Pisces69 6th Gear September 27, 2006 Share September 27, 2006 Dont we all bro............Dont we all. ↡ Advertisement Link to post Share on other sites More sharing options...
Robin 4th Gear September 28, 2006 Share September 28, 2006 i found it... but its very hard to reach. after 30 mins of fiddling with it , i couldnt get it to move at all... cause its obstructed. probably need a very small allen key Link to post Share on other sites More sharing options...
Pisces69 6th Gear September 28, 2006 Share September 28, 2006 B very careful when u turn/adjust these screws/nuts. Most r made of plastic & if it's stiff, u might not realise that u have overtighten it & cause u to strip the threads. Then u cannot adjust it back. Spray some lube like WD40 & let it soak for a few minutes b4 u try to adjust the tight screw/nut. Link to post Share on other sites More sharing options...
Robin 4th Gear September 29, 2006 Share September 29, 2006 mine's metal...but i was gentle lor... Link to post Share on other sites More sharing options...
Pisces69 6th Gear September 29, 2006 Share September 29, 2006 Yah hor. We more experienced guys r always gentle when we screw. Dosent matter if tight or not. Link to post Share on other sites More sharing options...
Robin 4th Gear September 29, 2006 Share September 29, 2006 (edited) if tight must insert gently n slowly... else later spoilt Edited September 29, 2006 by Robin Link to post Share on other sites More sharing options...
Poortraveller 1st Gear September 29, 2006 Share September 29, 2006 when u turn the screw driver, u have to see if the philips screw head bitting the gear ... Link to post Share on other sites More sharing options...
Poortraveller 1st Gear September 29, 2006 Share September 29, 2006 he say he'll try to post .... haha ... very busy lately lar ... Link to post Share on other sites More sharing options...
Pisces69 6th Gear September 29, 2006 Share September 29, 2006 Link to post Share on other sites More sharing options...
Poortraveller 1st Gear September 29, 2006 Share September 29, 2006 (edited) left right is which one ah? your turn to take photo if u to look carefully, on the left side where u see the black plastic holding the headlight, there is a hole, the adjustment is just inside that hole and u need a long screw driver to reach that area its the same for this pix ... just on the right side of ur red circle, plastic holder to hold onto the headlight housing Edited September 29, 2006 by Tenminste Link to post Share on other sites More sharing options...
Poortraveller 1st Gear September 29, 2006 Share September 29, 2006 i found it... but its very hard to reach. after 30 mins of fiddling with it , i couldnt get it to move at all... cause its obstructed. probably need a very small allen key come to my carpark ... i help u to adjust ... i think my marking is still @ the MSCP wall Link to post Share on other sites More sharing options...
Robin 4th Gear September 29, 2006 Share September 29, 2006 cant get the screw in.... its blocked by a metal piece at the side Link to post Share on other sites More sharing options...
Robin 4th Gear September 29, 2006 Share September 29, 2006 busy making babies Link to post Share on other sites More sharing options...
Robin 4th Gear September 29, 2006 Share September 29, 2006 err so i can consider myself quite experienced... Link to post Share on other sites More sharing options...
Robin 4th Gear September 29, 2006 Share September 29, 2006 errr... ok i try. but seriously the L/R screw cannot reach one... Link to post Share on other sites More sharing options...
Robin 4th Gear September 29, 2006 Share September 29, 2006 u mean i need to remove the black plastic housing.... ?! Link to post Share on other sites More sharing options...
Pisces69 6th Gear September 29, 2006 Share September 29, 2006 I think u already know how experienced u r. Link to post Share on other sites More sharing options...
Poortraveller 1st Gear September 30, 2006 Share September 30, 2006 dun need to remove the black housing ... just get a long screw driver can liao. just let me know if u need my help, just bring a can of tiger to my car park can liao ↡ Advertisement Link to post Share on other sites More sharing options...
Quad Light Bulb Size
P2096 Check engine light
