Yansen Neutral Newbie July 9, 2004 Share July 9, 2004 hi all, after skimming my brake discs to get rid of the screeching sound ('eeeeeeee'), the sound comes back after a few days, although it is not so audible n obvious as before skimming. what could be the problem here? pls advice. thanks. ↡ Advertisement Link to post Share on other sites More sharing options...
Soya Supersonic July 9, 2004 Share July 9, 2004 the pads could be glazed. Link to post Share on other sites More sharing options...
Vtim 3rd Gear July 9, 2004 Share July 9, 2004 I think you need to change the pads liao Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 9, 2004 Share July 9, 2004 Skimming is only part of the bigger job. After skimming it is best to finish the surface by honing. Washing with hot soap water should follow and wipe dry with clean cloth. Replace the glazed brake pad with OEM parts. Link to post Share on other sites More sharing options...
Jermy Clutched July 9, 2004 Share July 9, 2004 Btw are u driving a Mit Lancer? Link to post Share on other sites More sharing options...
Yansen Neutral Newbie July 9, 2004 Author Share July 9, 2004 hi, thanks to the 3 of u for replying. however, i just changed my brake pads abt 2 weeks before skimming... so shouldn't be glazed right? Link to post Share on other sites More sharing options...
Yansen Neutral Newbie July 9, 2004 Author Share July 9, 2004 nope, driving a nissan presea. y leh? Link to post Share on other sites More sharing options...
Milky33 Neutral Newbie July 9, 2004 Share July 9, 2004 hi all, after skimming my brake discs to get rid of the screeching sound ('eeeeeeee'), the sound comes back after a few days, although it is not so audible n obvious as before skimming. what could be the problem here? pls advice. thanks. you mean when you apply brake then you have that sound or? Link to post Share on other sites More sharing options...
Aspri Clutched July 10, 2004 Share July 10, 2004 Perhaps you should replace brake pads after you skimmed your discs. Mine was screeching and mechanic advised to change both together. Anyway, pad was running out anyway so no issues with that. Now no more screeching. Link to post Share on other sites More sharing options...
Yansen Neutral Newbie July 10, 2004 Author Share July 10, 2004 yah when apply brake then will have the eeeeeeeee sound. very irritating lah. Link to post Share on other sites More sharing options...
Yansen Neutral Newbie July 10, 2004 Author Share July 10, 2004 icic.. i also asked my mech but he said dont need leh. but y is it that must change both together even if my pads r relatively new? Link to post Share on other sites More sharing options...
Terence_oh Neutral Newbie July 10, 2004 Share July 10, 2004 I just changed my brake pads for the same reason (brake discs were skimmed, and then plenty of screeching). When the mechanic removed the old pads, he showed me how the edges were roughed up and distorted from the old disc surface, and said that was the cause of the noise. The old pads themselves were still relatively new. Some people have suggested 'cambering' the discs to smoothen the edge and remove the rough edge but I believe it will cause about half the cost of the brake pad change anyway. I bit the bullet, and changed to Project Mus at $100, and now it's noise-free. Link to post Share on other sites More sharing options...
Yansen Neutral Newbie July 10, 2004 Author Share July 10, 2004 oic.. ok so looks like i gotta get another new set of pads in less than a month! haha Link to post Share on other sites More sharing options...
Ahliew Neutral Newbie July 11, 2004 Share July 11, 2004 (edited) my ride screeches on the right side when brakes are applied father doesnt want to change brake pads, since its going to be scrapped(exported to south africa ) at around august Edited July 11, 2004 by Ahliew Link to post Share on other sites More sharing options...
Milky33 Neutral Newbie July 11, 2004 Share July 11, 2004 well...i think you should get the mechanic to file the brake pad for you...if the sound still there then you consider changing a new brake pad,don't need to spend unnessary... Link to post Share on other sites More sharing options...
Bcyn Neutral Newbie July 11, 2004 Share July 11, 2004 drive back to the mechanic that did everyting up for u... den make noise tell him i dun care... i dun wanna hear that sound. Link to post Share on other sites More sharing options...
Ace_t Neutral Newbie July 12, 2004 Share July 12, 2004 see if you can get yr mech to open the calipers to see your brake pads.. maybe got foreign particles embedded inside the pads ? dun waste good money on another set of pads. Link to post Share on other sites More sharing options...
Yansen Neutral Newbie July 13, 2004 Author Share July 13, 2004 hi, what do u mean by file the brake pad? thanks.. ↡ Advertisement Link to post Share on other sites More sharing options...
Sound Proofing the car
Whole car sound proof
Brake Pads
Brake Pads
Right side speakers no sound
