Tanlc Neutral Newbie February 19, 2004 Share February 19, 2004 In term of performance-wise, the smaller the diameter the better? Can Denso Iridium IK be used in Honda City iDSI? ↡ Advertisement Link to post Share on other sites More sharing options...
Vtim 3rd Gear February 19, 2004 Share February 19, 2004 the smaller the diameter, the lesser the voltage you required to create a spark, as the voltage of your car are constant, the end result you'll get a brighter spark than those on 2.5mm diameter. Also the Iridium can last for about 30k km as compare to copper's 5k~10k km. Yes, Denso IK20 is used on Honda's i-DSI engine but you'll need 8 plugs (2 set) I'll PM you Link to post Share on other sites More sharing options...
Tanlc Neutral Newbie February 19, 2004 Share February 19, 2004 DensoIK is so much expensive than Bosch Super4 What is the difference between IK16, IK20 and IK22? Link to post Share on other sites More sharing options...
Vtim 3rd Gear February 19, 2004 Share February 19, 2004 the number 16, 20, 22 are the Heat (temperature) range of the plugs that they can operate on, that's all. most NA cars can use IK16 or 20, some higher compression ratio cars need to use IK20 or IK22 especially T/C or S/C cars Your car manual will state which is the correct heat range plugs to be used on your car Link to post Share on other sites More sharing options...
Genie47 1st Gear February 19, 2004 Share February 19, 2004 I hear the name OWS Uber Power going to be mentioned! Link to post Share on other sites More sharing options...
Tanlc Neutral Newbie February 19, 2004 Share February 19, 2004 What's that? Link to post Share on other sites More sharing options...
Genie47 1st Gear February 20, 2004 Share February 20, 2004 Check with Vtim on these fine Iridium plugs from Germany. Link to post Share on other sites More sharing options...
Coyote Neutral Newbie February 20, 2004 Share February 20, 2004 Vtim is the man on spark plugs and some technical stuff. Bought mine from him lah. Link to post Share on other sites More sharing options...
Esky Neutral Newbie February 26, 2004 Share February 26, 2004 What's special about OWS spark plugs apart from them being cheaper than their Jap cousins? Link to post Share on other sites More sharing options...
Vtim 3rd Gear February 26, 2004 Share February 26, 2004 for the OWS, both the center & side electrode are made of Iridium but the size of the center electrode are not 0.4mm Link to post Share on other sites More sharing options...
Morris Neutral Newbie February 27, 2004 Share February 27, 2004 Hokkien say ai pe, ai chee, ai ........ Link to post Share on other sites More sharing options...
Nismo Neutral Newbie January 3, 2005 Share January 3, 2005 Don't use motorcycle ones on cars or vice versa. Use the ones for the application. PM Vtim, he got lobang for OWS Ir plugs that is cheaper than Denso or NGK. Good German stuff. halo bro....do u know if ows got plugs for our aveo? Link to post Share on other sites More sharing options...
Dwoon 1st Gear January 3, 2005 Share January 3, 2005 (edited) the number 16, 20, 22 are the Heat (temperature) range of the plugs that they can operate on, that's all. most NA cars can use IK16 or 20, some higher compression ratio cars need to use IK20 or IK22 especially T/C or S/C cars Your car manual will state which is the correct heat range plugs to be used on your car Bro, Can you enlighten about the thread size and reach etc.... normally, I would only hear about the heat range like IK20, IK22 etc..... but what about its other parameters? How are those classified? Thanks. Edited January 3, 2005 by Dwoon Link to post Share on other sites More sharing options...
Vtim 3rd Gear January 5, 2005 Share January 5, 2005 the number 16, 20, 22 are the Heat (temperature) range of the plugs that they can operate on, that's all. most NA cars can use IK16 or 20, some higher compression ratio cars need to use IK20 or IK22 especially T/C or S/C cars Your car manual will state which is the correct heat range plugs to be used on your car Bro, Can you enlighten about the thread size and reach etc.... normally, I would only hear about the heat range like IK20, IK22 etc..... but what about its other parameters? How are those classified? Thanks. here's more info for you to read : http://www.denso.com.sg/tpl/pdtlineup_plug_lineup.html http://www.denso.com.sg/tpl/pdtlineup_plug_typename.html Link to post Share on other sites More sharing options...
Nismo Neutral Newbie January 5, 2005 Share January 5, 2005 u have OWS spark plugs?... im not sure but i tink our aveo uses ZX6-iK from OWS. Do help me check if you have this plugs n if they are suitable... thanks bro Link to post Share on other sites More sharing options...
Vtim 3rd Gear January 11, 2005 Share January 11, 2005 bro, current supplier can't supply anymore as they were also caught by the product distributor for selling the plugs over the counter cheaper than the recommended retail price I'm trying to get another friend to source for me, only diff is than this other friend of my do not sell over the counter, so chances for me getting to sell again is quite good but it won't be so soon have you check out Volker-Iridium http://www.volker-iridium.com/ Link to post Share on other sites More sharing options...
Nismo Neutral Newbie January 11, 2005 Share January 11, 2005 looks good.. i crossed ref.. so how much is the volker 6ZX-11... maybe u would like to pm me.. thanks ah Link to post Share on other sites More sharing options...
Vtim 3rd Gear January 12, 2005 Share January 12, 2005 ok, better to pm ↡ Advertisement Link to post Share on other sites More sharing options...
Petrol Discounts in Singapore
Car of Politician
Car of Politician
Wheel Spacer, where to buy?
