Blaster Neutral Newbie July 25, 2004 Share July 25, 2004 Need some advice here. My current ride is a nissan b14 (i know quite old liao). Would like to increase the HP and torque. Will having a piggyback ECU helps? Or any other mods to do the job? Dun tell me to change car hor... ↡ Advertisement Link to post Share on other sites More sharing options...
Ah_veo Neutral Newbie July 25, 2004 Share July 25, 2004 bro....can i tong pang abit here? sori.... those reading this, pls oso recommend gadgets to reduce FC for Santa Fe. tks.. Link to post Share on other sites More sharing options...
Yansen Neutral Newbie July 25, 2004 Share July 25, 2004 piggyback ecu, straight flow exhaust, change extractor etc.. Link to post Share on other sites More sharing options...
Genie47 1st Gear July 25, 2004 Share July 25, 2004 Go one step at a time so that you will know what is working and what is not. First change to CAI. Monitor or dyno. Got increase, keep. Don't have, troubleshoot. Maybe sucking hot air. Dyno. OK? Good. Not OK, throw away the thing. Don't mod this area. Change exhaust header and everything. Repeat. ECU and piggyback ECU should be the last thing you should mod. Link to post Share on other sites More sharing options...
BMW320i Neutral Newbie July 25, 2004 Share July 25, 2004 Just to check with you sir, I've seen those plastic pipe with its opening facing outwards of the bonnet, whats that actually for ? I heard its called "rammed air **********" Link to post Share on other sites More sharing options...
Genie47 1st Gear July 25, 2004 Share July 25, 2004 (edited) Yeah it is air ram induction or air ram intake. Must have the bonnet scoop to work. Faster you go, more air getting into the engine. Edited July 25, 2004 by Genie47 Link to post Share on other sites More sharing options...
BMW320i Neutral Newbie July 25, 2004 Share July 25, 2004 (edited) wah ... then all the foreign objects go in as well ? Between CAI and the rammed air intake which is more effective ? think need to do a cut on the bumper to make way for the pipe ... Edited July 25, 2004 by BMW320i Link to post Share on other sites More sharing options...
Genie47 1st Gear July 25, 2004 Share July 25, 2004 Bumper? No you got it all wrong. CAI usually has a tube running to an empty foglight position. ARI has a hole on the bonnet. A CAI can be considered an ARI when you put have the tube run from the empty foglight position. Both have filters. So you don't have to worry about foreign objects. Link to post Share on other sites More sharing options...
BMW320i Neutral Newbie July 25, 2004 Share July 25, 2004 icic. learned something new today cheers Link to post Share on other sites More sharing options...
Genie47 1st Gear July 25, 2004 Share July 25, 2004 Sometimes not necessarily from the empty fog position. Some CAI systems use an airbox heatshield. Check out the ITG airbox system. Link to post Share on other sites More sharing options...
BMW320i Neutral Newbie July 25, 2004 Share July 25, 2004 From what I was told, CAI increase high end torque but decreases low end in return. But after my friend fixed it, it actually increase low end rather then high end, that I'm puzzled. My low end torque is low enough Link to post Share on other sites More sharing options...
Normal_aspirated Clutched July 25, 2004 Share July 25, 2004 Depends, if retain stock filter box, yes. Link to post Share on other sites More sharing options...
Normal_aspirated Clutched July 25, 2004 Share July 25, 2004 <<<<<<Both have filters. So you don't have to worry about foreign objects.>>>>> As long as it don't suck flood water from below, esp those closed types. Link to post Share on other sites More sharing options...
BMW320i Neutral Newbie July 25, 2004 Share July 25, 2004 ic ... Actually my car is still under warranty hence making any mods a pain in the rear... I actually considered replacing stock filters with K&N but I'm afraid those people at PML will cook up all sorts of rubbish saying "oh ! its because of your filters thats why your car door can't close properly." haiz ... think I'll keep it stock Link to post Share on other sites More sharing options...
Blaster Neutral Newbie July 25, 2004 Author Share July 25, 2004 Why should ECU be the last thing to mod? I was thinking of doing it as the first thing. Link to post Share on other sites More sharing options...
Normal_aspirated Clutched July 25, 2004 Share July 25, 2004 Genie is correct to say. If not, you will be even spending more $$$$$ to dyno & tune yer ECU. Link to post Share on other sites More sharing options...
Blaster Neutral Newbie July 25, 2004 Author Share July 25, 2004 hmmm ok....where can i get the CAI, straight through and extractor? how much will all these cost me? Have to start bugeting liao.... Anyway, any of these mods is illegal? Link to post Share on other sites More sharing options...
Goffy3 Neutral Newbie July 25, 2004 Share July 25, 2004 the add is : http://www.eguide.com.sg/eGuideGlobal/Index_searchf.asp Hope it help. ↡ Advertisement Link to post Share on other sites More sharing options...
ERP rates increase/decrease thread monitor!
Torque wrench hunt
Torque wrench hunt
Home repair advice needed
RS Chip Tuning
RS Chip Tuning
Computer advice needed
Town Council S&C Charges May Increase Soon!
