Andrewkb Neutral Newbie August 15, 2003 Author Share August 15, 2003 Initially I thought your intake is facing the front, you should get colder air (w/o affected by radiator fan) .. until I dig through the old thread and realised you're suffering the same ... Probably having the intake mouth below the side mirror will be the best ↡ Advertisement Link to post Share on other sites More sharing options...
Saaber Neutral Newbie August 15, 2003 Share August 15, 2003 resist the itch lah... Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie August 15, 2003 Author Share August 15, 2003 Since you replied :-P Don't you feel the same Comeon lah .. let's spray to black together Link to post Share on other sites More sharing options...
Saaber Neutral Newbie August 15, 2003 Share August 15, 2003 I almost wanted to do it and also add a backlight......... but after reading abt your misadventure.......I had 2nd thoughts... OK lah, will join in the new project after my reservist....I'm going in from 18/8 to 30/8... Link to post Share on other sites More sharing options...
Saaber Neutral Newbie August 15, 2003 Share August 15, 2003 Have you put in a oil catch tank or oil breather tank? I intend to fabricate one, maybe we can brainstorm together to get it done cheaply...aftermarket one are very expensive... Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie August 15, 2003 Author Share August 15, 2003 The backlight idea is very good .. because at night, the display cannot see liao ... Also the oil catch tank ... I think no need lah ... our engine probably dun run so high rev till it spill oil out .. I checked the breather hose ... inside is so CLEAN ! No oil stain leh ! Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie August 16, 2003 Author Share August 16, 2003 It's time for you to post some reading liao Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie August 16, 2003 Share August 16, 2003 Initially I thought your intake is facing the front, you should get colder air (w/o affected by radiator fan) .. until I dig through the old thread and realised you're suffering the same ... Probably having the intake mouth below the side mirror will be the best My intake is facing (but not directly, about 40% direct) the air scoop but not joined to it. There's a gap of abt 2". I made it this way becos I was afraid of rain being sucked in. This, of course, prove unfounded as Turtlekar's and Saaber's design has shown. I need to redirect the opening to join with the air scoop. This, I believe, will reduce the amount of hot fadiator air being sucked in. Unfortunately, I have been too lazy.... Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie August 16, 2003 Author Share August 16, 2003 Just curious ... 1) Where is your thermometer probe placed?? (Sorry .. forgotten) 2) What is the highest temperature reached ? Link to post Share on other sites More sharing options...
Jacko Neutral Newbie August 16, 2003 Share August 16, 2003 Hi, Don't mind me join in. I've a 3" hose connected from my airbox to my front air scoop(no gap), tried driving in heavy rain without problem. But when I remove my air filter and found leaves, cigarette butt and tiny stone/sand inside, luckily the airfilter is there to block it. My concern is, will water wet the whole airfilter(mesh or sponge) during heavy rain and sip into the TB? And I reckon need to clean the filter and airbox regularly. Cheers! Link to post Share on other sites More sharing options...
Jacko Neutral Newbie August 16, 2003 Share August 16, 2003 Yeah, curious to know. My highest is 60+ when I step back into the car(before I crank it) during a hot afternoon start/stop drive! but drop to 40+ after move off a while. Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie August 16, 2003 Share August 16, 2003 1) Probe placed directly at the intake opening. 2) Highest temp when car stop with fan spinning is abt 50. Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie August 16, 2003 Share August 16, 2003 Solution for your ciggy butts/leaves/dead bird problem - place a wire mesh over the opening. If you look within the airbox properly, there are a few holes for water runoff. Water from the rain should not pose a problem. Unless you start to scoop in flood water! Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie August 16, 2003 Share August 16, 2003 Before you start the engine, the heat could be due to the engine heating the surrounding. Temp is only accurate with the engine running. Link to post Share on other sites More sharing options...
Jacko Neutral Newbie August 16, 2003 Share August 16, 2003 Yeah, this is the thing I need to do to stop rubbish get into it. I did realise there is a small hole at the bottom of the airbox. Do u think doing the TB bypass will help bring down a few degree? Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie August 16, 2003 Share August 16, 2003 I was looking at that article but I did not manage to locate the piping on mt babe. Gotta show them one of these Friday nights.... Link to post Share on other sites More sharing options...
Jacko Neutral Newbie August 16, 2003 Share August 16, 2003 Sorry ah, what is your ride? Link to post Share on other sites More sharing options...
Jacko Neutral Newbie August 16, 2003 Share August 16, 2003 Look like an Alfa to me. Is it 156? ↡ Advertisement Link to post Share on other sites More sharing options...
Google Maps latest version
Different version of 3M Clay Bar
Which version of 倚天
Which version of 倚天
Subaru S204 sti version 9 limited edition show piece car
Mitsubishi Colt Version R discussion
Toyota Corona (Big backside version)
Which version of the iPhone 6/7/8/n..would you rather own?
Bill gates invented NEWater
