Andrewkb Neutral Newbie August 16, 2003 Author Share August 16, 2003 Actually the other day .. I think I over oiled the K&N and the oil actually dripped out of the air filter box onto the floor !!! Red oily patch ! Solution for your ciggy butts/leaves/dead bird problem - place a wire mesh over the opening. If you look within the airbox properly, there are a few holes for water runoff. Water from the rain should not pose a problem. Unless you start to scoop in flood water! ↡ Advertisement Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie August 16, 2003 Share August 16, 2003 >>Is it 156? Yup! Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie August 16, 2003 Share August 16, 2003 (edited) Too much oil is no good. Some may got sucked in and dirty your air flow sensor. When I wash the thing, I let it stand to dry for 1 day, oil it, and let it stand for another 2-3 days so that excess oil can drain off. Rest it on tissue/toilet paper. In the meantime I drive ard with the stock filter. You only need to wash it after 60K. Tried washing at 20K once. That thing's still very clean. It's suppose to filter even better once it gets dirty. Edited August 16, 2003 by Mikeckchong Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie August 16, 2003 Author Share August 16, 2003 Aiyah ...again .. its the backside-itchy syndrome ... you got specialist to recommend or not Maybe can even suggest to SAF that those with this illness can immediately get PES E Link to post Share on other sites More sharing options...
Jacko Neutral Newbie August 16, 2003 Share August 16, 2003 >>You only need to wash it after 60K. Tried washing at 20K once. That thing's still very clean. It's suppose to filter even better once it gets dirty. err...I thought cleaner is better? dirty=blockage=less airflow right?? Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie August 16, 2003 Share August 16, 2003 Got treatment for this disease.......sell car! Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie August 16, 2003 Share August 16, 2003 Nope, a new gauze filter has bigger holes so filter efficiency may be lower compared to the paper filter. However, once it gets a bit dirty, the dirt helps to 'plug' the bigger holes, this making it a better filter. Link to post Share on other sites More sharing options...
Jacko Neutral Newbie August 16, 2003 Share August 16, 2003 OK, but air flow will be affected right? Guess there is no perfect solution. Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie August 16, 2003 Share August 16, 2003 (edited) There is a limit of dirt collected before flow will be significantly affected. Maybe you can check out K&N's website on the technical details. Ultimately it's most impt function is still filtering. Edited August 16, 2003 by Mikeckchong Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie August 16, 2003 Share August 16, 2003 have not done it.....these 2 days busy leh ↡ Advertisement Link to post Share on other sites More sharing options...
Google Maps latest version
Different version of 3M Clay Bar
Which version of 倚天
Which version of 倚天
Subaru S204 sti version 9 limited edition show piece car
Mitsubishi Colt Version R discussion
Toyota Corona (Big backside version)
Which version of the iPhone 6/7/8/n..would you rather own?
Bill gates invented NEWater
