Wrc206 Neutral Newbie July 20, 2006 Share July 20, 2006 Most ppl fail for their headlights but still pass the annual inspection. ↡ Advertisement Link to post Share on other sites More sharing options...
Cyberet Neutral Newbie July 20, 2006 Share July 20, 2006 (edited) more dangerous when u r driving on the opposite lane, encounter a few times, kena blinded, cannot see the narrow lane properly feel like flashing the high beam Edited July 20, 2006 by Cyberet Link to post Share on other sites More sharing options...
Robin 4th Gear September 21, 2006 Share September 21, 2006 hehe, i park about a metre from the wall, measure the height from the floor to my light bulb, measure on the wall, draw a marking 3 inch below the height of my light bulb. not sure correct or not, but when i drive, i observe my light beam is pretty straight, with a slight dip. i focus the most intense spot to the marking where can i find the "screws" to make the adjustment?! Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear September 21, 2006 Share September 21, 2006 Depending on the manufacturer, they're on the back or the top of the headlight assembly Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear September 21, 2006 Share September 21, 2006 watch our for alighning too high coz you may blind other drivers and also not get enough light on the ground. for e.g. i adjusted my high beams to abt 1m off the ground (on the wall that was 1.5m in front of me). ended up shining my light on the tops of trees 1km away but no light on the road Link to post Share on other sites More sharing options...
Robin 4th Gear September 21, 2006 Share September 21, 2006 failed the headlights test yesterday... but overall pass... Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear September 21, 2006 Share September 21, 2006 parallex error??? unless you get in the left seat then i think you need to lose weight Link to post Share on other sites More sharing options...
Robin 4th Gear September 21, 2006 Share September 21, 2006 hmm ok. roughly must stop how far from the wall? Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear September 21, 2006 Share September 21, 2006 Honestly i dont know. I do it by trial and error till my headlight cast a good throw wothout blinding others... i find that 1-2m from the wall seems to be the easiest to work with though Link to post Share on other sites More sharing options...
Robin 4th Gear September 21, 2006 Share September 21, 2006 ok... i'll try this weekend Link to post Share on other sites More sharing options...
Poortraveller 1st Gear September 21, 2006 Share September 21, 2006 huh?? how come fail? urs HID huh? Link to post Share on other sites More sharing options...
Poortraveller 1st Gear September 21, 2006 Share September 21, 2006 maybe Link to post Share on other sites More sharing options...
Robin 4th Gear September 21, 2006 Share September 21, 2006 not sure ... but i was standing there looking at the numbers and it seems that the nos for the right beam differ quite a lot from the left beam. so perhaps 1 side is not alignmet properly to give them min require throw, so fail. this is just my guess. i didnt see the result slip until i got back home, so i couldnt ask them why fail. when they say "ok, pass" ...i happy pun pi pi take cert go home Link to post Share on other sites More sharing options...
Pisces69 6th Gear September 21, 2006 Share September 21, 2006 This is how I adjust my headlights. Find a very dark & flat road. Some ulu carparks r good. Cover 1 side & adjust till u can just see the top of the beam touch the road in the distance. Then do the same for the other side. Now walk in front as though u r an oncoming driver & see if your headlights blind you. Make minor adjustments if necessary & there u r done. Maximum throw without annoying on-coming drivers. Remember to adjust the beam slightly to the left cos u want to see the left side of the road clearly. Link to post Share on other sites More sharing options...
Poortraveller 1st Gear September 21, 2006 Share September 21, 2006 wa lau ... like tat walk here walke there will make ur life shorter by another few second Link to post Share on other sites More sharing options...
Poortraveller 1st Gear September 21, 2006 Share September 21, 2006 but how u know it fail? they told u? Link to post Share on other sites More sharing options...
Robin 4th Gear September 21, 2006 Share September 21, 2006 where to find a very dark & flat road... i try my mscp Link to post Share on other sites More sharing options...
Robin 4th Gear September 21, 2006 Share September 21, 2006 no lah... its stated on the result slip... headlight - F ↡ Advertisement Link to post Share on other sites More sharing options...
Cyclops Rear Light - Who came up with it first?
Are LED lights subject to brightness checks?
Quad Light Bulb Size
Recommendations for light kitchen carpentry and sink works
2009 hyundai avante HD
P2096 Check engine light
