ncar90 1st Gear November 27, 2017 Share November 27, 2017 Hi all, I have this knocking sound on my rear brakes whenever i brake and it is very annoying. I have already changed the brake pads, cyclinder and the brake shoe and i even changed my absorbers but it still happens. It is a drum brake system on the rear and my car is a nissan latio. My regular workshop is unable to pin point to the problem,would appreciate some views from the forum. Thank you in advanced! ↡ Advertisement Link to post Share on other sites More sharing options...
Optramagnum 6th Gear November 27, 2017 Share November 27, 2017 Maybe it's your wheel hub bearing? Try jacking up your rear left tyre, and hold the tyre at 12 and 6 o clock then feel for any play, repeat by holding 3 and 9 o clock. By right, you shouldn't feel any jerk. Link to post Share on other sites More sharing options...
Gnahp Turbocharged November 28, 2017 Share November 28, 2017 did you change the drum? an out of round/distorted drum will make sound and pedal pulsating usually damage by mechanic over torque the wheel bolts/nuts using their mighty impact wrench Link to post Share on other sites More sharing options...
ncar90 1st Gear November 28, 2017 Author Share November 28, 2017 Maybe it's your wheel hub bearing? Try jacking up your rear left tyre, and hold the tyre at 12 and 6 o clock then feel for any play, repeat by holding 3 and 9 o clock. By right, you shouldn't feel any jerk. Not sure if its my wheel hub,my mechanic suspect it is the drum getting out of shape so i will be changing the drum did you change the drum? an out of round/distorted drum will make sound and pedal pulsating usually damage by mechanic over torque the wheel bolts/nuts using their mighty impact wrench mechanice suspect it is out of shape. I will change the drum and hopefully,things will improve.thanks! Link to post Share on other sites More sharing options...
AntiBap November 28, 2017 Share November 28, 2017 If you change everything about the breaking still happen. You should check on the steering, it maybe something wrong in the steering but not the break 1 Link to post Share on other sites More sharing options...
QQDreamer 4th Gear November 29, 2017 Share November 29, 2017 If you change everything about the breaking still happen. You should check on the steering, it maybe something wrong in the steering but not the break is brake not break Link to post Share on other sites More sharing options...
ncar90 1st Gear December 2, 2017 Author Share December 2, 2017 Changed up my drums and it feels really nice to have a good brake.No sound anymore. 1 Link to post Share on other sites More sharing options...
QQDreamer 4th Gear December 2, 2017 Share December 2, 2017 Changed up my drums and it feels really nice to have a good brake.No sound anymore. Glad that you solved the problem. Link to post Share on other sites More sharing options...
Ct3833 Supersonic December 2, 2017 Share December 2, 2017 If you change everything about the breaking still happen. You should check on the steering, it maybe something wrong in the steering but not the breakHe said rear wheel, so nothing to do with steering. Link to post Share on other sites More sharing options...
JusticeCg December 25, 2017 Share December 25, 2017 Have u crash your car to somewhere maybe and Link to post Share on other sites More sharing options...
ncar90 1st Gear December 26, 2017 Author Share December 26, 2017 Have u crash your car to somewhere maybe andNo.it is a drum problem.Changed it and now my ride is absolutely sound free 1 Link to post Share on other sites More sharing options...
kdash Supersonic December 26, 2017 Share December 26, 2017 Changed up my drums and it feels really nice to have a good brake.No sound anymore.good to know everything is ok now ↡ Advertisement Link to post Share on other sites More sharing options...
Wheel bolts and Wheel spacer
Wheel Spacer Installation DIY
Nissan QashQai 2014 Part 2
Wheel Spacer, where to buy?
Would You Buy a Nissan...
