Madarmour Neutral Newbie June 24, 2002 Share June 24, 2002 Mike, it's the reverse lights and not the brake lights that can be upgraded to 55W halogen I'm discussing with Luke. The LEDs for brake, signal and dim lights are low wattage and generate minimal heat. I'm still looking out for them Sorry..........wrong channel! Yeah, LEDs are a good option. ↡ Advertisement Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie June 24, 2002 Share June 24, 2002 Hmmm, u notice the traffic lights uses clear cover whereas the TIBS buses, they dont.Those bright traffic lights LEDs do stand out under direct sunlight, but those TIBS buses, I cant even see them light up under some daylight condition. BTW, only some of them, especially those benz standard length bus. You're right about the clear lens. With colored lens, it will block out the light from the LEDs. It also doesn't make sense because LEDs are available in plenty of colors so getting red and yellow LEDs should be no problem. If colored lens is to be used, the LEDs should be white and plenty of then should be installed. The LEDs from the traffic lights are bright because there are plenty of them in each cluster. It shows that LTA engineers are good while TIBSs' are klutz! Copy also must copy properly mah! Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie June 24, 2002 Share June 24, 2002 So the LEDs on colored lenses may not shine that well? That's a fruit for tot Use plenty of white LEDs lor! Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie June 24, 2002 Share June 24, 2002 A few actually jus for fun . Jag, Beam, Lex, but man, the S40 T4 really rocks! The pickup and push from standstill was quite phenomenal! Next week, I might go test the T5 or T6. So many cars in a day! I'm sure you had some fun! Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie June 24, 2002 Author Share June 24, 2002 Use plenty of white LEDs lor! Yeah then using white LEDs for all the lamp clusters better and easier to get too Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie June 24, 2002 Share June 24, 2002 Yeah then using white LEDs for all the lamp clusters better and easier to get too Problem is how to get enough LEDs through the small bulb apperture! Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie June 24, 2002 Author Share June 24, 2002 Good point, the LED cluster must be designed to be similarly sized as a standard tungsten bulb Link to post Share on other sites More sharing options...
Zen Neutral Newbie July 15, 2002 Share July 15, 2002 (edited) I'll try getting a pair and try first Just want brighter and whiter dim light to accompany my fogs when I drive without headlamps on......don't flame me! I drive with my fogs only when there's drizzle or when the evening is cloudy before 7pm. [angelic] tb, where to get the led bulb? my city bulb is now so yellowish compared to my white xenon need to balance abit lah ..hee Edited July 15, 2002 by Caractereman Link to post Share on other sites More sharing options...
Zen Neutral Newbie July 15, 2002 Share July 15, 2002 (edited) Good point, the LED cluster must be designed to be similarly sized as a standard tungsten bulb I have seen in us vortex that there's only 1 LED bulb used, although some thing is done to ensure that the base is big enough to plug into the socket. Edited July 15, 2002 by Caractereman Link to post Share on other sites More sharing options...
GDIzen Neutral Newbie July 16, 2002 Share July 16, 2002 Yeah then using white LEDs for all the lamp clusters better and easier to get too Problem is how to get enough LEDs through the small bulb apperture! Beware though! LEDs do not work with all cars as I tried them on a Bimmer and it fails to detect the LED bulb. Had to sell them to a Corolla owner. Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie July 16, 2002 Author Share July 16, 2002 Yeah I know this problem from some US Volvo owners, they had the bulb failure warning light on when they replaced with LED bulbs. Link to post Share on other sites More sharing options...
Yongwd 1st Gear July 16, 2002 Share July 16, 2002 i think brick requires 23W bulb, if u replace with a 21W unit, the lamp failure warning lamp will be lit? Yeah I know this problem from some US Volvo owners, they had the bulb failure warning light on when they replaced with LED bulbs. Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie July 16, 2002 Author Share July 16, 2002 I believe it's 5w LED vs 21W bulb Link to post Share on other sites More sharing options...
Zen Neutral Newbie July 16, 2002 Share July 16, 2002 (edited) TB, you know where in Sim lim or elsewhere sell a LED bulb? I went to the 3rd floor and only have this ... it looks abit big for my circuit board, and now i am trying to find alternnative, preferably similiar size. but at least the yellow LED function properly and once the board is covered, cannot tell Edited July 16, 2002 by Caractereman Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie July 16, 2002 Share July 16, 2002 Beware though! LEDs do not work with all cars as I tried them on a Bimmer and it fails to detect the LED bulb. Had to sell them to a Corolla owner. It's probably a case of the computer being too smart! BTW, did the LED light up when switched on? Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie July 16, 2002 Share July 16, 2002 Problem is.....is ONE LED bright enough? Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie July 16, 2002 Author Share July 16, 2002 U doing DIY LED bulbs for your car? There are plenty of shops in SLT selling LEDs, check there. Link to post Share on other sites More sharing options...
Zen Neutral Newbie July 16, 2002 Share July 16, 2002 Problem is.....is ONE LED bright enough? my problem is that my city bulb has extreme color compared to my low beam light ↡ Advertisement Link to post Share on other sites More sharing options...
Reverse/backup camera with dashcam recording function
What is OPC?
What is OPC?
Is it ok to 'chope' a parking lot just by standing there?
For Tier-2 Sheltered, non-restricted zone season parking in HDB MSCP, is there a difference in Day Season Parking vs Season Parking?
Cyclops Rear Light - Who came up with it first?
