible one, including flexible subframe as I dun sepang and wish for a stable, firm but compliant ride. I also avoided coilover as a result ... yymv and expectation varied but when I dekitted my estima of >10 braces type, I enjoyed my ride for the last few days much more with reduced stiffness which is not helped by rear torsion beam. My take is to add them individually .. lighten the $ damage, appreciates the differences made and most importantly know what is the shortcoming and if last added really improved. Else you may end up like me with twice sti springs, rsr spring, cusco dampers, bilstein dampers, cusco rear arb, sti rear arb etc. etc. before my current setup. Cheers. Link to post Share on other sites More sharing options...
Incom 1st Gear December 2, 2021 Share December 2, 2021 8 minutes ago, richard_crl032 said: Nice plan especially rear sti flexible braces that replaced stock thick steel ones. I did not ventured into some of your mentioned braces but all sti flexible one, including flexible subframe as I dun sepang and wish for a stable, firm but compliant ride. I also avoided coilover as a result ... yymv and expectation varied but when I dekitted my estima of >10 braces type, I enjoyed my ride for the last few days much more with reduced stiffness which is not helped by rear torsion beam. My take is to add them individually .. lighten the $ damage, appreciates the differences made and most importantly know what is the shortcoming and if last added really improved. Else you may end up like me with twice sti springs, rsr spring, cusco dampers, bilstein dampers, cusco rear arb, sti rear arb etc. etc. before my current setup. Cheers. @richard_crl032 Coming from FD2R, anything now is mild. FXT stock is very quiet and nice to drive. After I have fixed the LCA bushings and front drive shafts issues. Just want to stiff up the car a bit to reduce flexing. Transmission and differential bushings, to improve the transmission efficiency, but trade off will be increase of NVH. Hope to see you soon at the workshop. 1 Link to post Share on other sites More sharing options...
ntuc2018 3rd Gear December 9, 2021 Share December 9, 2021 Hi, I just got a preowned XT. May I know what coolant is suitable for this car? Link to post Share on other sites More sharing options...
5ub23r0 1st Gear December 9, 2021 Share December 9, 2021 (edited) @ntuc2018 Congratulations on your ride! You will enjoy it! I got a pre-owned XT barely 3 weeks back and went to flush and fill with Ori Subaru Coolant. Edited December 9, 2021 by 5ub23r0 1 Link to post Share on other sites More sharing options...
Incom 1st Gear December 10, 2021 Share December 10, 2021 @richard_crl032 Just installed the STI Flexible Draw Stiffener, Cusco braces and rear differential mount carrier. The car feels more planted but no increase in harshness. CVT noise increase due to the rear differential mount carrier, but its not irritating. Car feels smoother, the feel of hollowness between 1.5 - 1.8K rpm is gone. Cheers 2 Link to post Share on other sites More sharing options...
shutterbox 3rd Gear December 10, 2021 Share December 10, 2021 sorry i had to ask this, but the search function doesnt work for thread only. If I need to replace front bushing outside of MI, where should I replace? and to what aftermarket ones, and roughly what costs? Link to post Share on other sites More sharing options...
richard_crl032 6th Gear December 10, 2021 Share December 10, 2021 1 hour ago, shutterbox said: sorry i had to ask this, but the search function doesnt work for thread only. If I need to replace front bushing outside of MI, where should I replace? and to what aftermarket ones, and roughly what costs? Bks woodlands c/o ah keong ... pls call him but think 280 and he will recommend previous SH's cos reportedly more robust. Cheers. 1 Link to post Share on other sites More sharing options...
Orixy 2nd Gear December 11, 2021 Share December 11, 2021 21 hours ago, shutterbox said: sorry i had to ask this, but the search function doesnt work for thread only. If I need to replace front bushing outside of MI, where should I replace? and to what aftermarket ones, and roughly what costs? I bought superpro polyurethane bushings from ebay, which is much cheaper even when shipping is included. You can go to the superpro official website to check for correct part numbers then search on ebay for options to purchase. Install at your trusted wkshop. The superpro polyurethane bushings are noticeably stiffer than stock but they should last way longer. I love the handling improvements they gave after installation! I also did the Richard recommended magic collar and those made the overall ride more sporty and planted, which i like. 🙂 1 Link to post Share on other sites More sharing options...
shutterbox 3rd Gear December 11, 2021 Share December 11, 2021 I changed at BKS, used stock SJ part. Thanks Richard n Orixy for sharing 🙂 1 Link to post Share on other sites More sharing options...
5ub23r0 1st Gear December 12, 2021 Share December 12, 2021 (edited) if anyone is still interested 1st tank SPC 95 8.11km/L 90% S mode 10% I mode 70% City 30% Highway Edited December 12, 2021 by 5ub23r0 1 1 Link to post Share on other sites More sharing options...
ntuc2018 3rd Gear December 13, 2021 Share December 13, 2021 (edited) @5ub23r0 Thanks. So far have been enjoying the quick pickup speed. Haha. May I know where can I buy this Subaru coolant? I search Lazada. Seems dun have. On 12/9/2021 at 9:07 PM, 5ub23r0 said: @ntuc2018 Congratulations on your ride! You will enjoy it! I got a pre-owned XT barely 3 weeks back and went to flush and fill with Ori Subaru Coolan Edited December 13, 2021 by ntuc2018 Link to post Share on other sites More sharing options...
ntuc2018 3rd Gear December 13, 2021 Share December 13, 2021 I am thinking to install such daytime running light on XT. Will there be any issue with LTA? These lights bought on Lazada suitable for Singapore XT? Also where can I get it installed? Thanks. Link to post Share on other sites More sharing options...
5ub23r0 1st Gear December 13, 2021 Share December 13, 2021 10 hours ago, ntuc2018 said: @5ub23r0 Thanks. So far have been enjoying the quick pickup speed. Haha. May I know where can I buy this Subaru coolant? I search Lazada. Seems dun have. Uh I changed it at BMS. before confirming the car I sent it to BMS for evaluation. Then right after ownership transfer I straight drive to BMS and flush and changed all the fluids (Engine Oil, CVT Oil, Coolants). 10 hours ago, ntuc2018 said: I am thinking to install such daytime running light on XT. Will there be any issue with LTA? These lights bought on Lazada suitable for Singapore XT? Also where can I get it installed? Thanks. was also looking at changing the fang DRL but I have not done research yet 😞 Link to post Share on other sites More sharing options...
richard_crl032 6th Gear December 13, 2021 Share December 13, 2021 (edited) 13 hours ago, ntuc2018 said: I am thinking to install such daytime running light on XT. Will there be any issue with LTA? These lights bought on Lazada suitable for Singapore XT? Also where can I get it installed? Thanks. Hi, these are all from tiongland and not recommended since they ALL do not last and look so so imho ... you need to cover these aftermkt lights to pass LTA inspection. Sti has their official white led ones albeit ex at about sgd800 or more but you can also get osram ones from amazon to drill and install .. they lasted 4 yrs in my xt especially since I added transparent silicon to further seal the electronics iJDMTOY 10pc 30W High Power Flexible LED Lighting Kit Compatible With Daytime Running Light or Under Car Puddle Light, 6000K Xenon White https://www.amazon.com/dp/B00QUGWV4Q/ref=cm_sw_r_awdo_navT_g_F0NCFT1W97V6EJKS9Q0K Cheers. Edited December 13, 2021 by richard_crl032 ↡ Advertisement Link to post Share on other sites More sharing options...
2022 Subaru Solterra BEV
Advice on exhaust.
Advice on exhaust.
New Subaru XV
New Subaru XV
