richard_crl032 6th Gear May 7, 2016 Share May 7, 2016 (edited) 1/2 1/2 - Getting an extra set of pillar From there ..... Work on Fiber glass , wooden mount.... Leather wrap ...... Etc It smoother up acclecration and the roll is more Meaning the car roll further when the foot is off the accelerator .. Hi Janjen, Indeed K&N filter makes your rider arguably lighter but pls dun expect day and nite different. Only ethrottle and piggyback like racechip ultimate gave significant difference on performance in addition to some others like strut bar, lowered spring, BBK etc. However, there are also those who never want to use K&F filter cos it is oil based especially when you clean it yourself after 50k miles as recommended. I am using it also but my estima had its airflow sensor clogged cos local periodic service dun clean airflow sensor like in usa or europe. You will find engine shuttering and loss in power and probably high FC if airflow sensor is clogged like in my experience but that was after 200k km and hence I am still using albeit taking care no excessive reoiling after cleaned. Cheers. Richard Edited May 7, 2016 by richard_crl032 ↡ Advertisement Link to post Share on other sites More sharing options...
richard_crl032 6th Gear May 7, 2016 Share May 7, 2016 I also not on ulitmate .... But yet I feel I have the oomph ..... :) Hi Meemee, Perhaps my expectation then cos estima is 2.4L or 2X the capacity and its 1.9ton may not be obvious after initial pick up at 60-70km/hr. However at 90km/hr upwards, 1.2L QQ certainly need to keep throttle open while 2.4L estima just cruises along with minimal intervention of the ethrottle. At these speeds, any needed acceleration is also for sure more brisk with the 2.4L estima. Hence, I would love the ultimate if not my CO's warning not to violate warranty too obviously :( Cheers. Richard Link to post Share on other sites More sharing options...
Talkie 1st Gear May 7, 2016 Share May 7, 2016 My Q1.2T will be delivered by end of month. Booked during recent expo, on 6 bid guarantee. TC got my COE this week. Car reaching shores early next week. 1) What is a good paint protection to take up? 2) Where can I go to get some sound insulation done on the doors? Thank you. 1 Link to post Share on other sites More sharing options...
Meemee 5th Gear May 7, 2016 Share May 7, 2016 This 6.5 inch sub look good -----to place at the rear doors Link to post Share on other sites More sharing options...
Mred1-2 4th Gear May 7, 2016 Share May 7, 2016 Hi Janjen, Indeed K&N filter makes your rider arguably lighter but pls dun expect day and nite different. Only ethrottle and piggyback like racechip ultimate gave significant difference on performance in addition to some others like strut bar, lowered spring, BBK etc. However, there are also those who never want to use K&F filter cos it is oil based especially when you clean it yourself after 50k miles as recommended. I am using it also but my estima had its airflow sensor clogged cos local periodic service dun clean airflow sensor like in usa or europe. You will find engine shuttering and loss in power and probably high FC if airflow sensor is clogged like in my experience but that was after 200k km and hence I am still using albeit taking care no excessive reoiling after cleaned. Cheers. Richard Yes the oil coupled with dirt becomes sticky residue. In my old ride the throttle body became a "sticky" issue. Link to post Share on other sites More sharing options...
EricChan 5th Gear May 7, 2016 Share May 7, 2016 1) I have good PPS experience with Optishine (read previous posts on this). 2) Go to MeeMee if you are keen on insulation work. My Q1.2T will be delivered by end of month. Booked during recent expo, on 6 bid guarantee. TC got my COE this week. Car reaching shores early next week.1) What is a good paint protection to take up?2) Where can I go to get some sound insulation done on the doors?Thank you. Link to post Share on other sites More sharing options...
dash1234 3rd Gear May 7, 2016 Share May 7, 2016 This 6.5 inch sub look good -----to place at the rear doorsMeemee and all expert out there,may l ask what about the front if l were to put this at the rear? Considering using Hertz for my front and left the rear untouch with the Pioneer subwoofer. I'm not that particular but just want something better than stock. Link to post Share on other sites More sharing options...
Meemee 5th Gear May 7, 2016 Share May 7, 2016 You may need lots of sound damping material for the sub at the door, else lot of metal vibration will generated . Hence - distortions ..... If you want to drive good speaker , I suggest maybe consider changing a head unit first ...... Cause stock not enough power to drive after market speaker. 1) I have good PPS experience with Optishine (read previous posts on this). 2) Go to MeeMee if you are keen on insulation work. Sorry ----- Meemee stop doing the door insulation works.... Maybe for a time being..... Due to family commitments :) Meemee and all expert out there,may l ask what about the front if l were to put this at the rear? Considering using Hertz for my front and left the rear untouch with the Pioneer subwoofer. I'm not that particular but just want something better than stock.Now working on how to add damping material :) Link to post Share on other sites More sharing options...
dash1234 3rd Gear May 7, 2016 Share May 7, 2016 You may need lots of sound damping material for the sub at the door, else lot of metal vibration will generated . Hence - distortions ..... If you want to drive good speaker , I suggest maybe consider changing a head unit first ...... Cause stock not enough power to drive after market speaker. Sorry ----- Meemee stop doing the door insulation works.... Maybe for a time being..... Due to family commitments :) Now working on how to add damping material :) Ok. Tks. Link to post Share on other sites More sharing options...
EricChan 5th Gear May 7, 2016 Share May 7, 2016 (edited) this modified 1st gen QQ reached 355 kmhr (222 mph) http://www.topgear.com/car-news/modified/watch-gt-r-engined-nissan-qashqai-hit-222mph Its 0 - 100 kmhr (0 - 62 mph) is 2.7 sec http://www.topgear.com/car-news/modified/meet-200mph-nissan-qashqai Edited May 7, 2016 by EricChan 1 Link to post Share on other sites More sharing options...
richard_crl032 6th Gear May 7, 2016 Share May 7, 2016 Hi Bros, Those whose asked avout thr reverse camera function on my newsmy dual wince and full android headunit, pls see enclosed much clearer and bright view with same stick camera due to simply superior 1024x600 screen against stock's 800x400. Cheers. Richard 1 Link to post Share on other sites More sharing options...
richard_crl032 6th Gear May 7, 2016 Share May 7, 2016 Meemee and all expert out there,may l ask what about the front if l were to put this at the rear? Considering using Hertz for my front and left the rear untouch with the Pioneer subwoofer. I'm not that particular but just want something better than stock. Hi dash1234, Oh no, meemee is showing superior replacement for your pioneer subwoofer cos rear door has the required bigger volume for low bass. You simply need to get some better 2 way speakers if you.want to improve the sound but as meemee mentioned, better headunit will make more significant difference and stock system + speake4s is quite ok and you hqve to spent quite a lot to upgrade significantly. Cheers. Richard Link to post Share on other sites More sharing options...
Talkie 1st Gear May 7, 2016 Share May 7, 2016 1) I have good PPS experience with Optishine (read previous posts on this). 2) Go to MeeMee if you are keen on insulation work. Thanks Eric. And noted MeeMee not free to do insulation anymore :). Link to post Share on other sites More sharing options...
Meemee 5th Gear May 7, 2016 Share May 7, 2016 Hi dash1234, Oh no, meemee is showing superior replacement for your pioneer subwoofer cos rear door has the required bigger volume for low bass. You simply need to get some better 2 way speakers if you.want to improve the sound but as meemee mentioned, better headunit will make more significant difference and stock system + speake4s is quite ok and you hqve to spent quite a lot to upgrade significantly. Cheers. Richard Get a decent set :) Make the ride more enjoyable ..... Especially after a hard day work .... Pump up the volume and enjoy the ride...... Must start the audio culture going .... Seem like not many into audio now a days ---- Correct me if I m wrong 1 Link to post Share on other sites More sharing options...
Baal Supersonic May 7, 2016 Share May 7, 2016 Is the 'power cut' that happens when turning for the 1.2 fixed? If so, what was the cause of this glitch? How was this fixed? Link to post Share on other sites More sharing options...
Talkie 1st Gear May 7, 2016 Share May 7, 2016 Get a decent set :) Make the ride more enjoyable ..... Especially after a hard day work .... Pump up the volume and enjoy the ride...... Must start the audio culture going .... Seem like not many into audio now a days ---- Correct me if I m wrong Any recommended place to get the audio done? Should change the heaf unit? Need to add amp, woofer and change speakers? My friend's new PI toyota sounds great w the locally installed pioneer HU costing S$200-300 and stock speakers. Quite astonishing. Link to post Share on other sites More sharing options...
richard_crl032 6th Gear May 7, 2016 Share May 7, 2016 Get a decent set :) Make the ride more enjoyable ..... Especially after a hard day work .... Pump up the volume and enjoy the ride...... Must start the audio culture going .... Seem like not many into audio now a days ---- Correct me if I m wrong Hi Meemee, Think now stock headunit not too bad and also with nav like ours that deter owners to change. Also younger gen grow up on ipod mp3 and not into high fidelity. Oso, have car nowadays damn achievement liao with high payments to make and there are also many other distraction as alternative avenue to spend $, including high priced housing. Cheers ! Richard Link to post Share on other sites More sharing options...
Mred1-2 4th Gear May 7, 2016 Share May 7, 2016 Is the 'power cut' that happens when turning for the 1.2 fixed? If so, what was the cause of this glitch? How was this fixed? It's the idling start/start software bug and solved with updated software. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
future of mitsubishi?
2018 Nissan Serena e-POWER
