Poortraveller 1st Gear September 30, 2006 Share September 30, 2006 changing job liao ↡ Advertisement Link to post Share on other sites More sharing options...
Robin 4th Gear October 1, 2006 Share October 1, 2006 yah... somethings no need too many ppl know know is enuff... Link to post Share on other sites More sharing options...
Robin 4th Gear October 1, 2006 Share October 1, 2006 tiger dun have....lion can or not? maybe next sat night... next sat no EPL matches Link to post Share on other sites More sharing options...
Robin 4th Gear October 1, 2006 Share October 1, 2006 got offer liao? Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 1, 2006 Share October 1, 2006 Yup. Link to post Share on other sites More sharing options...
Dafansu Turbocharged October 1, 2006 Share October 1, 2006 which side of the lamp should be adjust to a lower angle or both at same angle Link to post Share on other sites More sharing options...
Poortraveller 1st Gear October 1, 2006 Share October 1, 2006 singa?? oso can let me know the timing Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear October 1, 2006 Share October 1, 2006 should be abt the same. sometimes the drivers side is just a lil lower. Link to post Share on other sites More sharing options...
Robin 4th Gear October 2, 2006 Share October 2, 2006 i'll see what i can get on my way there... else we can go your nearby coffeeshop or the mini mart i was going to ask u the time...U ask me. how about say... sat 9pm - 9.30pm? go which mscp? and what level? Link to post Share on other sites More sharing options...
Intx Neutral Newbie April 8, 2009 Share April 8, 2009 I did retrofit a Lexus projector to my car and wonders whether there are workshop who has the headlight beam aligner? The machine which has the horizontal and vertical beam alignment. Link to post Share on other sites More sharing options...
Yeobh 4th Gear April 10, 2009 Share April 10, 2009 If you use an european headlight aimer chance your ride will not make through headlight alignment test in the inspection centre. Link to post Share on other sites More sharing options...
Anthonyh Neutral Newbie April 11, 2009 Share April 11, 2009 Yes it is possible. But before that do a test drive and then just your journey. Link to post Share on other sites More sharing options...
Goincrazy Neutral Newbie July 27, 2009 Share July 27, 2009 why not park on a straight road with no obstacles 100m ahead then you adjust it to the idea level?? Link to post Share on other sites More sharing options...
Ahgong Supercharged March 5, 2014 Share March 5, 2014 Park car about 10 feet away from a wall. Switch on high beam, the rule of thumb - the beam should shin 5deg downward and 5deg towards the driver left side read thru 6 pages. still no exact specifications on how to adjust the beam to meet inspection specifications. 5 degree a bit hard to measure for light beam. no? any more, erm... better, definitive way to do the adjustments? Link to post Share on other sites More sharing options...
Yeobh 4th Gear March 5, 2014 Share March 5, 2014 (edited) read thru 6 pages. still no exact specifications on how to adjust the beam to meet inspection specifications. 5 degree a bit hard to measure for light beam. no? any more, erm... better, definitive way to do the adjustments? It's very diificult to adjust modern day cars headlights with simple european design workshop headlight aimers let alone using a target board drawn on the wall. PS Photo shows a Japanese version of head tester/aimer for workshop use Edited March 5, 2014 by Yeobh Link to post Share on other sites More sharing options...
Ahgong Supercharged March 5, 2014 Share March 5, 2014 hmmm... so in this case, there is no way for us to know if the headlights is properly adjusted until we go for inspection? Link to post Share on other sites More sharing options...
Yeobh 4th Gear March 5, 2014 Share March 5, 2014 hmmm... so in this case, there is no way for us to know if the headlights is properly adjusted until we go for inspection? Currently , vehicle test centres does conduct headlights alignment and brightness tests and will consider a major fault of the overall test if only the headlight fails the luminous test. Link to post Share on other sites More sharing options...
Ahgong Supercharged March 6, 2014 Share March 6, 2014 Currently , vehicle test centres does conduct headlights alignment and brightness tests and will consider a major fault of the overall test if only the headlight fails the luminous test. erm... english? dun understand leh. ↡ Advertisement Link to post Share on other sites More sharing options...
Cyclops Rear Light - Who came up with it first?
Are LED lights subject to brightness checks?
Quad Light Bulb Size
Recommendations for light kitchen carpentry and sink works
2009 hyundai avante HD
P2096 Check engine light
