SingtradeMarketing 1st Gear April 7, 2021 Author Share April 7, 2021 Audi Q7 Thank you for supporting us to Install: Bewith Plug & Play 1080 10ch/8ch DSP Processor with amplifier Helix SDMI 25 Audible physics Avatar 6.1 2way component speakers Audible physics Avatar 3"mid speaker The BEWITH PLUG & PLAY 1080 is a combination audio processor and amplifier that combines a high-quality 8-channel amplifier (50 watts/channel) and 8 channels of digital processing. It can be connected to any aftermarket audio source or factory head unit-having a comprehensive 8 channels of high-level (speaker level) inputs, AUX input/output (2 channels each) and high-resolution optical digital input. It also features fully adjustable software, high-speed and high capacity components, making it the ideal combination processor/amplifier to get the best in-vehicle sound quality. Don't miss the chance to upgrade your sound system. For more details please call now. Link to post Share on other sites More sharing options...
SingtradeMarketing 1st Gear April 7, 2021 Author Share April 7, 2021 BMW lovers good news! available stock now. Link to post Share on other sites More sharing options...
SingtradeMarketing 1st Gear May 6, 2021 Author Share May 6, 2021 Toyota Previa Thank for supporting us to Install: Bewith 1080 DSP 10/8ch with Amplifier & control Pioneer DMH-ZS9350BT Bewith lucent 2way component BEWITH Lucent was planned as the fourth speaker series after the company's BEWITH brand "Confidence," "Accurate," and "Reference AM." Although it is the most reasonable price range in the BEWITH brand speaker series, but it is act meively selected in terms of sound preference and installability as well as other series. We aimed to become a new class. The 2cm caliber dome tweeter (L-20L) uses the company's first new silk-based diaphragm material "Lucent Silk". It features an almost transparent diaphragm appearance, supple and pleasant to the ear, and a tone full of sharpness and transparency, and you can enjoy the charm of a new sound that is different from the conventional hard dome and soft dome. In addition, the driver unit is made as compact as possible. The 16.5cm woofer (L-165L) is a combination of the company's original aluminum-magnesium (AM) diaphragm and a powerful magnetic circuit with a large ferrite magnet, which has a proven track record in the advanced reference AM series, and is combined with the L-20L tweeter. Careful sound quality matching was performed. While keeping the mounting depth dimension to 60 mm, which is easy to mount on many car models, a generous amplitude stroke is secured by adopting a newly designed cone shape with a shallow shape and a large roll edge. The passive network dedicated to this system is particular about sound quality, such as using the BEWITH original cable "TRANSOLA OFC Hyper4N" as the wiring material. Only filtering on the tweeter side is performed, and the woofer side has a simple configuration that drives the full range to bring out the characteristics of each unit. Don't miss the chance to upgrade your sound system. For more details please call now at 62661719. Thank you. Link to post Share on other sites More sharing options...
SingtradeMarketing 1st Gear May 6, 2021 Author Share May 6, 2021 Subaru Forester Thank you for supporting us to Install: Bewith plug & play DSP 8ch with control. Bewith plug & play 2ch amplifier X 3. ESB Audio 5000 series 5.6K3 3 way component speakers. 𝗘𝗦𝗕 𝗔𝘂𝗱𝗶𝗼 Car Audio High-Quality Speakers. 𝗘𝗦𝗕, for over thirty years, has specialized in the engineering and construction of speakers for automotive applications, offering different product lines, united by the fact of true fidelity to the musical source. True to quality. True to the music. Pure performers, accurate reproducers. Don't miss the chance to upgrade your sound system. For more details please call 62661719 now! Thank you. Link to post Share on other sites More sharing options...
SingtradeMarketing 1st Gear May 6, 2021 Author Share May 6, 2021 Toyota Harrier Thank you for supporting us to Install: Zapco ST-6X DSP 6 Ch. Class AB Amplifier with DSP. FOCAL Flax Evo 2 ways component FOCAL PC165 2 ways coaxial speaker. Sound stream SB8AM active subwoofer. Zapco ST-6X DSP 6 Ch. Class AB Amplifier with DSP. 6-Channel, Full Range, Class A/B On-Board, Full Function, 8-ch. Digital Signal Processing High-pass and low-pass filters, phase control, signal delay, and 15 channels of parametric equalization on each channel Optical Digital Input Power @ 4Ω: 6 x 100 watts THD @ Rated Power < 0.5% THD Power @ 2Ω: 6 x 150 watts Power Bridged @ 4Ω: 3 x 300W RMS Signal to Noise Ratio > 90dB THD + Noise < 0.2% Channel Separation >60dB Frequency Response 15Hz to 30KHz ±1dB Don't miss the chance to upgrade your sound system. For more details please call 62661719 now! Thank you. Link to post Share on other sites More sharing options...
SingtradeMarketing 1st Gear May 6, 2021 Author Share May 6, 2021 The New Mercedes-Benz C-Class Coupé. Thank you for supporting us to Install: Ground Zero GZCS 100MB 4" Component Speaker - Mercedes-Benz Compatibility List: C Class - W205, S205,C205,A205 GLC - X253, C253 E Class - W213 , S213, C238,A238 S Class -W222 Ground Zero GZCS W-200ML 8" Footwell Woofer - Mercedes Power Handling (RMS/max.): 110 / 220 Watts Impedance 4 Ohms Efficiency 88 dB Frequency Response 30 – 1500 Hz Voice Coil 38 mm / 1.5" copper Membrane Coated glass-fiber. Don't miss the chance to upgrade your sound system. For more details please call 62661719 now! Thank you. Link to post Share on other sites More sharing options...
SingtradeMarketing 1st Gear May 6, 2021 Author Share May 6, 2021 BMW 6 Series Thank you for supporting us to Install: HELIX V EIGHT DSP MK2 Gound Zero GZCS 200BMW-SW Rainbow MP-S4BMW HELIX V EIGHT DSP MK2 The new multi-tool for professionals The small addition in the product name makes the big difference – the V EIGHT DSP MK2 is the logical evolution of its already more than impressive predecessor. Same look as before but in the inside Audiotec Fischer brought in all of his expertise and substantially optimized the hardware. The result is an 8-channel amplifier with ten processed DSP channels that is unrivalled in many ways. Extra speed – thanks to ACO Faster is better – the particularly powerful 32 Bit ACO platform takes over all control tasks and ensures the decisive speed increase, especially for data communication with our DSP PC-Tool software but also for the lightning-fast switching between up to ten sound setups. But ACO offers much more – fantastic sound effects such as Augmented Bass Processing or RealCenter are implemented as well as a channel-separated Input EQ including the Input Signal Analyzer (ISA) for easy analysis and compensation of input signals of OE radios. New signal converters for optimized sound quality Instead of a combined codec, the new V EIGHT DSP MK2 uses separate AD and DA converters of the latest generation from Asahi Kasei with a native resolution of 32 Bit. This ensures maximum signal resolution in the entire signal path from input to output – and thus also guarantees optimal sound quality. Power pack in a noble design Despite its further increased feature set and up to 160 Watts RMS output power per channel (@ 2 Ohms) the V EIGHT DSP MK2 presents itself in the classic, clean HELIX design which provides ideal preconditions for a quick and easy integration. High-tech performance could hardly be more noble and elegant! Don't miss the chance to upgrade your sound system. For more details please call 62661719 now! Thank you. Link to post Share on other sites More sharing options...
SingtradeMarketing 1st Gear May 6, 2021 Author Share May 6, 2021 Kia Sorento Thank you for supporting us to Install: Focal K2Power ES 165 KX3 3 way component speakers. Alpine PXE-0850S 8-Channel 25W x 8 RMS Amplifier with Digital Signal Processing. Soundstream SB8AM 8"active subwoofer. Sound stream RX652 3 way coaxial speakers. Sound stream 10.1" Android player. Alpine PXE-0850S Adjustment Details: 12-channel 32-bit 300 MHz digital processor, 31-band EQ with fine tuning, Adjustable high-, low-, and band-pass filters (20-20 KHz), Selectable filter slopes (12, 18, 24, 30, 36, 42, 48 dB/octave), Selectable filter characteristics (Butterworth, Bessel, and Linkwitz-Riley), Delay: 0-20 milliseconds (0-273"), Phase adjustment: 0 or 180°. Don't miss the chance to upgrade your sound system. While stock lasts. For more details please call 88476629 Thanks Link to post Share on other sites More sharing options...
SingtradeMarketing 1st Gear May 6, 2021 Author Share May 6, 2021 Toyota Wish Thank you for supporting us to Install: ESB Audio 5000 series 5.6K3 – 3-way speaker system. Zapco ST-6X DSP 6 Ch. Class AB Amplifier with DSP. Sound stream SB8AM active subwoofer. Sound stream 10'1 Android player. Sound stream RX652 3 way coaxial speakers. Pioneer rev camera. ESB Audio 5000series: 5.6K3 – 3-way speaker system. Tweeter – 5028 1.1″/28 mm Dome Tweeter, 28 mm aluminum voice coil 32.8 mm nominal diameter, High-grade neodymium magnet Carbon fiber dome, Ferrofluid cooling and damping Acoustic resistance Qts. control, Computer optimized design.Motor metal parts CNC machined, Under-dome dB Cloth® damping material Nominal Impedance: 4 Ohm Nominal Power Handling: 110 Watt. Transient Power: 220 Watt.Frequency Response: 900 Hz ~ 25 KHz Sensitivity: 91 dB 1W/1m Mid-range – 5050 2″/50 mm Dome Midrange, 50 mm aluminum voice coil High-grade neodymium magnet, Carbon fiber dome Ferrofluid cooling and damping, Acoustic resistance Qts control Computer optimized design, Motor metal parts CNC machined .Under-dome dB Cloth® damping material, Nominal Impedance: 4 Ohm Nominal Power Handling: 120 Watt.Transient Power: 240 Watt Frequency Response: 500 Hz ~ 6 KHz.Sensitivity: 91 dB 1W/1m Mid-woofer – 5165 6.5″/165 mm Mid-Woofer, Carbon fiber cone TWS® rubber surround, Copper and aluminum voice coil 25 mm voice coil diameter, Y35 oversized magnet Aluminum former, ABS housing Conex® progressive spider, Motor metal part CNC machined.Computer optimized design, Nominal Impedance: 4 Ohm.Nominal Power: 160 Watt Transient Power: 320 Watt Frequency Response: 50 Hz ~ 3.5 KHz Sensitivity: 92 dB 1W/1m Don't miss the chance to upgrade your sound system. While stock lasts. For more details please call 88476629 Thanks Link to post Share on other sites More sharing options...
SingtradeMarketing 1st Gear May 6, 2021 Author Share May 6, 2021 Honda Freed Thank you for supporting us to Install: Focal Flax Evo PS165FXE 2way component speakers. Bewith Plug & play 1080 10ch/8 ch DSP Processor with amplifier. Pioneer active subwoofer. The BEWITH PLUG & PLAY 1080 is a combination audio processor and amplifier that combines a high-quality 8-channel amplifier (50 watts/channel) and 8 channels of digital processing. It can be connected to any aftermarket audio source or factory head unit-having a comprehensive 8 channels of high-level (speaker level) inputs, AUX input/output (2 channels each) and high-resolution optical digital input. It also features fully adjustable software, high-speed and high capacity components, making it the ideal combination processor/amplifier to get the best in-vehicle sound quality. Don't miss the chance to upgrade your sound system. For more details please WhatsApp 88476629. Thanks. Link to post Share on other sites More sharing options...
SingtradeMarketing 1st Gear May 6, 2021 Author Share May 6, 2021 (edited) Toyota Camry Thank you for supporting us to Install: ESB Audio 5000 series 5.6K3 – 3-way speaker system. Zapco ST-6X DSP 6 Ch. Class AB Amplifier with DSP. Sound stream SB8AM active subwoofer. ESB Audio 5000series: 5.6K3 – 3-way speaker system. Tweeter – 5028 1.1″/28 mm Dome Tweeter, 28 mm aluminum voice coil 32.8 mm nominal diameter, High-grade neodymium magnet Carbon fiber dome, Ferrofluid cooling and damping Acoustic resistance Qts. control, Computer optimized design.Motor metal parts CNC machined, Under-dome dB Cloth damping material Nominal Impedance: 4 Ohm Nominal Power Handling: 110 Watt. Transient Power: 220 Watt.Frequency Response: 900 Hz ~ 25 KHz Sensitivity: 91 dB 1W/1m Mid-range – 5050 2″/50 mm Dome Midrange, 50 mm aluminum voice coil High-grade neodymium magnet, Carbon fiber dome Ferrofluid cooling and damping, Acoustic resistance Qts control Computer optimized design, Motor metal parts CNC machined .Under-dome dB Cloth damping material, Nominal Impedance: 4 Ohm Nominal Power Handling: 120 Watt.Transient Power: 240 Watt Frequency Response: 500 Hz ~ 6 KHz.Sensitivity: 91 dB 1W/1m Mid-woofer – 5165 6.5″/165 mm Mid-Woofer, Carbon fiber cone TWS rubber surround, Copper and aluminum voice coil 25 mm voice coil diameter, Y35 oversized magnet Aluminum former, ABS housing Conex progressive spider, Motor metal part CNC machined. Computer optimized design, Nominal Impedance: 4 Ohm.Nominal Power: 160 Watt Transient Power: 320 Watt Frequency Response: 50 Hz ~ 3.5 KHz Sensitivity: 92 dB 1W/1m Don't miss the chance to upgrade your sound system. While stock lasts. For more details please call 88476629 Thanks Edited May 6, 2021 by SingtradeMarketing Link to post Share on other sites More sharing options...
SingtradeMarketing 1st Gear May 6, 2021 Author Share May 6, 2021 Last job for 🐁 Year. BMW 6 Series Thank you for supporting us to Install: Full set for Bewith series. Bewith 1080 Plug & play 10/8ch DSP Processor with amplifier. Bewith Reference L-25R +L-88R Bewith Reference L-88R for center speakers. Bewith Reference L-165R. Bewith Reference series. Next-generation standard model, featuring newly developed AM diaphragm The Reference AM series further enhances reproduction of high-quality audio sources thanks to the newly developed AM (Aluminum/Magnesium) diaphragm and other new features, and is particulary designed for ease-of-installation to the latest sports cars and luxury automobiles. The line-up consists of three speaker unit models, three models combined with a dedicated network, and five dedicated network models, for a total of eleven models. This is the series completion of Bewith’s next-generation models, featuring timbre uniformity across all frequency bands, directivity control, and exceptional smooth and flat frequency response. Don't miss the chance to upgrade your sound system. For more details please call now. Link to post Share on other sites More sharing options...
SingtradeMarketing 1st Gear May 6, 2021 Author Share May 6, 2021 Alpine days. Thank you Noah & Forester supporting us to install: Alpine Halo11 iLX-F2611E THE BIGGEST 11-INCH SCREEN DISPLAY AUDIO The new iLX-F2611E Alpine Halo Mech-Less (no CD/DVD) Audio/Video Receiver features the same “hovering” screen platform as its predecessors while boasting a larger, 11-inch touchscreen – 49 percent more surface area than the 9-inch. For more details call 62661719. Thanks. Link to post Share on other sites More sharing options...
ackergilll Neutral Newbie February 27, 2022 Share February 27, 2022 Hello there, I've check this product of the best cushion for long distance driver, what do you guys think of that? is that seem legit? also these road trip essential, seem promising! what do you think guys? Link to post Share on other sites More sharing options...
ackergilll Neutral Newbie April 16, 2022 Share April 16, 2022 Try these for your baby support: Best Travel Booster Seat & Best Toddler Travel Bed Link to post Share on other sites More sharing options...
Emre Neutral Newbie July 14, 2022 Share July 14, 2022 Aşağıdaki linke sizler için bu yılın en pahalı ve en lüks arabalarını ekledim. https://oke.io/YakQ9a Link to post Share on other sites More sharing options...
Newbiee03 Neutral Newbie August 21, 2022 Share August 21, 2022 https://www.facebook.com/107378898643628/posts/pfbid0Wb8SP9ZLFQTLh4YMuyiygg3KEiSV5PVdcysYVwLiYoepiCagutwK9NVMjb6bBV7wl/?sfnsn=scwspmo , would recommend reading it, if you're into RV's Link to post Share on other sites More sharing options...
Actan72 5th Gear March 20, 2023 Share March 20, 2023 any amplifier to replace audison 8.9 ? Thanks Link to post Share on other sites More sharing options...
Car air-con
Car air-con
Home Aircon
Home Aircon
Car camera recommendation
Dehumidifier recommendations
Explore High-Performance FineVu Dashcams by Auto Interior Pte Ltd
